How to dump Eskimonika :)
pik33
Sid dumper can only dump about 90 seconds of this tune...
So I did this:..
Got a serial player/serial slave and modified it like this:
then used this "minimalistic player" from obex
to play this.
It plays,
but it have some glitches in it. Edit: now it haven't
Solution was simple: use faster SD card.
So I did this:..
CON
_CLKMODE = xtal1 + pll16x
_XINFREQ = 5_000_000
_SD_DO = 0
_SD_CLK = 1
_SD_DI = 2
_SD_CS = 3
_SD_WP = -1 ' -1 ifnot installed.
_SD_CD = -1 ' -1 ifnot installed.
OBJ
sid : "SIDcog"
serial : "FullDuplexSerial"
fat : "SD3.01_FATEngine.spin"
VAR
byte registers[25]
long s
byte k
PUB main | readyToUpdateRegisters, i, j
sid.start( 10, 11 )
serial.start( 31, 30, 0, 115200 )
fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, _SD_WP, _SD_CD, -1,-1, -1)
fat.mountPartition(0) ' mount the sd card
fat.openFile(fat.newFile(string("e.dmp")), "W")
repeat j from 0 to 95999
readyToUpdateRegisters := false
repeat while not readyToUpdateRegisters
repeat while serial.rx <> 13
if serial.rx == "S" and serial.rx == "D" and serial.rx == "M" and serial.rx == "P"
readyToUpdateRegisters := true
repeat i from 0 to 24
registers[i] := serial.rx
sid.updateRegisters( @registers )
fat.writeData(@registers, 25)
fat.closefile
fat.unmountPartition
dira[16]:=1
outa[16]:=1
repeat
' A minimalistic SID dump player.
' Plays a C64 tune dumped from a .sid file.
CON _clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
SD_PINS = 0
playRate = 200'Hz
rightPin = 10
leftPin = 11
VAR
byte buffer[25]
OBJ
SID : "SIDcog"
SD : "fsrw"
PUB Main
sd.mount(SD_PINS) ' Mount SD card
sid.start(rightPin, leftPin) ' Start the emulated SID in a cog
sd.popen(string("e.dmp"), "r") ' Open tune
'Main loop
repeat
waitcnt(cnt + (clkfreq/playRate)) ' Wait one VBL
sd.pread(@buffer,25) ' Read 25 bytes from SD card
sid.updateRegisters(@buffer) ' Write 25 byte to SIDcog
to play this.
It plays,
I don't have the time right now though!
So, for those who likes this tune, here is headerless raw Eskimonika 8 minutes dump. Because it is headerless, use this "minimalistic player" from OBEX (set playback rate to 200 Hz)
If you want to do a serial sid dump for yourself, you can use code from first post of this topic. This "SD3.01_FATEngine.spin" is renamed (for use with KyeDOS) Kye's FAT16/32 driver from OBEX.
Eskimonika.dmp.raw..zip
http://c64sklastcompo.miina.com/eskimonika.mp3
At first try, she did get hurt badly. SD card I used first time was too slow to write data as fast it comes from serial player. So I thought about rewrite this code to add a circular buffer for RS232 data - or something similar. Then I tried another SD card which was fast enough. Now I can make a "serial dump" of SIDs for any time I want
