rfid reader code question
I downloaded this code from the parallax website for product downloads. I bought rfid tags and substituted the 10 digit tag i.d. into the eeprom data table (as tag #3 in the code below). I think im missing something because it shows up in the debug terminal as unauthorized, and wont activate pin 3 (the intended door unlock).Any help would be appreciated......I just found another program that solved my first problem. It read the tag and displayed the i.d. which ended up being different from the i.d. stamped on the front of the tag. I substituted the "read i.d." and this program worked. Why is the printed id different from the read id? -mike
' File....... RFID.BS2
' Purpose.... RFID Tag Reader / Simple Security System
' Author..... (c) Parallax, Inc. -- All Rights Reserved
' E-mail..... [EMAIL="support@parallax.com"]support@parallax.com[/EMAIL]
' Started....
' Updated.... 09 SEPT. 2005
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' Reads tags from a Parallax RFID reader and compares to known tags (stored
' in EEPROM table). If tag is found, the program will disable a lock.
' -----[ Revision History ]------------------------------------------------
' -----[ I/O Definitions ]-------------------------------------------------
Enable PIN 0 ' low = reader on
RX PIN 1 ' serial from reader
Spkr PIN 2 ' speaker output
Latch PIN 3 ' lock/latch control
' -----[ Constants ]-------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
TMidi CON 12
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
TMidi CON 60
T38K4 CON 45
#CASE BS2PX
T1200 CON 3313
T2400 CON 1646
T4800 CON 813
T9600 CON 396
T19K2 CON 188
TMidi CON 108
T38K4 CON 84
#ENDSELECT
SevenBit CON $2000
Inverted CON $4000
Open CON $8000
Baud CON T2400
#SELECT $STAMP
#CASE BS2, BS2E
TmAdj CON $100 ' x 1.0 (time adjust)
FrAdj CON $100 ' x 1.0 (freq adjust)
#CASE BS2SX
TmAdj CON $280 ' x 2.5
FrAdj CON $066 ' x 0.4
#CASE BS2P
TmAdj CON $3C5 ' x 3.77
FrAdj CON $044 ' x 0.265
#CASE BS2PE
FrAdj CON $0AA ' x 0.665
#CASE BS2PX
TmAdj CON $607 ' x 6.03
FrAdj CON $2A ' x 0.166
#ENDSELECT
LastTag CON 3
#DEFINE __No_SPRAM = ($STAMP < BS2P) ' does module have SPRAM?
' -----[ Variables ]-------------------------------------------------------
#IF __No_SPRAM #THEN
buf VAR Byte(10) ' RFID bytes buffer
#ELSE
chkChar VAR Byte ' character to test
#ENDIF
tagNum VAR Nib ' from EEPROM table
idx VAR Byte ' tag byte index
char VAR Byte ' character from table
' -----[ EEPROM Data ]-----------------------------------------------------
' valid tags
Tag1 DATA "04129C1A1C"
Tag2 DATA "041402CCD7"
Tag3 DATA "0030781520"
Name0 DATA "Unauthorized", CR, 0
Name1 DATA "Tag 1 (White Card)", CR, 0
Name2 DATA "Tag 2 (Oval)", CR, 0
Name3 DATA "Tag 3 (Small Round)", CR, 0
' -----[ Initialization ]--------------------------------------------------
Reset:
HIGH Enable ' turn of RFID reader
LOW Latch ' lock the door!
' -----[ Program Code ]----------------------------------------------------
Main:
LOW Enable ' activate the reader
SERIN RX, T2400, [WAIT($0A), STR buf\10] ' wait for hdr + ID
#ELSE
SERIN RX, T2400, [WAIT($0A), SPSTR 10]
#ENDIF
HIGH Enable ' deactivate reader
Check_List:
FOR tagNum = 1 TO LastTag ' scan through known tags
FOR idx = 0 TO 9 ' scan bytes in tag
READ (tagNum - 1 * 10 + idx), char ' get tag data from table
IF (char <> buf(idx)) THEN Bad_Char ' compare tag to table
#ELSE
GET idx, chkChar ' read char from SPRAM
IF (char <> chkChar) THEN Bad_Char ' compare to table
#ENDIF
NEXT
GOTO Tag_Found ' all bytes match!
Bad_Char: ' try next tag
NEXT
Bad_Tag:
tagNum = 0
GOSUB Show_Name ' print message
FREQOUT Spkr, 1000 */ TmAdj, 115 */ FrAdj ' groan
PAUSE 1000
GOTO Main
Tag_Found:
GOSUB Show_Name ' print name
HIGH Latch ' remove latch
FREQOUT Spkr, 2000 */ TmAdj, 880 */ FrAdj ' beep
LOW Latch ' restore latch
GOTO Main
END
' -----[ Subroutines ]-----------------------------------------------------
' Prints name associated with RFID tag
Show_Name:
DEBUG DEC tagNum, ": "
LOOKUP tagNum,
[Name0, Name1, Name2, Name3], idx ' point to first character
DO
READ idx, char ' read character from name
IF (char = 0) THEN EXIT ' if 0, we're done
DEBUG char ' otherwise print it
idx = idx + 1 ' point to next character
LOOP
RETURN
