Question about connecting to 12 Volt Battery
Hi All,
I m wanting to build a Mars Rover type robot. I have a small motor cycle battery 12 volts that I want to use for a couple of reasons, 1 for powering everything and the other is give the robot some weight for traction. I also have a 12 volt solar panel I plan on using to keep the battery charged. Anyways to get to my question, what pre-cauntions should I use? I have several Basic Stamps on Homework and other boards and although these boards have 5 volt regulators on them I m a bit worried about connecting to a battery that can put out so many amps.
