New XMM hardware - Page 6 — Parallax Forums
New XMM hardware
12346»
  • average joeaverage joe Posts: 795
    edited 2012-06-05 02:39
    Well, I've given up on the new board for now. I only have 1 display and the other board works, sort of. So, I'll be stepping back to that board as soon as I re-design the power supply fix.
    The cache driver is a bit tricky. My idea is to lock the COMMON resources before accessing that resource.. I see 2 different resources, the SD card AND the SRAM. Use 1 lock or 2?
    spi_flash_cache.spin seems to use the locks in a special way?
    lock_set_handler
            mov     lock_id, vmaddr
            mov     lck_spi, lock_set
            mov     nlk_spi, lock_clr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
    lock_id long    0               ' lock id for optional bus interlock
    From what I can tell, this copies in the lock set and clear instructions into their "placeholders" in this code
    miss    movd    mtest, line
            movd    mst, line
    lck_spi test    $, #0 wc                ' lock no-op: clear the carry bit
       if_c jmp     #lck_spi
            mov     dira, spidir            ' set the pins back so we can use them
    mtest   test    0-0, dirty_mask wz
      if_z  jmp     #:rd                    ' current page is clean, just read new page
            mov     vmaddr, vmcurrent
            shl     vmaddr, offset_width
            call    #BWRITE                 ' write current page
    :rd     mov     vmaddr, vmpage
            call    #BREAD                  ' read new page
            mov     dira, #0                ' release the pins for other SPI clients
    nlk_spi nop
    mst     mov     0-0, vmpage
    miss_ret ret
    I get the basic idea, but still not sure how to compensate for this:
    I'm also unsure how to pass in the lock id with a start-up parameter? Or is this unnecessary? I will work up some code for review and comments.
    edited 2012-06-05 03:51
    I guess a better question is this: What is an extended function in spi_flash_cache? How is it called? I started working on a patch and this is what I have so far::
      Skeleton JCACHE external RAM driver
      Copyright (c) 2011 by David Betz
      Based on code by Steve Denson (jazzed)
      Copyright (c) 2010 by John Steven Denson
      Inspired by VMCOG - virtual memory server for the Propeller
      Copyright (c) February 3, 2010 by William Henning
      For the EuroTouch 161 By James Moxham and Joe Heinz
      Basic port by Joe Heinz, Optimizations by Steve Denson
      Copyright (c) 2012 by John Steven Denson and Joe Heinz
      TERMS OF USE: MIT License
      Permission is hereby granted, free of charge, to any person obtaining a copy
      of this software and associated documentation files (the "Software"), to deal
      in the Software without restriction, including without limitation the rights
      to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
      copies of the Software, and to permit persons to whom the Software is
      furnished to do so, subject to the following conditions:
      The above copyright notice and this permission notice shall be included in
      all copies or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
      IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
      FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
      AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
      LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,ARISING FROM,
      OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
      THE SOFTWARE.
    CON
      ' default cache dimensions
      DEFAULT_INDEX_WIDTH   = 6
      DEFAULT_OFFSET_WIDTH  = 7
      ' cache line tag flags
      EMPTY_BIT             = 30
      DIRTY_BIT             = 31
    PUB image
      return @init_vm
    DAT
            org   $0
    ' initialization structure offsets
    ' $0: pointer to a two word mailbox
    ' $4: pointer to where to store the cache lines in hub ram
    ' $8: number of bits in the cache line index if non-zero (default is DEFAULT_INDEX_WIDTH)
    ' $a: number of bits in the cache line offset if non-zero (default is DEFAULT_OFFSET_WIDTH)
    ' note that $4 must be at least 2^(index_width+offset_width) bytes in size
    ' the cache line mask is returned in $0
    init_vm mov     t1, par             ' get the address of the initialization structure
            rdlong  pvmcmd, t1          ' pvmcmd is a pointer to the virtual address and read/write bit
            mov     pvmaddr, pvmcmd     ' pvmaddr is a pointer into the cache line on return
            add     pvmaddr, #4
            add     t1, #4
            rdlong  cacheptr, t1        ' cacheptr is the base address in hub ram of the cache
            add     t1, #4
            rdlong  t2, t1 wz
      if_nz mov     index_width, t2     ' override the index_width default value
            add     t1, #4
            rdlong  t2, t1 wz
      if_nz mov     offset_width, t2    ' override the offset_width default value
            mov     index_count, #1
            shl     index_count, index_width
            mov     index_mask, index_count
            sub     index_mask, #1
            mov     line_size, #1
            shl     line_size, offset_width
            mov     t1, line_size
            sub     t1, #1
            wrlong  t1, par
            shr     line_size, #1       ' divide lenght by two for word-byte after response - jsd
            mov     frqa, _frqa         ' setup NCO freq
            mov     frqb, _frqb         ' setup EDGE freq
            ' put external memory initialization here
