0 - 4V output range from Prop?
I need to set 2 pins on a Prop to range from 0 - 4V. I recently asked about voltage boosters, and there are several that will get 3v3 up to higher voltages. But I am thinking something simpler. What about an optofet, output 0 - 3v3 from the Prop via PWM, have the FET acting like a variable resistor in a divider with a 5V source, tweak the resistors to produce a range from 0 - 4v. I am curious how you guys would do this.
http://forums.parallax.com/showthread.php?139705-Is-there-a-recommended-external-DAC-that-works-well-with-the-prop&p=1093983&viewfull=1#post1093983
You may need an op amp with rail-to-rail I/O
Do you have a 4v or 5v rail available?
http://search.digikey.com/us/en/products/LTC2633ACTS8-HI12%23TRMPBF/LTC2633ACTS8-HI12%23TRMPBFCT-ND/2615219
http://www.mouser.com/ProductDetail/Microchip-Technology/MCP4922-E-SL/?qs=iRhCjdSJZe7UvhW2OLtctH71DVOMI67vsMvrewCVJFE%3d
EDIT. How convenient, there is an object for this DAC.
FF
FF
Oooopppps, never mind the will there be a ____ question, just saw your edit.
