DIY PropScope?
Hey guys, I'm looking for some advice on possibly building a propscope equivalent. Now let me note, I'm just trying to put together something for testing and debugging of projects. I have several props laying around and thought this could be a good use for one. It would be nice to have TV out to display waveforms, and dual channel would be very helpful. I don't need GHZ sampling rates or anything. 16-pin logic analyzer functions would be very helpful too but could be a second module if necessary. I am mostly debugging propeller chip circuits. So, with those criteria do you think the propeller is a good choice? What ADC's would you recommend? Any comments? thoughts? suggestions? would be greatly appreciated!
Plan is to use the 8-bit bus to capture data to the free memory of the SSD1963.
When in 640x480x24-bit color VGA output mode, there is about 300kB of free space...
Just need to add an 8-bit buffer to the system so that one can control when 8-bits of scope data are allowed to occupy the bus.
Maybe could use multiple buffers to look at 16 or 24 bits of interleaved channels.
Could also hook to an 8-bit ADC instead of logic...
Anyway, I think I can clock in data at up to about 100 MHz.
Then, can display on DVI, VGA or touchscreen...
But, this is probably a bit more complex than what you want, right?
Mostly I'm just looking for a viable solution to spending a couple hundred for an old scope on ebay.
ADC selection would be a big part of the project IMO. The coding should be fairly simple.
As I said, I'm not looking for anything too complex. I'd like to use as few components as possible to keep cost down. I had thought about using SigmaDelta, but I doubt this would work very well at higher frequencies. *above 5MHZ* 8 bit resolution should be fine. I would like to do 10-20 MHZ sample rate, higher if possible. 100MHZ would be wonderful to have so the more I think about it, the more interested I get Rayman's idea.
As I said, I'm just looking for a tool to help in debugging. All I have for testing are 2 cheap meters *1 analog, 1 digital* and some leds.
I was pleased at how easiy it was to use Hanno's code with these chips.
The datasheet states 8-bits, 20Msps to 100Msps.
Have you seen some of the other Prop oscilloscopes done by forum members? Post #5 of my index lists some of the oscilloscope and logic analyzers I've seen on the forum (under "Propeller Tools").
Thanks for all your help guys!
On the Smorgasboard there is the "IO Dreamkit" by Hanno / Bill Henning / Sapieha / uController.com ( I think thats right)
It uses the ADC08100 for up to 100Msps capture.
Sigma-delta comes essentially for free, so it is well worth 'pushing into the corners' - it's effectively a 80Mhz (100MHz?) D FF sampler, so you get naturally better resolution at lower frequencies where it matters more.
I think you would want a switchable integrator for wide frequency range.
Good triggering is vital, so a DAC to bias a proper Analog trigger would make up for the ADC limitations, and it should work equally well on a digital waveform, and have the desired wide bandwidth. (DC - 100MHz)
I did work out how to get a genuine edge WAIT, on Prop hardware, at a small resource cost - you config a pair of pins as Counter Feedback (aka d FF) and then wait on the 01 or 10 on the pair of pins.
Easier software, and higher fMax / smaller min trigger width.
I also hate losing resolution, so a natural fit would be a time-delta logic analyzer - ie it stores the time of any transition, not a simple memory-fill.
This gives a very wide dynamic range, and has natural compression.
WAITPNE with a wide field, does this naturally, and you can store the time of any edge to ~10ns - the highest 'follow rate' will be a software determined.
Even a COG could store precision samples, of maybe 40 bytes of serial data using a 23b Timestamp and 8b wide captures, or around 400 edges of any data.
24b wraps at ~ 160ms, so a trade off of Time:Chans, would allow 1.34s wrap, for 5 chans, for example.
That would capture a GPS 1pps signal, which is a good test pulse.
If you are looking to learn, design it, build it, test it, push the limit. But if you want the functionality, go to ebay or used test equipment sellers and get what you need. DIY here will be more costly and less tolerant of technique. Also remember that that 100 mhz sample rate may translate into a 50 mhz bandwidth (nyquist), how many samples you can take per time will make a difference in how the captured waveform looks. So if you can get 1Gsps you will have better approximation of the 50 mhz waveform. Look at the specs on new DSOs and notice the relation between their bandwidth and samples per second. Modern DSOs also use other tricks for cleaning up periodic waveforms as well. Sample averaging comes to mind...
I vote ebay. Just avoid the scopes using CCD analog capture channels. These parts are nearly impossible to find. Hang out on the yahoo tek scope group andothers before going to ebay. Ihave one of the affore mentioned scopes and great both channels below 1mhz above, a crystal clear, b sucks ... $225.00. 2247A 4ch nonstorage perfect shape, ultraclean trace $175.00. 2230 analog perfect, digital one channel goofy in chop, perfect in alt, $60.00, easy fix when I find the time. buying these was a learning experience. Not as expensive as it could have been.
There's a tiny little scope for sale on Amazon.com for $78:
http://www.amazon.com/SainSmart-Pocket-Sized-Digital-Oscilloscope-VERSION/dp/B004Y3QHZ6/ref=sr_1_5?s=industrial&ie=UTF8&qid=1337953973&sr=1-5
and there are also
~$300+ Uni-Trend UTD2102CEL, and variants : 100MHz, 7" LCD, 1Gsps, on ebay
as well as the imtemediate
~$175 DSO203 - small handheld LCD 4 channels, 72Mhz sampling, with some analog compromises.
While it is clear on the basis on [Results / One persons time], you will be better to 'just buy a scope', there are things Vanilla Scope miss.
A Good counter and pulse detector is one.
Plus, a lot of uC work is digital, so a Good Logic Analyzer can be a lot of use, and fortunately a Prop finds that easier.
Then we need to keep an eye on Prop 2, and it can push the 'do-able' a little further.
Thanks again guys!
Joe
I have used Propalyzer and that is a great program especially with the QuickStart. I put a header on a second QuickStart with just the data and ground lines and when piggybacked to another QuickStart you can observe all the data lines of the 1st QuickStart with the Propalyzer program. Very cool!
http://code.google.com/p/xoscillo/
The Prop should be able to capture (sparse) Digital edges to 12.5ns/10ns precision, and use compression to store just the edge-times.
For narrow pulse timings, ( Freq < 1MHz) pulses with a preamble (front porch?) > ~ 500ns will have the time stamp precise, and (Assuming overclock to 10ns) slightly narrower 100-500ns pulses would capture the second edge, but not quite at the right time stamp.
Extremely narrow pulses, 10-100ns, could possibly be detected/inferred on single pins, with special software.
- A stored Time value, with no apparent Data change, would be from a very narrow pulse.
A separate COG should be used for Frequency Counter (choose a channel), and perhaps another COG for Time Interval ChA-ChB difference measurements. One can never have too much information
I think a 40MHz(50MHz) reciprocal counter should be do-able, and time intervals to 12.5ns(10ns) precision doable, with a min-time of around 100ns
