soldering iron tip like eroded
ok so i had the weirdest thing happen to my soldering iron tip. here is a pic http://db.tt/CQ5csPBI it started a frw days ago when a little spot wouldnt tin, then i noticed a chunk missing there. after an hour of soldering it went from a chunk to what you see in the pic... i usually clean the tip every few joints with a wet sponge or a brass pad. i also use alot of flux, i got the flux out of a tourch kit. ive never had a tip do this neone know the cause?
I've never had one go that dramatically, but usually the tip gets soft over time as the metal is annealed by the heating and cooling. Then the tip begins to erode and it is time to get a new one.
its all Copper . but in 2 hours of use I have dissolved a entire tip ..
Peter
http://www.finishing.com/379/18.shtml
Or perhaps that tip had an unfortunate manufacturing fault. Might be worth to send an email and picture to Weller- I am guessing they have some sort of customer service or head office contact shown at their website. They might be very interested in your experience which might represent an issue with their internal quality controls, and they also might be able to post you a replacement fairly quickly. Of course they also might just tell you what "you" have done wrong
http://www.instructables.com/id/Soldering-101%3A-Lesson-1%3A-Tin-the-Tip/
I think I agree with the above. Defect.
What kind of flux is it? Rosin or acid? I could see acid flux eat away the iron plating and causing this.
Be stronger than that - DONT USE corrosive (acid) flux on PCBs - they are very strong acids and you should be using goggles and gloves if handling/soldering the stuff. Such acids probably attack the FR4 itself over time let alone the thin copper traces.
Fluxes like that are always washed off, to remove all traces of them, after assembly..
