H bridge question
Hello,
I found a .spin driver to controll my h bridge. I have tested the driver and succesfully it works with my h bridge. So here is my problem. Im having a hard time hooking my potentiometer to my proppeller to controller the h bridge threw the hbridge driver. if you can help me, or point me in the right direction. I would apreciate it. This is the driver that I am using.
PWM Motor Driver (H Bridge)
Thank you, Tyrone
Thank you, Tyrone
How do you want to read the value of the potentiometer? You can use the same technique used with the Stamp and its RCTIME statement. This is described in detail in the Basic Stamp Syntax and Reference Manual under the RCTIME statement. You can download this manual from Parallax's Downloads webpage under Basic Stamp Documentation. The Object Exchange has a BS2_Functions object that provides a lot of the functionality of the Stamp using Spin methods including an RCTIME method.
Another technique would be to set up the potentiometer as a voltage divider. Let's say you have a 1K pot. A 10K pot would do as well. You connect one end of the fixed resistor to ground (Vss) and the other end to 3.3V (Vdd). The slider / wiper will have a variable voltage between 0V and 3.3V. You set up the Propeller to act as a sigma-delta ADC (analog to digital converter) as shown in the AN001 application note on the counters.
So, one way or another, you get a number from the setting of the potentiometer. You just have to multiply or divide that number and add or subtract some base value from it to get another number that you can pass to the PWM routine to set the motor speed and direction.
So, this object accepts a value from -100 to +100 as I described with 0 defined as stop. At this point, what's the question?
first of all welcome to the propellerforum!
To really help you it is important that you provide more iformation.
I took a look on link that you posted
your link http : / / forums . parallax . com / objects / 455/
but the objects are not in the forum they are in the obex
your description is much to vague as is would help.
Page four of the OBEX
- in view all objects?
- in view motor control ?
search results for pwm?
search results for h-bridge?
I guess you meant this object http://obex.parallax.com/objects/455/
The sourcecode of the object is very important. How should anybody help you without knowing the sourcecode you are using??
You might have a wrong picture about how electronics in the microcontroller-world works.
In the microcorntroller-world things are NOT standardised as in the PC world. In the PC-world take any kind of USB-device plug it into any kind of PC., laptop netbook, tablet or whatever
and the thing will work (if you or windows got the right driver)
In the microcontroller-world things are not standardised like this. It would be very helpful if you tell us what you want to do in the end. Give us an overview about your project.
If all you want to do is that a potentiometer should determinate the speed of a motor. You wouldn't need the propeller-chip at all. A simple NE555 to drive a MOSFET would be enough.
how fast does the potentiometer or another "inputdevice" change its value. Depending on this speed there are different ways how to interface to the potentiometer.
slow speeds (method RC-time) high-speed method sigma-delta ADC (which does not work reliable for the DIP-40 housing of the propeller-chip) alternative using an external ADC like the MCP3208.
If the potentiometer is just for testing and later you use different ways to setup the motor-rpm do it right now this other way.
So next step is that you provide information about your project what you want to do IN THE END
best regards
Stefan
Yeah it makes more sense to give more detail. The object you have above is the driver i am refering to. What I am trying to do is power an mosfett h bridge with that object. I have tested it and it works fine.The only thing I have done with object is adjust the PWM Freq. and conected my propeler and loaded the object. The motors I am using are 24v 14amp. What I want to do is controll the hbridge with a pot by hand(forward,reverse,and speed). The motors are high powered and are fast.
In the end I want to make a high powered servo. I have cogs and chains to connect to the motor for the torq needed. Also I think the MCP3208 would probably be the best choice. I looked at the data sheet, and from you're suggestion I think I want to go with that. What would be the best way to hook it up to the pot and hbridge? Does it need the propeller?
Thanks Tyrone,
Do you want the pot to use in way a or way b
way A:
middle-position of the pot means motor stands still no rpm
turn pot from middle to the right means motor turns clockwise
turn pot from middle to the left means motor turns counter-clockwise
way B:
You have a switch for motor-direction
switch-position 1: motor turns clockwise
switch-position 2: motor turns counter-clockwise
Pot at left end 0 rpm
Pot at right end max rpm
I'm no expert about control-circuits that give their signals towards H-bridges
From my medium experience I suggest for way A the propeller is one way you can do it.
If somebody who is a more advanced expert about H-bridges than me can chime in. This person
might know a circuit for way A that works without propeller too.
