"#include" files under SPIN
Is there a statement to get CON sections included from an external file? (like an #include directive under C/C++)
Problem is to get all modules of my project to use the same constant definitions in order to minimize chances of different definitions during the several iterations/unit testing of different modules.
The most I could imagine is to build an object for all my definitions and then call them with the # connector, eg:
definition object
calling module(s)
but although it works it not as elegant as an #include and it wastes 3 longs for the null procedure (PropTool will not compile a module with no PUB routines)
Any ideas?
Alex
definition object
'' PIN definition module (pins.spin) '' CON BUZZER = 6 PUB null
calling module(s)
OBJ PIN : "pins" PUB void beep(PIN#BUZZER)
Any ideas?
Alex
There is a "file" directive that can be used to load a DAT section.
If you are looking for use of #include (including data), there is a way of handling that at least (the "file" directive).
The open-source Spin compiler being developed (http://code.google.com/p/open-source-spin-compiler/) may (eventually) have pre-processing capability, and some of the other Spin compilers (like homespun) have some basic pre-processing directives.
1. Use Brad's bst or Mpark's homespun
2. Use Andy's PreSpin '' Compile with PropTool + "PreSpin 0.3" by Andy Schenk www.insonix.ch/propeller
'#include "__MODULE.spin" ' include the common code for OS modules
Warning: Don't forget the comment char ' at the start of the '#include comand!
I just downloaded the latest fix of bst but I couldn't find the #include directive in the manual and I couldn't get it to work by trying
I haven't tried PreSpin but from the description seems to be a one-file solution, does it work across nested objects?
Thanks to everyone for the comments.
Alex
The C pre-processor is perfectly good, well understood by most, well documented, thoroughly debugged, and open-source. It's relatively easy edits to handle comments that aren't //
So how do we use a C preprocessor (+ something else i guess) to compile a spin project?
Ok, granted it's a workable solution.
However a project wide pre-processor does look useful, BST has it along with some interesting features like eliminating unsed routines. Has anyone discovered if it has an equivalent form of #include ?
Alex
{comments may cause some issues, but worst would be to alter the comment before compilation and the compiler would not care}
' comments like BASIC are handled by a altered version I use for BASIC.
point me someplace that I can upload it, and it's yours, its GNU licensed anyway...
