Support OS X 10.7 Lion
Hi,
Please support whatever needs to be done to permit Basic Stamp programming using Mac OS X Lion.
Best,
Daniel
Best,
Daniel
Apple dropped support (in Lion) for they way that we compiled and delivered the Stamp Tokenizer library. We know about this and have plans to correct it, but for now the way to get around it is to it through Bootcamp to get it to work. I hope that this helps.
-Nick
As others have mentioned, using Windows XP under VMware or Parallels Desktop works great. It also helps with other Windows-only programs like the PC part of ViewPort and the PropScope. I can also run the Prop Tool even though BST works fine on the Mac.
Yes it would be a very good idea you recompile the stamp tokenuzer ! can you tell us why this is so long to do ? and who is suppose to do this ?
Thank you.
As requested, we are now updating the PBASIC Tokenizer and will recompile it so that it will work under Lion. We plan to release the new tokenizer by mid-January 2012 and Murat (maker of the MacBS2 software) has indicated he will include it in his next release of the software.
Thank you for the suggestions and for your patience.
Mike Logan
UPDATE: We are working on the solution for this and expect it to be available to the public before the end of February 2012.
I am now targeting April 6th as the date to have this finished and released. I know you're all as eager for this to move forward as I am to get it done.
Thank you!
We just received our ordered BOE BOT Robot today, but can't program it since we've only iMAC and Macbook computers in the company.
Any update on the MAC version of the software?
Best regards,
Remy Knecht
3D CONSULT
As of last week, I have put everything else on temporary hold in order to focus on this PBASIC Tokenizer library update, because it just isn't getting done in-between other projects. So I'll be working on this update this week and will update this thread with new details as soon as I have them to share. Thank you for your continued patience.
thanks
The download description for BST on Parallax's website doesn't mention Lion, but that's just the lack of an update to the description once Lion was released. It works fine.
Hi Parallax Fans! I have good news and bad news...
Good News: I've addressed a number of issues (hundreds actually) in the PBASIC Tokenizer source so that it now compiles via XCode 4 on OSx Lion without any errors or warnings.
Bad News: I can't get it to link to my tester code. In fact, I can't get XCode to generate anything other than a ".a" file which I'm not sure is the right thing (we wish to release this as a static or dynamic library to be included in any software that wishes to compile for BASIC Stamp 2 and later... like we've done in the past). I think I may be on the right path now, but to make sure, I would sure appreciate it if a well-versed XCode developer would kindly donate a little of his/her time to speak with me over the phone. I've searched many resources internally and on the net, but am not able to find clear answers, which makes me think I'm asking the wrong questions.
Regardless, I'm still pursuing this effort and wanted you to know.
Well, no one responded, but now I've solved the generation and linking problem I had (I think). But there are many failures while running the test suite on PBASIC code. The type of errors I see are probably related to a set of common issues and I'm going to have to carefully weed them out. There's still a chance it's something I'm overlooking, but proof of that will likely show up as I try to solve each problem. I'll report back the next milestone I reach.
Thanks.
Thanks for working on this and sharing your progress. I am sure that many (hundreds, thousands?) of Mac users are eager to program the Basic Stamps in OS X.
I wasn't trying to offend anyone. I was just stating my situation of not being able to program in pBasic using OSX Lion. I have been a customer of Parallax for many years and have used their products while coaching Science Olympiad. I have not been able to use the Basic Stamp since January after upgrading to Lion. At some point I decided that I must move on...
