Windows 7 / Propeller BOE / FTDI COM Troubles — Parallax Forums
Ken GraceyKen Gracey Posts: 7,419
edited 2012-05-28 08:01 in General Discussion
Hey all,
Today I started teaching the Propeller with our local high school freshmen (yes, they can't even drive) Engineering Technology instructor, Ms. Butterworth. Ms Butterworth is picking it up really fast and at the end of our three 1:20 classes each of the 50 students successfully programmed a Propeller Boe-Bot for making squares, circles, and other dead-reckoning projects. Next week we're moving into repeat statements to create more complex shapes like spirals. What a blessing to tuck the servo management into another cog! Blech. . they can't begin to appreciate not having these hassles, but I'll back them into appreciating them a bit later when I show a BASIC Stamp doing the same thing, or a Propeller USB Oscilloscope displaying the signals. Anyway, these kids will quickly be working with Ping)) sensors and making their robots talk with speech synthesis and WAV file playback. I admit there's a bit of a high-level approach, but for those who need to look under the hood they also have the opportunity to use objects of their own. I am taking all of these experiences and putting them into learn.parallax.com so we can make this a tremendous success. If you believe in your stuff, best way is to put it to the test, or as MattG says "eat your own dog food!".
But I'm having a BIG problem and I don't know the origins of it. Almost intermittently, 4 of our 20 laptops have lost their VCP COM port communication with the Propeller. The same computers were used with the S2 robot (in the adjacent middle school) with no problem. Here's the setup:
- Windows 7
- PropBOE on a Boe-Bot chassis
- Propeller Tool software
- Standard FTDI installation
- Latency timer initially set at 16
When we have a COM lockup I switch cables, switch PropBOEs and isolate the problem with the computer. Perhaps the PropBOE is causing the problem - I'm not certain.
The "fix" has been to reboot the computer and change the COM assignment to another free number. At the same time I've decreased the latency timer to 1. This works, for a while, but not permanently.
Anybody anywhere experience a similar series of events or have a solution for this problem?
  • tobdectobdec Posts: 267
    edited 2012-05-24 13:25
    Ken whats the brand of those laptops? I've had a few of my customers have similar issues with serial to usb FTDI hardware on particular usb rot hub brands. The solution...different FTDI hardware.
    edited 2012-05-24 13:41
    tobdec wrote: »
    ASUS laptops, don't know the exact model number but I will find out. They're fairly new, purchased this year.
    Your solution was different FTDI hardware, not different drivers? Ouch. . .
    edited 2012-05-24 14:25
    Ken this is the driver Win7 installed on my machine for my PropBoe on com 21.
    When I check com port problems in Win7 I start with the FTDI device unplugged then open control panel/device manager and click on "Ports (COM & LPT)" then plug in your FTDI device and note the new USB serial device that appears and click on
    that to open the window for it and click on the driver tab. Mine shows this -
    Driver Provider: FTDI
    Driver Date: 3/18/2011
    Driver version: 2.8.14.0
    Edit: I have an Asus P8P67 Pro motherboard in my machine and it is setup with 32bit Win7 home premium.
    edited 2012-05-24 15:40
    Yup Ken....basically for some reason or another the FTDI hardware just wouldn't work with any driver combo. I even tried it under linux, it seemed as though it was an issue with the usb root hub. These particular customers were using them for a CNC mill. I could run their software and exact drivers on my laptop but their laptop just wouldn't work with it. We ordered new FTDI hardware and it took off like a rocket....now I don't have a definitive answer on this Ken this is just our educated guess at the issue. This situation your are in sounds alot like what we were having with our clients.
    edited 2012-05-24 15:42
    Also Ken something to look at since its only 4 of 20 of your laptops...is it possible windows update screwed something up? Because we KNOW M$ updates NEVER get it wrong....
  • xanaduxanadu Posts: 3,347
    edited 2012-05-24 21:43
    I've been in IT long enough to know that many devices simply fail to work until you change their COM port. The thing about COM ports is if they're not closed properly they don't open. I have never experienced any of these problems with my Prop Plug, but many other devices have done the same on almost every operating system I've used.
    If you really want to trace the root cause of something like that you'd probably need some kind of debugging that isn't available.
    Have you checked the Windows log/system log just in case there's any info there?
    edited 2012-05-25 04:47
    Do you have any USB 3.0 ports on the new PCs? They just don't work with the FTDI drivers.
    edited 2012-05-25 05:11
    I have just installed Windoze 7 Ultimate on an older Acer laptop. Using the same hardware - my propplug equiv ft232rl and my prop board - I have noticed the ocassional times that proptool cannot find the com port. Closing proptool and reopening and the port is again found. Seems there is some issue with Windows 7 and the drivers that does not occur on windoze xp. (proptool v1.30)
    edited 2012-05-25 05:48
    You could always test the COM ports witha LiveCD of PuppyLinux loaded with BST.