            jmp     #vmflush
    fillme  long    0[128-fillme]           ' first 128 cog locations are used for a direct mapped cache table
            fit   128
            ' initialize the cache lines
    vmflush movd    :flush, #0
            mov     t1, index_count
    :flush  mov     0-0, empty_mask
            add     :flush, dstinc
            djnz    t1, #:flush
            ' start the command loop
    waitcmd wrlong  zero, pvmcmd
    :wait   rdlong  vmline, pvmcmd wz
      if_z  jmp     #:wait
            shr     vmline, offset_width wc ' carry is now one for read and zero for write
            mov     set_dirty_bit, #0       ' make mask to set dirty bit on writes
            muxnc   set_dirty_bit, dirty_mask
            mov     line, vmline            ' get the cache line index
            and     line, index_mask
            mov     hubaddr, line
            shl     hubaddr, offset_width
            add     hubaddr, cacheptr       ' get the address of the cache line
            wrlong  hubaddr, pvmaddr        ' return the address of the cache line
            movs    :ld, line
            movd    :st, line
    :ld     mov     vmcurrent, 0-0          ' get the cache line tag
            and     vmcurrent, tag_mask
            cmp     vmcurrent, vmline wz    ' z set means there was a cache hit
      if_nz call    #miss                   ' handle a cache miss
    :st     or      0-0, set_dirty_bit      ' set the dirty bit on writes
            jmp     #waitcmd                ' wait for a new command
    ' line is the cache line index
    ' vmcurrent is current cache line
    ' vmline is new cache line
    ' hubaddr is the address of the cache line
            movd    mst, line
    lck_bus test    $, #0 wc                ' lock no-op: clear the carry bit
       if_c jmp     #lck_bus
      if_z  jmp     #:rd                    ' current cache line is clean, just read new one
            call    #wr_cache_line          ' write current cache line
    :rd     mov     vmaddr, vmline
            call    #rd_cache_line          ' read new cache line
    nlk_bus nop
    mst     mov     0-0, vmline
    miss_ret ret
    ' pointers to mailbox entries
    pvmcmd          long    0       ' on call this is the virtual address and read/write bit
    pvmaddr         long    0       ' on return this is the address of the cache line containing the virtual address
    cacheptr        long    0       ' address in hub ram where cache lines are stored
    vmline          long    0       ' cache line containing the virtual address
    vmcurrent       long    0       ' current selected cache line (same as vmline on a cache hit)
    line            long    0       ' current cache line index
    set_dirty_bit   long    0       ' DIRTY_BIT set on writes, clear on reads
    zero            long    0       ' zero constant
    dstinc          long    1<<9    ' increment for the destination field of an instruction
    t1              long    0       ' temporary variable
    t2              long    0       ' temporary variable
    tag_mask        long    !(1<<DIRTY_BIT) ' includes EMPTY_BIT
    index_width     long    DEFAULT_INDEX_WIDTH
    index_mask      long    0
    index_count     long    0
    offset_width    long    DEFAULT_OFFSET_WIDTH
    line_size       long    0                       ' line size in bytes
    empty_mask      long    (1<<EMPTY_BIT)
    dirty_mask      long    (1<<DIRTY_BIT)
    ' input parameters to rd_cache_line and wr_cache_line
    vmaddr          long    0       ' external address
    hubaddr         long    0       ' hub memory address
    ' temporaries used by rd_cache_line and wr_cache_line
    ptr             long    0
    count           long    0  ' copy line size from shifted line size
    'get_values              rdlong  hubaddr, hubptr         ' get hub address
    '                        rdlong  ramaddr, ramptr         ' get ram address
    '                        rdlong  len, lenptr             ' get length
    '                        mov     err, #5                 ' err=5
    'get_values_ret          ret
    'init                    'mov     err, #0                  ' reset err=false=good
                            'mov     dira,zero                ' tristate the pins with the cog dira
    '                        and     dira,maskP0P20P22       ' tristates all the common pins
    'done                    'wrlong  err, errptr             ' status  =0=false=good, else error x
                            'wrlong  zero, comptr            ' command =0 (done)
    lock_set_handler
            mov     lock_id, vmaddr
            mov     lck_bus, lock_set
            mov     nlk_bus, lock_clr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
               ' Pass pasm_n = 0- 7 come to this with P0-P20 and P22 tristated and returns them as this too
    set137                  or      dira,maskP22            ' pin 22 is an output
                            andn    outa,maskP22            ' set P22low so Y0-Y7 are all high
                            or      dira,maskP0P20          ' pins P0-P20 are outputs
                            and     outa,maskP0P2low        ' set these 3 pins low
                            or      outa,pasm_n             ' set the 137 pins
                            or      outa,maskP22            ' pin 22 high
    set137_ret              ret                             ' return
    load161pasm                                             ' uses vmaddr
                            mov     count, line_size       ' make a copy of line_size AND.
