Scripting language that isn't specific to data types?
Hi,
I've been recently revisiting my old ALICE-to-Propeller project. The main downfall of the project was the fact that, to speed it up, the entire ALICE library had to be sorted. After endless problems with the sorting program, mainly due to the Propeller's speed and numerous stack overflow errors, I gave up on the prospects of having the Propeller chip do the sorting. What would be much easier is to write a PC script to sort it, seeing as PC's are more fit to handle file systems and mass memory movement than a Propeller is. I've only experimented around with script languages before, and coming back to it for this project, I realized something in all of them that caught me up: Specific data types.
In SPIN, when you declare a byte, you are declaring an 8-bit section of the memory that can hold an ASCII character, a decimal value, a hexadecimal value, or a binary value. You can set them up into arrays with a simple bracket notation ( [#] ) and can access the arrays through a loop or directly using variables. This seems to not be the case for most scripting languages. VB script, Python, and Visual Basic (the 3 I have attempted so far) do not allow you to easily switch between data types, meaning you can't easily clear or nullify an array and makes programming difficult for someone not accustomed to it.
My question is, before I spend more time learning a new scripting language, can anyone suggest one that sticks to the SPIN-style way of denoting data types? Any help is appreciated.
Microcontrolled
Microcontrolled
I'm not following your point ? Visual Basic allows arrays, and bytes, and it can type convert mostly as needed ?
Types exist mainly for speed and size reasons. If you care about neither, use Float for everything.
Microcontrollers tend to care very much about size and speed.
Some languages (or even chips) try to reduce the Types, but while that makes the language compiler simpler, the users code often gets larger.
- eg you can do only 32 bit variables, but then have to resort to shift and mask, if you want bytes.
If you really want to be fussy about types why not just use a compiled language like C or Pascal? There are plenty of free compilers around.
EDIT: After think about it for a while, I seem to recall that the ALICE database file uses multiple lines for some entries, so my original suggestion wouldn't work. Do you have a link for the original data file? I'll search on my computer to see if I can find it.
1. Find the Pattern tags
2. Grab the text inside the pattern tags
3. Take the first 7 characters of the pattern and create a new text file with that name.
4. Write the entire category tag's contents (which includes the pattern and template tags) to the text file.
5. Go to the next instance of a pattern tag and repeat this process.
Doing this will allow the Propeller to easily narrow down what text file to search for a query in, rather than having to scan through 14MB of text.
Now you only need to search the index file to find any tags position in the data file which you can then read quickly with a seek command.
Next step is to sort your index file so that when you do the look up on the Prop you can perform a binary search which will be very quick.
Best use a fixed number of bytes for the tag name and file offset fields in the index file. Just zero out any unused space in the name.
A sorted index plus binary search must be quicker than rifling through a mess of little files.
http://en.wikipedia.org/wiki/REXX
There's a lot of text parsing and file handling commands in the language.
Variables are... typeless and really, really fun...
(No arrays, but a compound structure that can be used as Arrays)
I once built a MySQL frontend in REXX that ran in an OS/2 Command window.
(OS/2 version of MySQL came with a REXX library)
Here's a REXX-based XML-parser:
http://rexxxmlparser.sourceforge.net/
- Microcontrolled
EDIT: Dave, I took your advice and looked over the old thread. What I'm doing now is similar to what was discussed. I hope it's as fast as I think it will be.
Perl also has the ability to swallow large strings with ease, so sorting large pieces of memory/files is super simple. It's a bit difficult to remember all it's ins and outs at times, but there's nothing better for doing quick and dirty things like what you're referring to.
Although, it sounds like you got it solved, I figured I'd throw in my vote for perl anyhow.
