code issue
I'm having a code problem. Everything works fine until it gets to the case section. It has executed the first case line to play wave file 0(it did so when i waived my hand in front of the ping ..not when it was at its limit of sight ), also it correctly executed the second line to play file 1 when my hand was within a foot, but it wont do either of these things consistently or any of the ones below them at all. The case is supposed to check the value of" range" from ping and play a file if it is in the correct inches range for each file. Does anything look wrong in the case statement? Thanks-mike
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PING_Pin = 16 ' I/O Pin For PING)))
Distlimit = 120 ' In inches
do = 0
clk = 1
di = 2
cs = 3
laudio = 11 ' -1 if unused.
raudio = 10 ' -1 if unused.
volume = 20 ' Default volume.
VAR
long stack[100]
long range
long spinPlayerStack[100]
OBJ
Debug : "FullDuplexSerial"
ping : "ping"
wav : "WAV-Player_DACEngine.spin"
PUB Start
cognew(talker,@stack)
Debug.start(31,30,0,9600)
waitcnt(clkfreq + cnt)
repeat ' Repeat Forever
debug.str(string(1,"PING))) Demo ", 13, 13, "Inches = ", 13, "Centimeters = ", 13))
debug.str(string(2,9,2))
range := ping.Inches(PING_Pin) ' Get Range In Inches
debug.dec(range)
debug.tx(11)
{ debug.str(string(2,14,3))
range := ping.Millimeters(PING_Pin) ' Get Range In Millimeters
debug.dec(range / 10) ' Print Whole Part
debug.tx(".") ' Print Decimal Point
debug.dec(range // 10) ' Print Fractional Part
debug.tx(11) }
pub talker
dira[6]~
wav.FATEngineStart(do, clk, di, cs, -1, -1, -1, -1, -1)
wav.DACEngineStart(laudio, raudio, volume)
waitcnt(clkfreq*4+cnt)
if ina[6]==1
wav.playWAVFile(@file12) '"wanna play a game?" ''change back to 12
wav.playWAVFile(@file11) ''''''''''''want me to guess how far away you are? file 11
feet_guesser
pub feet_guesser
repeat
case range
range >distlimit: wav.playWAVFile(@file0) ''''''''''' come closer, i cant see you file 0
range >0 and range <24 : wav.playWAVFile(@file1) '''''you are 1 foot away
range >12 and range <36 : wav.playWAVFile(@file2) '''you are 2 feet away
range >24 and range <48 : wav.playWAVFile(@file3) '''you are 3 feet away
range >36 and range <60 : wav.playWAVFile(@file4) '''you are 4 feet away
range >48 and range <72 : wav.playWAVFile(@file5) '''you are 5 feet away
range >60 and range <84 : wav.playWAVFile(@file6) '''you are 6 feet away
range >72 and range <96 : wav.playWAVFile(@file7) '''you are 7 feet away
range >84 and range <108 : wav.playWAVFile(@file8) '''you are 8 feet away
Have it print which section of the code you are in at that time and have it print when it is outside of any cases and just in the general loop
I'm not 100% on this, but I believe I also vaguely remember having issues with waitcnt when I coded like this
instead I always write it this way now
waitcnt((clkfreq*4)+cnt)
I also write it as follows
(range >0) and (range <24) : wav.playWAVFile(@file1) '''''you are 1 foot away
I'lll give you an example from your first few conditions.
Edit: This is junk code. See kuroneko's explanation below.
pub feet_guesser repeat case range range >distlimit: wav.playWAVFile(@file0) ''''''''''' come closer, i cant see you file 0 waitcnt(clkfreq*4+cnt) range <24 : wav.playWAVFile(@file1) '''''you are 1 foot away waitcnt(clkfreq*4+cnt) range <36 : wav.playWAVFile(@file2) '''you are 2 feet away waitcnt(clkfreq*4+cnt) range <48 : wav.playWAVFile(@file3) '''you are 3 feet away waitcnt(clkfreq*4+cnt) range <60 : wav.playWAVFile(@file4) '''you are 4 feet awayAs Cluso99 mentioned, you have overlapping ranges. This really doesn't matter much (it just looks bad) since your code and the code I just posted should behave the same.
You could move the first condition to the end and use "other". I think the code would have a more logical flow (to humans reading it) if you started testing for near items and moved the test distance away with each comparison. If you do start with the out of range test, then I'd keep move inward by tesing to see it the range is greater than a certain value.
I agree with turbo's suggestion of adding debug statements. I fill my code with debug statements whenever I'm trying to figure out what it's doing.
PUB null | range dira[16..23]~~ range := 0 case range range < 4: outa[16]~~ other: outa[23]~~ waitpne(0, 0, 0) DATThe case expression is compared against each of the targets (top to bottom). So we have 0 as a case expression, the target is (range < 4) which is -1 (TRUE). This means the first case doesn't match (0 <> -1) and it falls through to other. If you use -1 you'll get a match ...In other words all you have are -1/0 (TRUE/FALSE) target expressions which - I assume - is not what you want.
Use the "Go Advanced" button and then "Manage Attachements". You should then be able to upload files.
If you've never used the serial terminal for problem solving, you are in for a treat as it should really make your life easier if you start to.
Kuroneko is like Hawkeye, he can spot a comparison error from a mile away, I can almost guarantee that it is doing whatever it shouldn't be doing because of what he commented about
There are also debuggers such as
PASD by Ariba
Zero-Footprint debugger by Cluso99 (me) - its a bit complex to setup but can trace spin and pasm code.
jazzed has done a debugger too (sorry, forget the name of it atm)
Hanno has a commercial product (sorry, a real senior moment here - forget what he calls it to)
And there are a couple of emulators as well.
PUB null | range dira[16..23]~~ range := 1 case [COLOR="orange"]range[/COLOR] [COLOR="blue"]range > 0 and range < 24[/COLOR]: outa[16]~~ other: outa[23]~~ waitpne(0, 0, 0) DATrange (CaseExpression) is compared against range > 0 and range < 24 (MatchExpression). So on the left side we have 1, on the right side we have a boolean expression which evaluates to TRUE (1 > 0 and 1 < 24) which is the same as -1. However 1 is not equal -1 which is why the first case isn't selected. IOW for this specific case (range == 1) your case statement looks effectively like this:PUB null | range dira[16..23]~~ range := 1 case [COLOR="orange"]range[/COLOR] [COLOR="blue"]-1[/COLOR]: outa[16]~~ other: outa[23]~~ waitpne(0, 0, 0) DATIf you want a case statement to be executed for the range between 0 and 24 (exclusive) then you should use something like this:PUB null | range dira[16..23]~~ range := 1 case [COLOR="orange"]range[/COLOR] [COLOR="blue"]1..23[/COLOR]: outa[16]~~ ' selected for range within 1 to 23 (inclusive, 0 < range < 24) other: outa[23]~~ waitpne(0, 0, 0) DATThanks for the second attempt. Now it stuck in my brain too.
I always use case the way you just describe but I didn't catch the problem in the original code or my changed version.
Thanks again for helping me us see the light.