                            mov     ptr, hubaddr            ' hubaddr = hub page address
                           'or      outa,maskP0P20          ' set P0-P20 high - unnecessary - jsd
    lock                    lockset lock_id wc
                            or      dira,maskP0P20          ' output pins 0-20
                            mov     pasm_n,#0               ' group 0
                            call    #set137                 ' set the 137 output
                            and     outa,maskP0P18low       ' pins 0-18 set low
                            shr     vmaddr, #1              ' schematic connects SRAM A0 to A0, not A1 - jsd
                            or      outa,vmaddr             ' output addres to 161 chips
                            andn    outa,maskP19P20         ' clock and load low
                            or      outa,maskP19            ' clock high
                            or      outa,maskP20            ' load high
    load161pasm_ret         ret
    stop                    jmp     #stop                  ' for debugging
    memorytransfer          or      dira,maskP16P20         ' so /wr and other pins definitely high
                            or      outa,maskP16P20
                            mov     pasm_n,#1               ' back to group 1 for memory transfer
                            call    #set137                 ' as next routine will always be group 1
                            or      dira,maskP16P20         ' output pins 16-20
                            or      outa,maskP16P20         ' set P16-P20 high (P0-P15 set as inputs or outputs in the calling routine)
    memorytransfer_ret      ret
    ' setups needed for burst read
    _frqa                   long    $1000_0000
    _ctra                   long    4<<26 | 19      ' NCO mode on P19
    _phsa                   long    $0000_0000      ' phsa offset for adjusting clock start
    _frqb                   long    2               ' phsb accumulates twice per edge
    _ctrb                   long    $A<<26| 19      ' Edge Accumulate mode on P19
    ' rd_cache_line - read a cache line from external memory
    ' vmaddr is the external memory address to read
    ' hubaddr is the hub memory address to write
    ' line_size is the number of bytes to read
    rd_cache_line
    ' command T
    pasmramtohub
                            call    #load161pasm            ' load the 161 counters with ramaddr
                            call    #memorytransfer         ' set to group 1, enable P16-P20 as outputs and set P16-P20 high
                            and     dira,maskP16P31         ' set P0-P15 as inputs
                            andn    outa,maskP16            ' memory /rd low
                            or      outa,maskP19
                            mov     phsa, _phsa             ' init counters phsa
                            mov     phsb, ptr               ' save hub ptr to phsb
                            mov     ctrb, _ctrb             ' set ctr be mode
                            andn    outa,maskP19            ' start counters
                            rdword  data_16,phsb            ' sync up only
                            mov     ctra, _ctra             ' enable address counter clk
    ramtohub_loop           ' 10MB/s read loop uses phsb for hub pointer
                            mov     data_16,ina             ' get first data
                            wrword  data_16,phsb            ' move data to hub
                            djnz    count,#ramtohub_loop
                            or      outa,maskP19            ' stop clock
                            mov     ctra, #0                ' stop counter
                            or      outa,maskP16            ' memory /rd high
                            or      dira,maskP0P15          ' %00000000_00000000_11111111_11111111 restore P0-P15as outputs
    rd_unlock               lockclr lock_id
    rd_cache_line_ret       ret
    ' wr_cache_line - write a cache line to external memory
    ' vmaddr is the external memory address to write
    ' hubaddr is the hub memory address to read
    ' line_size is the number of bytes to write
    wr_cache_line
     ' command S
    pasmhubtoram
                            or      dira,maskP0P15          ' set prop pins 0-15 as outputs
    hubtoram_loop           and     outa,maskP16P31         '%11111111_11111111_00000000_00000000       ' clear for output
                            rdword  data_16,ptr         ' get the word from hub
                            and     data_16,maskP0P15       ' mask to a word only
                            or      outa,data_16            ' send out the byte to P0-P15
                            andn    outa,maskP17            ' set mem write low