    In this way you could identify if it is a OS problem or a BIOS problem. You might need to update the BIOS on some of those laptops.
    edited 2012-05-25 08:05
    mindrobots wrote: »
    Rick - I noticed a sticker on one of the Asus machines that said "USB 3.0" but I didn't think much about it. After all, we've been programming S2 robots quite nicely for several months already. How is it possible the S2 would not cause a crash but the PropBOE does?
    And I wonder if some ports are 3.0 and others are actually 2.0. It seems odd that a machine wouldn't be compatible with older hardware, not just from us but everybody else.
    I haven't had time to research the USB 3.0/FTDI issue and exactly what's on these PCs, but I guess I better check [on my free time]. There's really nothing as deflating to a microcontroller class as being stopped immediately due to PC troubles.
    edited 2012-05-25 08:07
    xanadu wrote: »
    For example, a student who is in the middle of a download and decides to disconnect the USB cable from a PropBOE? Think that could cause the type of problem you're referring to?
    edited 2012-05-25 08:11
    For troubleshooting the problems like this I often pull out some of the SysInternals tools:
    http://technet.microsoft.com/en-us/sysinternals
    In particular you may want to try PortMon
    http://technet.microsoft.com/en-us/sysinternals/bb896644
    The other utilities on the site for monitoring processes, registry, etc are all great tools for troubleshooting.
    Robert
    edited 2012-05-25 08:16
    Ken Gracey wrote: »
    With the contortions I went through with the USB interface on my project, I would definitely say 'yes'. Often times there is a timeout option on the PC side of programming that would allow bailing out (in a graceful way) of a data transfer.
    Unsoundcode might offer some insight to this...
    edited 2012-05-25 08:31
    Ken as far as I know USB 3.0 ports at least at the moment are meant to support storage devices only. I have USB 2.0 and 3.0 ports on my machine and the PropBoe does not work on the 3.0 ports for me.
    Edit: I can take my 3.0 storage device and plug it into a 2.0 port and it will work but slower. I also can't imagine a machine that has 3.0 port(s) to not have a 2.0 port(s), but you never know!
    edited 2012-05-25 08:42
    ratronic wrote: »
    Is it possible that a laptop has both 2.0 and 3.0 USB ports? Perhaps it is - maybe we're just using the wrong port (the 3.0 one). I'll have to check that out as soon as possible.
    As we have been programming both S2s and PropBOEs on these machines they MUST have some USB 2.0 ports if the 3.0 port truly can't work with FTDI drivers.
    edited 2012-05-25 08:48
    davejames wrote: »
    Dave, well, I'm sure that this happens. With 20 students programming at once there's always an assortment of issues going on. But they're starting to figure out how to handle them on their own quite nicely. Just treating the COM port connections with sensitivity could really help here: don't unplug until download is done; close COM ports to PST and other devices when finished, etc.
    Ken Gracey wrote: »
    That may be possible. Do you have the exact model # of the laptop? With that it would help to look up the specs.
    Didn't you have some direct contacts at FTDI? Perhaps you can give them a call and ask them if they have seen any issues with using USB 3.0 ports and if there are if they have any work arounds or new drivers.
    Robert
    edited 2012-05-25 09:43
    Here's the results of my non-scientific study.
    This is using my Toshiba Laptop (purchased last Christmas) which has 1 USB3 and 3 USB2 ports. The USB 3.0 port has a blue plastic tab and a funnier USB squiggle marking it. I have installed the latest FTDI driver from FTDI and it is running Win 7 Home Premium.
    My S2 with Parallax USB to Serial adapter (#28030) works on either port. (It is recognized by F7 in Spin Tool - that's working for now)
    My Prop-BOE works on USB2.0 port but the device driver fails to install on USB3.0 port
    My C3 works on either port
    A random QuickStart works on either port.
    That's the extent of my testing. Based on your experiences, my experiences and the troubles John R has been having with his laptops in Wisconsin, there appears to be some problems with PropBOE on USB3.0 (and I'd have to re-read John's thread but maybe some general issues with PropBOE on some USB ports).
    I never noticed the USB3Prop-BOE issue on my laptop because the USB 3.0 port is on the left and the Prop-BOE, if I'm using it, gets plugged in on the right. I've also been using my C3 mostly with the PropGCC efforts.
    The random nature of the problems could relate to where kids plug things in (like me) or it could be an intermittent issue like the QuickStart and its magic resistor.
    Check for USB3.0 ports and if they exist, try a class with EVERY ONE using the USB2.0 ports.
