WebSite!!!
hmlittle59
Hello All,
I had to remove redirect. Could not stop the linking together. My bad, did not realize that would happen.
This is the short version. (Redirect).
www.gdvalet.com
Sorry for any confusion.
Need feedback
Howard
www.gdvalet.com
Need feedback
Howard
EDIT: I just went through your site and saw no images at all, even the sample images. I'm can't help troubleshoot it unfortunately.
I get the following message:
[h=1]Not Found[/h] The requested URL /images/flag_usa.gif was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 mod_jk/1.2.32 Server at www.garagedoorvalet.com Port 80
If I were to "GUESS" your images are missing a complete address and should be "www.gdvalet.com/images/flag_usa.gif" etc.
Clear your browser cache and retrying hitting your site. You should see the 404 errors.
Contents of the images folder
http://www.garagedoorvalet.com/images/
Thanks for reply. I checked all pages and they showed up just find. Image/documents/Programs had already been moved to within the same Folder long time ago (that was an issue before). As I was typing this before and went to check my version of FireFox and new update was downloading. Now it's version 12.0 with Windows 7,64bit (ACER machine). I'm in central Texas and my wife is up in Dallas, and she logged on and said all was well. She used our Niece's Laptop also and said all was well. She also used the redirect of (www.gdvalet.com)...the direct link is www.garagedoorvalet.com. I just logged in with my Smart Phone and all is well, (some minor word wrap issue's in places). Must be perfect....will try and resolve, thanks.
need more feed back please. Just did a rebuild of ALL files.
Howard
The diagonal striped background image really doesn't work well with the darker text. The blue text against that background is particularly difficult on the eyes.
The red and yellow colors that are used here and there tend to clash with the rest, you might want to narrow down the color palette and stick with just variations of blue and green along with black/gray/white. Try to keep dark text on light backgrounds and vice-versa. Also, some links show up as blue text and others are white, seems like they should all be the same.
Some of the menu items on the "Resources" tab opened new tabs in Firefox instead of changing what's in the current view like the rest of your tabs/menus do.
Thanks again. Color palette will be changed. New web pages open in same tab, All Resource tabs are set to open in new tabs for reading and printing.
Thanks again
Howard