                            add     ptr,#2              ' increment by 2 bytes = 1 word. Put this here for small delay while writes
                            or      outa,maskP17            ' mem write high
                            andn    outa,maskP19            ' clock 161 low
                            or      outa,maskP19            ' clock 161 high
                            djnz    count,#hubtoram_loop      ' loop this many times
    wr_unlock               lockclr lock_id
    wr_cache_line_ret       ret
    pasm_n                  long    0                                    ' general purpose value
    data_16                 long    0                                    ' general purpose value
    maskP0P2low             long    %11111111_11111111_11111111_11111000 ' P0-P2 low
    maskP0P20               long    %00000000_00011111_11111111_11111111 ' P0-P18 enabled for output plus P19,P20
    maskP0P18low            long    %11111111_11111000_00000000_00000000 ' P0-P18 low
    maskP16                 long    %00000000_00000001_00000000_00000000 ' pin 16
    maskP17                 long    %00000000_00000010_00000000_00000000 ' pin 17
    maskP18                 long    %00000000_00000100_00000000_00000000 ' pin 18
    maskP19                 long    %00000000_00001000_00000000_00000000 ' pin 19
    maskP20                 long    %00000000_00010000_00000000_00000000 ' pin 20
    maskP22                 long    %00000000_01000000_00000000_00000000 ' pin 22
    maskP19P20              long    %00000000_00011000_00000000_00000000 ' pin 19/20
    maskP16P31              long    %11111111_11111111_00000000_00000000 ' pin 16 to pin 31
    maskP0P15               long    %00000000_00000000_11111111_11111111 ' for masking words
    maskP16P20              long    %00000000_00011111_00000000_00000000
    maskP0P20P22            long    %11111111_10100000_00000000_00000000 ' for returning all group pins HiZ
            fit     496
    I don't think this is even close. First, this defaults not to use the lock
            movd    mst, line
       if_c jmp     #lck_bus
    nlk_bus nop
    mst     mov     0-0, vmline
    miss_ret ret
    This does nothing new until you call :
    lock_set_handler
            mov     lock_id, vmaddr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
    Which patches the lock set and clear commands into the no:ops? This is done at the end of the dispatch section of the extend command? I'm not sure how to replicate?
    Please ignore SD lock comment since I realized the only time the cache will use the SD is on boot loading SD content to SRAM. The "program" will not be running, so no need to lock SD. UNLESS using SDxmmC? *Not sure I want to at this point?*
    If you guys could point me in the direction of FIXING this I would appreciate it. I will look at the OTHER cache drivers to see how they differ.
    Thanks guys...
    Oh, btw.. what's going on with the board? I could use a logic analyzer on the LCD pins if someone has the time. :D If not I understand!
    edited 2012-06-05 04:01
      THE SOFTWARE.
    CON
      EMPTY_BIT             = 30
      DIRTY_BIT             = 31
    PUB image
      return @init_vm
    DAT
            org   $0
            add     pvmaddr, #4
            add     t1, #4
            add     t1, #4
            rdlong  t2, t1 wz
            add     t1, #4
            rdlong  t2, t1 wz
            mov     index_count, #1
            sub     index_mask, #1
            mov     line_size, #1
            mov     t1, line_size
            sub     t1, #1
            wrlong  t1, par
            jmp     #vmflush
            fit   128
            mov     t1, index_count
            add     :flush, dstinc
            djnz    t1, #:flush
      if_z  jmp     #:wait
            mov     hubaddr, line
            movs    :ld, line
            movd    :st, line
            movd    mst, line
       if_c jmp     #lck_bus
    nlk_bus nop
    mst     mov     0-0, vmline
    miss_ret ret
    index_mask      long    0
    index_count     long    0
    ptr             long    0
    'get_values_ret          ret
    lock_set_handler
            mov     lock_id, vmaddr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
    load161pasm_ret         ret
                            or      outa,maskP16P20
    rd_cache_line
    ' command T
    pasmramtohub
                            or      outa,maskP19
    wr_cache_line
     ' command S
    pasmhubtoram
            fit     496
            movd    mst, line
       if_c jmp     #lck_bus
    nlk_bus nop
    mst     mov     0-0, vmline
    miss_ret ret
    lock_set_handler
            mov     lock_id, vmaddr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
    Thanks guys...
