Scribbler 2 Level Converters
Mike Green
I know there have been problems with the "hacker's port" level shifters. I assume that a +5V pullup may help force the shifter into input mode. Anybody knows for sure? What would be a minimum value for such a pullup? Any other suggestions? I'm trying to attach a WiFly-RN-XV on an xBee 3.3V/5V adapter board. These use a 74LVC244A for buffering. I'd rather not have to bypass the level shifter.
The there are already 4.7K pull-ups on on the hacker port lines.
Phil posted a link to the level shifter datasheet in this thread (post #30). There was some discussion about the level shifter there as well.
This thread is about trying to us a Ping with a S2.
I strongly dislike the level shifter on the S2. It keeps me from using many devices I would like to use with the robot.
For the Serial Port, I'm using a Parallax USBto232 adapter. I can program the Scribbler, and transmit to the Scribbler, but nothing seems to come back from the Scribbler. I've used a variety of serial drivers including FDS, all at 9600 Baud. I wonder whether this is due to the RS232 interface circuitry "stealing" voltage from DTR for the negative supply.
For the Hacker Port, I'm trying to use the xBee 3.3V/5V adapter plugged into P4 and P5 to run a WiFly adapter. Sending data to the WiFly adapter from the Prop seems to work, but data from the WiFly adapter to the Prop doesn't get through. When I looked at the 3.3V/5V adapter schematic, there's a 1K serial resistor on the output of the 74LVS244A and that would limit the low voltage to the level translator, particularly with the 4.7K pullup. I shorted out the 1K resistor on the DOUT pin to the Hacker Port and that didn't seem to help.
Anyway, I'll appreciate any suggestions. I'm trying to make up a version of FemtoBasic for the Scribbler 2 that uses a WiFi connection for its console, supports most of the S2.spin calls, and stores up to 8 programs in the user area of the EEPROM, but I've got to get the hardware working first.
I'm using a Parallax USBto232 (Rev
Is there something you'd like me to try using my USBto232/S2 to see if I can replicate the problem you're having?
I've seriously thought of removing the level shifter in my S2. However, part of the fun of a ready made robot is the ability to share programs with other robot owners. If I were to liberate my S2's hacker port, the programs I may write using devices connected to the hacker port wouldn't be usable to most S2 owners with their shackled unmodified hacker port.