For way b a PWM-circuit using a NE555-chip is enough.
I'm pretty sure lokking at a rotating a DC-motor cw/ccw is not the final purpose of your project.
Just some really wild guessings:
- Are you building a kitchen-machine for mixing cake-ingredients?
- are you building an electric driven car similar to a golf caddy?
- are you building a winch to move loads up and down?
Are you planning to add some more features like displaying motor-turn-direction with LEDs, motor-rpm on a LCD or a 7-segment display etc. ?
which are reasons to use the propeller-chip instead of a "thumb" NE555 H-bridge-control-circuit
best regards
Stefan
The link above should explain why I need a pot with a micro controller and everything else. We are all new to this but eager to learn. Any help or direction anyone can give us will be helpful. I work full time and volunteer with the church. So my study time,and keeping them interested is short.
Tyrone
I knew as soon as you give the global overview about your project that new possabilities can be found.
First of all rc-servos do NOT work with PWM. PWM means a regular pulsetrain with variant on/off-time ratio.
Now standard rc-servos are controled by maybe I can call it repeated single-pulses. Every 20 milliseconds a single pulse
of 1-2 milliseconds is send to the servo-electronic. Anyway the graphic at the link you posted is correct and could be used with a PWM-signal too.
For positioning-purposes I suggest using a magnetic encoder from austria microsystems.
BIG SHOUT @Duane Degn: are you ready to publish your propeller-code about the magnetic encoder?
(Duan is developing code for the AS5055-Chip) thread is here http://forums.parallax.com/showthread.php?138736-Magnetic-Encoder-Project-(AS5055)&highlight=magnetic+encoder
These chips offer a pretty high accuracy 4096 pulses per rotation for a low price (around $5 per piece). Very robust as the encoder works with a magnetic field.
You can turn each normal rc-servo or any other DC-motor into a continous rotating servo which has still the ability to stop at any angle with more precision as any other rc-servo.
for a spider-robot standard rc-servos and a propeller-chip will do.
@OBC: I think your banana-synth is a great starting point for those guys to get a quick result that makes fun and start fiddling with the sound.
Tyrone do your guys like to rap or make music in general?
OBC Can you support them?
http://forums.parallax.com/showthread.php?140128-What-do-you-get-when-you-cross-a-Propeller-with-eight-bananas&highlight=bananas
additional edit:
if you read the word project-management you might think "huh that's a bit oversized for what I'm doing." You may be right. But I want you to watch this video
about a special project management method called SCRUM. http://www.youtube.com/watch?v=XU0llRltyFM
http://www.youtube.com/watch?v=WxiuE-1ujCM&feature=related
SCRUM is completely different to classical project management. My personal opinion is that SCRUM will become the leading method as it offers consequently evolutional
development of projects. It comes from the software-guys but these guys are using it for hardware-developing http://blog.opensourceecology.org/2012/04/extreme-manufacturing/
Anyway there is a good chance that even SCRUM is oversized for what you are doing. But if not and your guys can add the point
"experienced with project-management SCRUM in their applications for a job I guess this is a big plus to choose them.
best regards
Stefan
Thanks for youre help Stefan\
Tyrone and kids
I've updated the AS5055 software thread (in Propeller forum). I should be able to release the software this coming week.
I've been working on several different PCB designs for these encoders. I'm hoping to have several designs that could fit inside a CR servo and be located where the pot had previously been located. A magnet would need to be mounted to the final gear of the servo in order for the encoder to measure the servo's rotation.
In the AS5055 hardware thread (in the general forum), I've posted designs for using these encoders with an on-board microcontroller in order to make them easier to use with Basic Stamps and Arduinos.
@Stephan, Sorry for missing your shout. I hadn't checked this thread yesterday.
I found this OBEX (http://obex.parallax.com/objects/285/ ) and plan to use it as a starting point to make my servo. I understand PWM is not suitable for what I am doing. but instead a timer chip like the (ADCO831) is to read the position of pot.
I also found this (http://obex.parallax.com/objects/455/) to drive my h-bridge. I have tested this driver with my hbridge and motor and it works perfectly with my h-bridge.
I plan to replace the SN754410 (motor driver) object inside(http://obex.parallax.com/objects/285/) with the one I found that works with my hbridge to hopefully achieve my goal. I have ordered a couple of ADC0831 chips and hopefully they will be here by the weekend.
Q1.
Will this work? And if so what other changes will be needed to make it work?
Thanks for your help,
Tyrone and kids
