Using Bluetooth With the Propeller?
Ok so one day i saw this article http://gadgetgangster.com/news/56-jeffs-shop/534-bluetooth-howto.html, so the other day i started cracking open blue tooth keys I had laying around. On one of them there are a few very small surface mount pads labeled:
SPI_Clk
SPI_CSB
SPI_MISO
SPI_MOSI
UART_TX
UART_RTS
UART_CTS
UART_RX
Now im wondering if this module will work with my prop, the article says nothing about the chipset used in the bluetooth module. Does the chipset even matter, or does the usb key just know TTL? What I would like to do is make the connections to tx/rx/rts and 3.3v to use the usb module as a wirless programmer, Im not sure how to set up the computer to transmit over the bluetooth adapter and not a COM port though. Im also wondering if I can use the spi pads for wireless communication between the computer and prop, since spi would be faster as long as I wasnt trying to program the propeller. But when using spi, wouldnt I need to know some kind of protocall to communicate with the bluetooth chip?
Also if anyone knows in the GG article I posted it shows header connected to the module and a cable plugging into the prop. I dont understand thats where the usb voltage and data lines are on USB keys but I dont see those on his stick.
SPI_Clk
SPI_CSB
SPI_MISO
SPI_MOSI
UART_TX
UART_RTS
UART_CTS
UART_RX
http://www.ebay.com/itm/1pcs-Wireless-Bluetooth-Transceiver-Module-RS232-TTL-HC-05-/251066012059?pt=LH_DefaultDomain_0&hash=item3a74b3519b
My module is one of these mounted on a breakout to make it easy to get into the Vdd/Vss Tx/Rx lines.
OBC
front with chips
back with uart and spi serial
Im sure it should work, what id like to know is why are all the break out boards on the net like 50 dollars?? Maybe we could just buy these chips and make cheap bluetooth boards for uControllers? I would also like to know how to use the SPI hook ups..
http://www.ebay.com/itm/BT-Board-Serial-4-Pin-Bluetooth-RF-Transceiver-Module-Backplane-RS232-F-Arduino-/261031956317?pt=LH_DefaultDomain_0&hash=item3cc6b78f5d#ht_1574wt_698
We had considered stocking these at Gadget Gangster, but they are plentiful everywhere else from what I can see.
OBC
also do u have any idea how to set spin tool or bst up to program over bt? what id really like is to figure out these chips and make a prop board with wireless programming built in.
OBC
Attached is a picture of the typical open collector transistor circuit.
Also attached is a windows version of the propeller-load program (available for other O/S too).
Please review the Propeller Loader documentation at www.parallax.com/propellergcc