    We use function #7 to set the lock and since that is currently the highest function code used by the driver the code was placed directly after the lock table to save one long which would normally be just a jmp to the start of the handler. That's clever coding by Ted.
    edited 2012-06-05 04:28
    Okay, I think I'm with you on the structure. I'm still unsure about how to modify the CURRENT cache driver to support locking. Seems like I need to add extended functionality?
    extend  mov     vmaddr, vmpage
            shr     vmaddr, #8
            shr     vmpage, #2
            and     vmpage, #7
            add     vmpage, #dispatch
            jmp     vmpage
    dispatch
            jmp     #waitcmd
            jmp     #erase_4k_block_handler
            jmp     #write_data_handler
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
    '       jmp     #lock_set_handler - This is the next instruction - no need to waste a long
    Is called from the beginning of the command loop:
    waitcmd mov     dira, #0                ' release the pins for other SPI clients
            wrlong  zero, pvmcmd
    :wait   rdlong  vmpage, pvmcmd wz
      if_z  jmp     #:wait
            test    vmpage, #int#EXTEND_MASK wz ' test for an extended command
      if_z  jmp     #extend
    would become
      if_z  jmp     #:wait
      if_z  jmp     #extend
    This extended command section sounds like the way to implement ADDITIONAL functions?
    Now function 7 sets the lock, and is called ???? automatically I hope?
    I also noticed the SPI cache has
      int: "cache_interface"
    I found this in load161. Got rid of it.
    OKAY... Getting close:
      THE SOFTWARE.
    CON
      EMPTY_BIT             = 30
      DIRTY_BIT             = 31
    OBJ
    PUB image
      return @init_vm
    DAT
            org   $0
            add     pvmaddr, #4
            add     t1, #4
            add     t1, #4
            rdlong  t2, t1 wz
            add     t1, #4
            rdlong  t2, t1 wz
            mov     index_count, #1
            sub     index_mask, #1
            mov     line_size, #1
            mov     t1, line_size
            sub     t1, #1
            wrlong  t1, par
            jmp     #vmflush
            fit   128
            mov     t1, index_count
            add     :flush, dstinc
            djnz    t1, #:flush
      if_z  jmp     #:wait
            test    vmline, #int#EXTEND_MASK wz ' test for an extended command  added JPH 6-5-12
    if_z  jmp     #extend                                               '       added JPH 6-5-12
            mov     hubaddr, line
            movs    :ld, line
            movd    :st, line
    miss    movd    mtest, line               'modified names to match SPI_Flash_Cache  JPH  6-5-12
            movd    mst, line                 'modified names to match SPI_Flash_Cache  JPH  6-5-12
    lck_bus test    $, #0 wc                ' lock no-op: clear the carry bit JPH  6-5-12
       if_c jmp     #lck_bus                ' added for locking JPH  6-5-12
    mtest   test    0-0, dirty_mask wz       'modified names to match SPI_Flash_Cache  JPH  6-5-12
    nlk_bus nop                             ' added for locking JPH  6-5-12
    mst     mov     0-0, vmline              'modified names to match SPI_Flash_Cache  JPH  6-5-12
    miss_ret ret
                                  'Extended function set? JPH  6-5-12
    extend  mov     vmaddr, vmline
            shr     vmaddr, #8
            shr     vmline, #2
            and     vmline, #7
            add     vmline, #dispatch
    '        mov     dira, spidir            ' not needed since pins should be tri-state by now?
            jmp     vmline
    dispatch
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
    lock_set_handler
            mov     lock_id, vmaddr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
                 'Insert extended function stubs here???
    index_mask      long    0
    index_count     long    0
    ptr             long    0
    'get_values_ret          ret
    load161pasm_ret         ret
                            or      outa,maskP16P20
    rd_cache_line     ' command T          pasmramtohub
                            or      outa,maskP19
    wr_cache_line     ' command S    pasmhubtoram
            fit     496
    I think it's close now? Ready for comments/ Sorry about the repetitive edits but don't want to "CLOG" the thread :D
    Now is function 7 always called on boot?
    edited 2012-06-05 07:33
    No, no, we don't want that!
