What would you like to see on a Propeller2 Development board?
From what I read in the preliminary specs for the Propeller2 external memory can be added for use by the video and all kinds of other stuff. I would like to see a development board with all the bells and whistles. Easy connections for the external memory, access to ALL ports, uSD card slot, Stereo audio amp, LED indicators, NO voltage translators, VR's, Pushbuttons/switches, VGA & TV connections, Large eeprom. But most of all I would like an easy way to switch in/out all of the added accessories to have the ports available. I'm not sure about everybody else, but the LED displays I have never used but to play with, maybe that space could be used for some goodies.
I don't mind paying a little more for a great Development board, what would you like to see on it?
Edit: ok voltage translators on the servo header connections.
http://www.mini-itx.com/store/?c=3
http://en.wikipedia.org/wiki/Mini-ITX
http://www.logicsupply.com/products/slfjt_01
MP3 decoder will be cool too.
Currently it seems that every accessory Parallax sells has its own different connector; standardizing for a development platform would be very helpful.
Shields are a start towards the goal of a standardized connecter, but go a little too too far in the other direction in that each shield covers every pin, plus, piggybacking boards is an awkward construction, in my opinion.
It would be nice to have a sort of backplane configuration with half a dozen or so sockets on a development board that each provide ground, power and maybe 4 to 12 IO pins, sort of like spinStudio, if anyone remembers that board.
Plus, sell empty connector sockets so users can easily and cheaply build up their own accessory boards.
Maybe a bit like Digilent does? They call their system PMod, and all their FPGA boards support the modules. Here is one (small) example: http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,790&Prod=BASYS2
The Basys2 has 4 PMod expansion port headers, along with a collection of the most commonly used accessories.
Here is the list of their PMod accessories: http://www.digilentinc.com/Products/Catalog.cfm?NavPath=2,401&Cat=9
Assuming that most accessories need 8 or less I/O, they could come with a matching connectorr to fit right on one.
Accessories that need more I/O (like RAM) could span a set of headers if they're placed in a regular pattern.
Keep the board mostly clean, with just power, uSD, VGA and Keyboard/Mouse implemented on the board.
Anything else on add-on boards. Make the boards a 'standard size' with known connector placement and screw holes, and anyone can make new ones.
I don't use my PPDB much, use Quickstarts, PP-USB, Protoboards more. My C3 in a case gets tossed in my brief case a lot. Quickstarts are like microcontroller duct tape!
Since some micro-ITX cases have quite a bit of extra room for a Cd player or hard disk, providing a board that fits a CD player or hard disk foot print might be another good alternative. One could set up an micro-ITX computer with a Propeller2 board in the same case. This would all be rather seamless for developers.
Regarding back planes, shields, and such...
Ribbon cables with multiple sockets make a good back plane with lots of flexibility.
So if the Propeller2 board has a 90 degree ribbon cable socket coming off the board, one can stack endlessly. This would eliminate problems that Arduino shields have with stacking more than one.
But beware that the edge for ribbon cable interface must not be mixed with other ports.
Power, RS-232, VGA, USB, Keyboard and Mouse all need to be on another edge that can be fitted to holes through a chassis. The ribbon cable would conflict with this.
On the old PDB, I've never used much of what's there, but I can see where some would.
Maybe only 4 buttons and 4 dip switches would be enough. I never used the RTC because I prefer the DS1302.
Instead of (or in addition to) the 2x8 LCD connector a 1x16 (or better 1x20) would have be more useful.
LEDs are usually easier to control than LCDs, too.
1) A simple board like prop 1 demo or proto board, but with SD and SRAM.
2) A bigger board like Prop BOE or PPDB with headers for various kinds of video (component/composite, VGA), keyboard connector, SRAM, SD connector, audio amp, servo headers, buttons, level translator (5V)
All prop 2 boards should include SD and SRAM.
USB IO
SD for booting and program storage
Big power supplies
10 2x5 headers with ground, 8 IO pins and jumper selectable power (3.3 volts or Vin)
I would arrange the 2x5 headers 4 on top and bottom and 2 on a side fairly close together maintaining pin spacing of 0.1 inches (no Arduino mistake). RAM, video, LCD, sound, etc. can be on boards that plug into the 2x5 headers or can be connected with ribbon cable if needed to be remotely mounted from the development board.
Pins that are not sent to 2x5 header or used for USB, SD card, boot process, could be split between LED and push button switches.
John Abshier
