Propeller + C3 Power requirements: 7.512 VDC, 300+ mA with a LIPO ACCU
nomad
hi,
i working on a quadcopter-system with Propeller as microcontrollers.
i want make power requirements with a LIPO-Accu
now my question:
1) it's possible to connect the propeller with a
- LIPO-Accu
~ 12.0 VDC and
- ~ 1.0 Ampere Power Output ?
for instructions and tips I would be grateful
thanks
regards nomad
now my question:
- LIPO-Accu
~ 12.0 VDC and
thanks
regards nomad
thank you for your answer.
on my lipo describe with 11.1volt
i think 12 volts is without loads...
a another lipo is
- Lipo accu V-Maxx 3S1P 11.1 Volt / 1000 mA with BEC (5volt for receiver accu) or
- Lipo accu V-Maxx 2S1P 7.4 Volt / 1000 mA with BEC33
when i buy the lipo i testing the power - output
and if output > 12.volt i make a regulator for 12volt
is this correct?
thanks for hints
regards nomad
in the year 2010 i make this with big lead-Accu with 12 volt and 3700 mA
the propeller are running with no problem