    I'll keep playing but I think I've run our of USB3.0 ports.....
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2012-05-25 10:03
    Hi Ken, the following two threads are very similar in nature to yours.
    http://forums.parallax.com/showthread.php?139525-FTDI-Driver-problems-with-Windows-7-64-bit
    http://forums.parallax.com/showthread.php?139821-PropBOE-USB-Connection-Not-Working
    It seems the main culprit is the PropBOE, rather it's FTDI or interface circuit when using USB 3.0 or USB 1.1 as other boards tend to work without problem.
    It would be interesting (for me) to see a screen shot of the FTDI EEPROM using USBView.
    Jeff T.
  • Daniel HarrisDaniel Harris Posts: 207
    edited 2012-05-25 10:14
    Ken,
    A quick and dirty way of checking if the port you are using is a USB 3.0 port, look at the physical port itself - USB 3.0 ports will have blue plastic inside of the port where the connections are made. There is a strong possibility, too, that not all ports on the laptop are USB 3.0. My Acer laptop at home has two USB 2.0 ports and a single USB 3.0 port. USB 3.0 is still pretty bleeding edge, so it is something special if a port is 3.0 compatible.
    Daniel
  • KyeKye Posts: 2,200
    edited 2012-05-25 10:22
    USB 3.0 ports have a USB 2.0 port inside of them. There are physically 2 different buses for USB 3.0 and USB 2.0.
    The host controller chip that manages the USB 2.0 and USB 3.0 ports may have diver issues, however.
    edited 2012-05-25 10:56
    Kye wrote: »
    By "physically" you mean the electronics are different, but the connectors are actually the same aside from one being blue (3.0). http://en.wikipedia.org/wiki/USB_3.0#Connectors
    I'll check for blue connectors.
    Thanks Daniel and Kwabenator!
    edited 2012-05-25 13:08
    Ken I can confirm that this list of your products seem to work on USB 3.0 on my machine -
    USB serial adapter Rev B w/ copyright date of 2005 on it driver dated 3/18/2011 Version 2.8.14.0
    USB Stamp Professional Development Board driver dated 7/12/2010 Version 2.8.2.0
    USB Propeller Protoboard Driver dated 3/18/2011 Version 2.8.14.0
    USB Propeller Professional Development Board Driver dated 3/18/2011 Version 2.8.14.0
    Only the PropBoe that does install a driver but the Prop tool can't see when plugged into a 3.0 port
    USB PropBoe driver dated 3/18/2011 Version 2.8.14.0
    edited 2012-05-25 13:22
    Jeff T.
    I second that!
    edited 2012-05-25 13:23
    Well skip that my PropBoe started working on a 3.0 port I will keep it there and see if any problems develop.
    edited 2012-05-25 14:59
    Ken Gracey wrote: »
    Absolutely, anything along those lines. The COM port is tied into an IRQ and an IO address which will become unavailable when there is some 'issue' with it to maintain your operating system stability. If that COM port were still open that one IRQ would rule your system.
    You should make sure that your laptop's COM port has a dedicated IRQ, and not shared with anything else. Usually it will not be shared but the bulk of COM problems are shared IRQs and COM ports stuck open. Some laptops have IR and parallel ports that can be turned off, it's not a bad idea.
    USB 3.0 seems to work fine here with the the Prop IDE, 64bit Win7 Pro. Also for my serial Boe-Bot I've had no problems with my SIIG converter. USB has always been good for backwards compatibility. I primarily do MCSE stuff but I do love hardware. I'm no expert on hardware, but again these COM port issues have been an issue for a long time and it's really hard to point fingers when you have so many variables.
    Also as mentioned earlier the BIOS is a good place to look. Not sure what settings are available in yours but sometimes the system defaults are the best. Hope that helps!
  • jmgjmg Posts: 15,200
    edited 2012-05-25 19:30
    mindrobots wrote: »
    What are the USB devices, on those various boards, and used in what mode(s) ?
    edited 2012-05-25 19:35
    Kye wrote: »
    So that would make a USB 3.0 somewhat less tolerant of USB connector wear, and miss-alignment etc, just due to the shared space giving smaller landing areas ?
    Should be easy to check, and reports USB 3.0 sometimes works hints at something simpler ?
    edited 2012-05-25 19:37
    @jmg - i don't have any of that info. I'll have to do more testing and gather additional info. I was just doing a cursory go/no-go test.
    edited 2012-05-26 00:27
    @jmg
    USB plugs have always had an extra, unused terminal (through USB 2.0). It may be that USB 3.0 has taken over that extra terminal and the only physical difference in sockets are the blue plastic color. This needs a bit of research. As it stands, I don't have any USB 3.0 ports at all. And no USB 3.0 devices.
