When was Prop Tool 1.3 released? — Parallax Forums
prof_brainoprof_braino Posts: 4,313
edited 2012-05-17 19:08 in Propeller 1
I just notice there's a proptool v1.3. When did this come out? I didn't see these on the "more info" page. I think it was after April 20, as that's the last time I downloaded the prop tool, and the was v1.2 (R2). Aside from changes to the IDE (example "parallax serial terminal toggle" under the run option) is there anything drastic we need to know about?
Experience tells me to be wary: I started with Proptool v1.2. There was an update to the FTDI drivers, which made them incompatible with (my install of) prop tool v1.2. There was the out-of-sequence named prop tool v1.2 (R2) which was incompatible with with my fixed v1.2 with fixed FTDI drivers. The reliable fallback of wiping the hard disk and reinstalling everything from scratch is what finally solved the issues.
So, how does this one work? Can we just install v1.3 over v1.2 (R2), or do we have to uninstall v1.2 (R2) manually first? Do we have to futz with the drivers? Or do we need to use the Big Hammer approach as before and wipe the hard disk and reinstall windows from scratch, and start from there? After years of experience with windows software, "nuke 'em from orbit, its the only way to be sure" makes a LOT of sense to me. Windows install takes 45 minutes, and automatic updates takes about a day or two; diagnosing the root cause for any given windows related issue can take weeks with no progress.
It says "requires IE7" or newer. This looks different from earlier releases. If we removed the massive security risk that is IE, are we out of luck? Previous version of prop tool are listed, but I didn't find any links. Are those still down loadable?
And why can't the dates of the releases be shared, it there a reason omitting dates is desirable?
    edited 2012-05-16 09:08
    My installation folder is dated 12/30/11 so it was before then?
  • LeonLeon Posts: 7,620
    edited 2012-05-16 10:41
    Mine is 23/06/2011, six months earlier.
    edited 2012-05-16 10:46
    Leon wrote: »
    I installed mine the day after you installed yours Leon.
  • Don MDon M Posts: 1,654
    edited 2012-05-16 11:22
    I'm going to take a stab and guess it was around the time they started pushing Parallax Semiconductor...
    edited 2012-05-16 11:26
    The executable in the zip file has a datestamp of June 21, 2011.
    edited 2012-05-16 11:46
    Dave Hein wrote: »
    So I guess I've been in the if it ain't broke don't fix it camp.
    What about requiring IE? Are security problems with IE a non-issue anymore?
    edited 2012-05-16 11:55
    My copy of 1.3 installed nicely right next to version 1.2.7... In other words, no need for Big Hammer..:thumb:
    And I kinda wondered about the lack of "fanfair" over V1.3 myself... I love it, some great improvements.
    -Tommy
    edited 2012-05-16 12:00
    I have IE on my computer but I don't use it. Firefox is my default browser.
    I think I have one machine set up with 1.2.7 and 1.3 (and a copy of Propeller Tool for the S2, maybe). I don't had any issues....ok, I don't have any issues related to the Propeller Tool.
    edited 2012-05-16 12:05
    Depending on whether you're following older bookmark links, version 1.2.7 is still downloadable from a page that makes it look like it's the current version. Version 1.3 has a couple of nice features; the one I like most is a menu command for directly launching PST.
    In order to find v1.3, be sure to drill down using Parallax's store menus, not from a Google link. The first hit for "propeller tool download" points to:
    http://www.parallax.com/tabid/442/Default.aspx
    and that's for v1.2.7.
    -- Gordon
  • yarisboyyarisboy Posts: 245
    edited 2012-05-16 21:25
    I just upgraded to the new version. The old one use to cause a lot of memory access violations and on the 4-core 64 bit win 7 machine it had other problems. With v1.3 most of that got fixed. The memory access violations have gone away on both my win-xp and win-7 machines. Hats off to the writer on 1.3
  • g3cwig3cwi Posts: 262
    edited 2012-05-17 03:03
    That seems to be a problem with a few Parallax resources. I printed out a copy of the Prop Manual before discovering that it was not the current version. Their web resources seem a bit disorganised. Probably just me.
    Cheers
    Richard
    edited 2012-05-17 03:48
    It seems fairly obvious from this page which are the latest versions:
    http://www.parallax.com/tabid/832/Default.aspx
    edited 2012-05-17 06:13
    ...only if you arrive there first!
    73
    Richard
    edited 2012-05-17 06:20
    You get there directly from the home page -> General Info -> Propeller Downloads
    edited 2012-05-17 06:40
    I Googled "Propellor Chip Manual" and came straight up with a page with V1.1 only as a PDF. As I said before it depends where you arrive from as to what you find. Anyone might be forgiven for thinking that was the latest version.
    http://www.parallax.com/Store/Books/Propeller/tabid/171/CategoryID/45/List/0/Level/a/ProductID/377/Default.aspx?SortField=ProductName%2cProductName
    Regards
    Richard
    edited 2012-05-17 06:51
    Leon wrote: »
    Which is great is if you found that page first. Your "fairly obvious" make an assumption that all searches will either start or end at that web page. As shown above, If we Google for prop tool we end up someplace else. While the page you listed is the right resource, it is NOT something that we can be required to "just know". While it is common in business etc to expect employees to "just know" stuff that has not been communicated, it is still not a good idea.
    SOME experience users may know to look there first; ALL new users will NOT know to look there first. Depending on the sequence of exploration folks end up lots of different places. Folks that research everything first may search thru the web site and find that link. Folks that buy a prop based on another project on another website might not. It take a bit before we know what to trust. For example if we search the obex for the program that ships on the prop demo board, we find nothing. Can the search be trusted? Can the OBEX be relied upon? No to both, the prop demo board program exists and is downloadable, but we just have to get lucky to find it.
    Like many things in life, the parallax website is not perfect, and this thread is highlighting a couple possible improvements. These can be examined and possibly addressed, or ignored and costly. Callous dismissal might not be the best course of action.
    edited 2012-05-17 06:58
    I Googled "propellor tool" and guess what:
    Old tool, old documents.
    Cheers
    Richard
  • bsnutbsnut Posts: 521
    edited 2012-05-17 07:44
    Thanks guys for posting this information and I just finished downloading the new Propeller tool.
    edited 2012-05-17 08:47
    Microsoft's way of dealing with changing URLs they no longer want spidered by the search engines is to simply delete them. Eventually they roll off Google's and Bing's radar, but hard links on other people's Web sites now point to an invalid page, with no re-link to the proper page. So, this is something I'm happy Parallax does not do.
    On the other hand, since many of these pages have duplicate content anyway, I would think the best approach is to mark the old ones with a canonical meta tag, which at the least Google respects. Over time, Google (and probably Bing and other SEs) will roll the page over to the new one. The ranking of the page will improve, too, as there won't be as much duplicate content.
    The problem is that the SEs don't know which is the most authoritative page for these landing sites. The canonical tag helps to resolve that.
    http://googlewebmastercentral.blogspot.com/2009/02/specify-your-canonical.html
    There are other ways to eventually flush out these older pages, allowing the newer ones to come up in rank. One method might be a 301 redirect (users no longer see the old page), and a no-index meta tag.
    -- Gordon
    edited 2012-05-17 13:16
    It's also good to go to www.parallaxsemiconductor.com for the latest updates and application notes.
    Jim
    I just installed in the directory PropTool130 and it works fine with both versions. 1.3 hadsome ficxes that I required. It seems to behave better with missing usb port.
