Human Detector using Propeller?
I want to start a project that uses a Propeller to function as a "infallible" detector of a Person.
The sensor will be a loop of wire that is 3 foot in diameter. Actually it is a copper wire that has 40 turns
that are taped to make a loop. The idea being the loop is under the floor mat.
So the loop acts as an inductor driven by the Propeller, then by magic the Propeller senses change in the
inductance change caused by a person entering/crossing the loop.
Any ideas? I'll watch this thread for comments, THANKS -Joe
I think what Leon is insinuating by his comment is that raw humans (those who are uncooked and not wearing metal in their shoes) are not likely to alter the inductance of a loop in any detectable way using everyday means of creating magnetic fields, etc.
You might want to look into using Passive Infrared Devices (PIRs). See the following:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/pir/List/0/SortField/4/ProductID/83/Default.aspx
Will that still work even if they're wearing insulated shoes?
Of course, you might amp up that idea and run the thing at 2.45 GHz and 1000 watts. Then use a thermal sensor and a sound sensor and correlate the thermal reading with scream detection.
Just the other day I caused an airport security fence to beep like hell even if I have nothing "odd" on me resulting in a pat down check.
It's not so easy.
Ahh, they threw a coin in there so they could get to know you REAL well!
http://www.youtube.com/watch?v=0H22E_f5h6w
Note: the video loses sync with the audio about half way through but in actuality, the tone could only be heard as I waved my hand over the single loop coil.... The "loop" shorted to itself could be an important factor here because you want the signal to radiate as little as possibly unless it couples into a person standing over it or a hand waiving over it. A single piece of wire would radiate too much like an antenna and defeat the purpose.
Note:
The transmitter loop was about 3/4 inch diameter bare wire loop connected to itself after a single loop. A small tail 1/2 inch was connected directly into P0 and layed over on the SBB
The receiver was about 4 feet away from the transmitter.
Here was my test code.... Note the shortwave receiver that I have only goes up to 30MHz, so that's what I used.
That is more likely to work by capacitance, rather than inductance, so it will depend a lot on what is under the floor.
Since you have a large mat, why not use the cheap-and-cheerful, tried and proven, pressure mat ?
Or an optical beam, also tried and proven...
You could work purely capacitive, with a underlay ground plane to remove floor variances.
See this thread :
http://forums.parallax.com/showthread.php?140096-Propeller-controlled-Capacitive-Load-Cell
Regards
Richard
2, Put out a camera chart, and put a pressure mat in front of it.
I remember a PCB kit that I bought as a kid, it had a sheet of paper with possible things to make.One of them was a man/woman detector, this was a wein bridge with one arm being a thermister at the focal point of a car headlight reflector (back when they were made of metal). This was to be pointed at the lower legs and detect the heat or not. It wouldn't be much good with these "modern" women who wear trousers (or with Scots men ...)
Edit D'OH read the last post
Great! Coffee all over the damn keyboard and monitor.....LOL
Actually, though, when are we going to see a Kinect hooked up to a Prop?
Mickster
Be reasured that the possibilities of more of the Seckshund clan is minimal, now.