    Ok, well we have a finalized board design for the ILI chip. I just got an email saying the latest board is on the way which will run both displays. We must be getting close to a hardware that is stable now. So... if this new board works with both your 3.2" and my 2.4" displays, and with dual displays so we can do 480x320, then maybe we can say the hardware is working. And if that is so, well I ordered 10 boards, so maybe we can start sending out some boards and maybe the brilliant boffins here on the GCC thread can try out a board? Happy here to send a few out to those keen to help debug things. I see so many brilliant things here that are just on the verge of being implemented!
    edited 2012-06-05 23:17
    Okay guys, sorry about the false starts. I think I've got the revisions necessary, but I don't know how to test? I've done the "standard" cache driver tests and it passes with flying colors. Here's the FULL file, and I will post the section I changed so you don't need to dig.
      THE SOFTWARE.
    CON
      EMPTY_BIT             = 30
      DIRTY_BIT             = 31
    OBJ
      int: "cache_interface_joemod"
    PUB image
      return @init_vm
    DAT
            org   $0
            add     pvmaddr, #4
            add     t1, #4
            add     t1, #4
            rdlong  t2, t1 wz
            add     t1, #4
            rdlong  t2, t1 wz
            mov     index_count, #1
            sub     index_mask, #1
            mov     line_size, #1
            mov     t1, line_size
            sub     t1, #1
            wrlong  t1, par
            jmp     #vmflush
            fit   128
            mov     t1, index_count
            add     :flush, dstinc
            djnz    t1, #:flush
      if_z  jmp     #:wait
            mov     hubaddr, line
            movs    :ld, line
            movd    :st, line
    miss_ret ret
            shr     vmaddr, #8
            shr     vmline, #2
            and     vmline, #7
            jmp     vmline
    dispatch
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
    lock_set_handler
            mov     lock_id, vmaddr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
    index_mask      long    0
    index_count     long    0
    ptr             long    0
    'get_values_ret          ret
    load161pasm_ret         ret
                            or      outa,maskP16P20
                            or      outa,maskP19
            fit     496
    These are the changed section.
            mov     t1, index_count
            add     :flush, dstinc
            djnz    t1, #:flush
      if_z  jmp     #:wait
            mov     hubaddr, line
            movs    :ld, line
            movd    :st, line
    miss_ret ret
            shr     vmaddr, #8
            shr     vmline, #2
            and     vmline, #7
            jmp     vmline
    dispatch
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
            jmp     #waitcmd
    lock_set_handler
            mov     lock_id, vmaddr
            jmp     #waitcmd
    lock_set
            lockset lock_id wc
    lock_clr
            lockclr lock_id
    Where to go from here? How to test the locking mech? How to implement read-write byte-word?
    *edit*
    I take it the locking mechanism is working since dryPerS dropped to 1348 for XMMC. Need more testing, but I THINK I'm about ready to start porting existing spin to c!
    I'm getting deeper and deeper. I hope you guys aren't sick of me yet!
    One final thought. I've mentioned using other libraries, now I've found something I'm interested in and don't know WHERE to start!
    http://tse3.sourceforge.net/
    This project seems to contain quite a few functions I've been looking for, but I have no idea where to start. Any good wiki's or other helpful C++ docs you guys could point me to?
    edited 2012-06-06 04:33
    Unfortunately, Ted (denominator) wrote the code for the locks so I haven't actually used it. I'm not sure if he checks the forums anymore but maybe he'll reply to your question. I think the idea is that the cache driver doesn't use locks initially but a program wishing to share pins with the cache driver can pass it a lock through the set_lock_handler driver function to tell it to start using that lock when it has to access the shared pins.
  • jazzedjazzed Posts: 11,803
    edited 2012-06-21 11:55
    Ted put all of his information on using locks in this page:
    http://code.google.com/p/propgcc/issues/detail?id=44
