Proposal: Parallax Penguin rePurposed ???
First, where has all the Penguin info gone, Parallax? These links from the sticky are dead:
PENGUIN PRODUCT PAGE
www.parallax.com/detail.asp?product_id=27313
PENGUIN DOCUMENTATION
www.parallax.com/dl/docs/prod/robo/27313-6%20PenguinDoc-v1.0.pdf
Would sure like to see updated links to this info, Parallax! Otherwise, the sticky is pretty useless. Lots of Penguin owners out here.
Second, I can't be the only person who has considered using a Penguin controller board on a wheeled (BoeBot or equivalent) base. I know, it's heresy, walkers are inherently cooler than rolling bots. But...
I have an extra Penguin kit from the giveaway. Built one, saved one. The Penguin is cool, but face it, the walking is not that consistent. Novel yes, accurate no. The controllability of the tilt-stride mechanism depends on mechanical adjustment, surface friction, and many other factors. No chance of dead reckoning or tracing a consistent path. It seems to me that the built-in surface mount compass and the higher-power processor (BS2PX IIRC, can't find the info!) are almost going to waste here. I played with my Penguin for a while, but he mostly sits up on the shelf.
But if you were to transplant that board onto a smooth rolling robot with encoders and good speed control, you might start to have something fun to experiment with, navigationally speaking. Especially if you connected a few I/O & power lines to a breadboard area, as on BoeBot, to add a PING or IR sensor.
We could always make a BS1-IC or BS2 controller to keep the Penguin mechanicals going.
Am I a bad guy for even suggesting such a terrible thing?
Martin_H: That's a fantastic concept, pity that you'll never get around to doing it. Steering using the compass heading is pure genius, so since the execution is up for grabs, if I do it, it's all mine. Thanks Bro!
PS: What other great ideas will you never execute? Lemme know!
PENGUIN PRODUCT PAGE PENGUIN DOCUMENTATION"
The two links came from the product page and there is no product so the links went inactive.
The sticky is still very useful as many other links are working or can be converted.
The docs are still available as they were saved off site.
Most of the links at the Penguin Signature Site are working too or can be converted.
http://forums.parallax.com/showthread.php?129592-Penguin-Robot&p=977061#post977061
You can easily find the Penguin documentation you want listed there for download.
Another good source is the PRS Penguin Robot Society Web Site. http://www.p-robot.com/
