Spin Help
Hello,
I modified Beau's inductive proximity1 code and used the new object for the Prop BOE. My program works great where I find the resonant frequency using the calibrate procedure. In the code below, i put in some debug code using the Propeller Serial Terminal plus object to see what ad values and frequencies were reported. When the values for ad reach 1023, I get several values and the frequency that is chosen is the last of the list. How do I get it to pick the first one that is 1023?
Cenlasoft
Cenlasoft
OBJ system : "Propeller Board of Education" ' PropBOE configuration tools pst : "Parallax Serial Terminal Plus" ' Terminal communication tools adc : "PropBOE ADC" ' A/D Converter on PropBOE time : "Timing" ' Timing convenience methods CON FPin = 7 'Frequency Synthesizer OUTPUT pin New_Freq = 261_000 StartFrequency = 100_000 'Start Frequency to Sweep ... 0 kHz to 500 kHz StopFrequency = 400_000 'Stop Frequency to Sweep ... .0 kHz to 500 kHz SweepStep = 1_000 'Sweep increment used in auto calibration VAR long ad ' Stores A/D conversion Result long Frequency,FMax,ADCMax PUB Go ' Program starts here system.Clock(80_000_000) ' Propeller system clock -> 80 MHz Calibrate repeat Synth(FPin,FMax) ad := adc.In(0) ' Get AD0 analog to digitla conversion time.Pause(50) 'Delay 50ms pst.Home pst.Str(String("ADC Val = ")) pst.Dec(ad) pst.Str(String(" , ")) pst.Dec(FMax) pst.ClearEnd PUB Calibrate FMax~ ADCMax := 1023 repeat Frequency from StartFrequency to StopFrequency step SweepStep 'Sweep frequency range Synth(FPin,Frequency) ad := adc.In(0) waitcnt(cnt+clkfreq>>10) 'Allow ADC to settle if ad => ADCMax ADCMax := ad FMax := Frequency pst.dec(ad) pst.Str(String(", ")) pst.Dec(Frequency) pst.NewLine PUB Synth(Pin, Freq) | s, d, ctr, frq {{ ########################################################################################## ########################################################################################## Section used to Synthesize a specific frequency on an I/O pin: ########################################################################################## ########################################################################################## }} Freq := Freq #> 0 <# 500_000 'limit frequency range ctr := constant(%000100 << 26) '..set NCO mode s := 1 'determine shift frq := fraction(Freq, CLKFREQ, s) 'Compute FRQB value ctr |= Pin 'set PINA to complete CTRB value CTRB := ctr 'Set CTRB FRQB := frq 'Set FRQB DIRA[Pin]~~ 'make pin output PRI fraction(a, b, shift) : f if shift > 0 'if shift, pre-shift a or b left a <<= shift 'to maintain significant bits while if shift < 0 'insuring proper result b <<= -shift repeat 32 'perform long division of a/b f <<= 1 if a => b a -= b f++ a <<= 1
You might get more replies if you attach an archive of your project with your post.
I personally don't have all the objects listed in your program and I didn't want to go hunt them down.
I'm not sure I understand your question.
Do you want the loop to stop as soon as the variable "ad" equals 1023?
You mentioned Beau's code. Is there more information about his code? Do you have a link?
Your right, but all I want is to stop the loop as soon as "ad" equals 1023. This will give me the first resonant frequency value. I have tried to change the "=>" to "==" and then use "Next" in the loop. I need to know where to put the "Next" statement to exit the loop as soon as it hits 1023.
Cenlasoft
You'd use quit to break out of the loop.
You could also use return to stop the method you are presently in and return to the calling method.
