Developing for Propeller on Linux
Hello, all. Now that I have my bench computer up and running, I'm eager to get to some projects. Because it's an old computer (Celeron 2GHz w/ 768MB RAM - not fantastic, but it's all I've got), I'm running Lubuntu on it, a supposedly light version of Ubuntu. On that front, I have to say: so far, so good. It doesn't constantly peg my CPU at all like Canonical or Mint did. Right now, I'm getting various engineering packages installed, such as Kicad (EDIT: this is now working as well - latest version, too
) and the Arduino environment (works).
I'm looking at the page for BST at the moment, as it seems the best option for developing on the Propeller for Linux, but I was wondering if I have other options I can try out. I have nothing against doing all my development in C and/or assembly. I should also point out that I have one of the old RS232 Propsticks as my platform. This machine has an RS232 port (another reason to use an old computer), so physically connecting them isn't an issue. I just need to make sure I can actually get the bit files to the Prop.
Thank you all for the help!
Right now I've been tinkering with the SimpleIDE C environment on Linux, and I must say it's quite neat. The PropGCC group has done a fantastic job of getting a multi-model compiler up and running, and Jazzed has done a great job on the SimpleIDE.
You can download SIDE and the PropGCC packages and be writing/running C code in minutes.
One of the things the PropGCC group is trying to remedy is the fragmented and scattered landscape that SPIN lives in, without a cohesive library and environment to develop in.
PropGCC already has SD filesystem support built into the libc, simple serial, full duplex serial, and STDIO for files and serial devices. It even has simple printf that sends data to the serial port, like you'd expect.
I've been helping out a little here and there and still getting my hands dirty, but it's an impressive feat thus far.
You should be able to port a lot of Arduino code over easily because it's C, you don't have to rewrite it completely.
I haven't touched a M$ machine in years, and I am too poor to afford a mac.
http://forums.parallax.com/showthread.php?135557-Getting-Started-with-PropGCC
BST
Info:
http://forums.parallaxinc.com/forums/default.aspx?f=25&m=298620
Download:
http://www.fnarfbargle.com/bst/
http://obex.parallax.com/
Good luck! with your project.
Bob
I program in Spin/PASM. I've looked at PropGCC, Catalina, and PropBasic but for a few reasons (one here), I decided that none are suitable.
Anyway, to compile and download I use BSTC with Gedit. I have a Gedit syntax highlighter file (insert URL HERE) that will (mostly) accurately highlight Spin files. I prefer Gedit over BST because BST is missing some of the more important editor features that I like.
To do PASM debugging I use the BMA Debugger: http://forums.parallax.com/showthread.php?115068-BMA-Multi-COG-PASM-Debugger-V1.9-Now-Available&p=829927&viewfull=1#post829927
I also use a custom download script to make the debugging cycle faster. It uses BSTC and picocom (terminal), along with another custom script that I wrote to parse .list files:
Hi Cody. Thanks for your analysis. Just a few notes on some missed perceptions:
1. Propeller-GCC was never intended to produce commented PASM or LMM/ASM code.
2. You got hub access in your COG code because you did not create COG C source suitable for running entirely in a COG - requirements for COG C source are described here http://code.google.com/p/propgcc/wiki/COGModeExperiences
3. In GCC the linker checks for program overflows, not the compiler. There is no such thing as a .fit directive.
My own take? Chip designed Propeller and SPIN/PASM to do certain things well. Many of us are used to that and enjoy it.
However many more newcomers are not at all used to SPIN/PASM and prefer different and more familiar tools.
--Steve
Ah that's a shame - every so often I find BST hangs (but fortunately if you close the window it prompts to save unsaved files so you don't lose anything) - it would be nice if that bug could go away some time - (and cut/copy/paste made to work in the serial window).
It works nicely otherwise and is straightforward to use.
Sadly it's author has gone really quiet for a long while now.
If you are not restricted to SPIN and C, propforth works great on the slowest computer your can find. All you need is a terminal emulator (up to 230400 baud so far). In addition to interactive high level language, it allows direct interactive execution of assembler snippettes from the command line or forth routines.
As for "best", it depends on what your goal is. Propforth is often ideal for getting a lot done quickly, and having fun. This can be useful in the tool chain.
We really need to start beating up that compiler (testing that is) since it will play a very prominent role this year and more.
My goal here is to output as many oscillators from one voice as possible before heading outside the chip, so I won't be emulating a filter or anything like that. Each voice will get it's own output pin and then each go to its own analog filter stage (hence the gates from the MIDI cog) with filter envelopes done in the analog domain, before the voices are mixed together. I'm still debating what to do about output amps, or VCAs, and their envelopes. I'm thinking about doing that inside the Prop, except that would reduce the number of oscillators I could have running per cog. I'll have to play around with that.
Not an easy project, I'm sure, but I do want to point out that I'm only a beginner to the Prop, not to electronics and DSP in general, though I wouldn't call myself advanced, either. Solidly intermediate, I think.
If that's NOT a typo, you may want to get some funding going on KickStarter , too!
Err, umm, yeah... It was a typo, but it does give me some interesting ideas for a synth.
I just fixed it.
