Cutting the cord and going wireless, any suggestions? What do you use?
Hey everyone,
I'm working on a new project where the programming cable is getting in my way and I'd like to program my prop wirelessly. So I was wondering what you use or suggest? (so sad that the parallax wifi was canceled, but such is life) thanks!
Dave
Dave
http://forums.parallax.com/showthread.php?127780-Upload-Prop-programs-via-XBee
I keep hoping to make a similar program for the Nordic modules I use. The Nordic version is still on a back burner though.
http://www.iogear.com/product/GUWH104KIT/
Robert
Robert,
Do you know if the Iogear device will work to program a Prop? I've read a lot of wireless USB devices wont work with the Prop's timing needs when being programmed.
http://forums.parallax.com/showthread.php?139534-Wireless-Programming-of-a-Propeller-chip-(video)
No special PC or Propeller bootloader required. Feel free to ask any questions about it.
No worries. Phase two is getting the Wixels working with the BS2, but I need a few parts to shift 3.3 logic levels to RS232 level so a stamp can consume them. A Parallax order is on the horizon, but I keep getting sidetracked on other projects.
http://uconnect.com.tw/Bluetooth.html
Mickster
We use the spinneret to connect wired to the wireless hub. Then we use an android terminal app to program the prop, the terminal is the mobile part. Its probably kind of backwards from what you want, but doesn't require special hardware beyond a spare wireless router.
Thanks for your suggestions! I'll have to take a look at them a little bit closer...
Thanks!
Yaaa! I can't beleive that I forgot about that. I don't see them on Parallax anymore, does anyone know if I'm just looking in the wrong spots?
I just wanted to give you'll an update. I really appreciated everyone's input and advice. I'm amazed at how integrated/advanced/you obviously know what you're doing.
I ended up opting for the wireless USB router. I tried to find the same one that was originally used and that Parallax was selling, but Parallax has since sold out so I went to my next favorite place, Amazon. They didn't have the "104" version, but they did have the "204" version with the included adapter. That one had a very poor rating and is apparently not compatible with Windows 7, so I kept looking and found several others that were also not compatible with Windows 7....
Dave
It uses 12V @1.5amps
Model: GUWIP204
The link is here:
http://www.amazon.com/gp/product/B0058DN1Q4/ref=oh_details_o01_s00_i00
