I need help identifying a component on the Xbee 5v/3v adapter board Rev B
Thanks to my poor soldering skills, I managed to create a solder bridge while soldering the long headers to the Xbee 5v/3v adapter board Rev B.
While fixing the solder bridge, I managed to pop loose a teeny tiny component that sets between the SLP and VREF pins. It's rectangular, somewhat yellowish, and too small for me to solder back onto the board, so I'm hoping I can either live without it or attach a replacement component external to the board. Problem is, I can't match it with the schematic, so I'm clueless as to what it is. I've attached a photo with the component circled. I hope somebody here can tell me what it is.
Many thanks.
Many thanks.
One end of it appears to be tied to a ground plane, so I'm now suspecting it's the C2 capacitor (0.1 uF) seen in the following RevB schematic:
http://www.parallax.com/Portals/0/Downloads/docs/prod/rf/32401-XBee5V_3.3VAdapter_BSchematic.pdf
But that's just a guess at this point. I suppose if it's the C2, then I could place a 0.1 uF cap across Vcc and GND as an external connection.
Anybody know for sure?
Thanks, Leon, but doesn't a small capacitor such as 0.1 uF look like an open circuit to a simple DVM? or are there DVMs that have some kind of capacitor tester thingy?
That said, you might be able to get by with just leaving it off the board. But, if you do, check Vdd with both a scope and voltmeter to make sure it's 3.3V and not oscillating.
Thanks, Phil. I'll try leaving it off the board and see what happens. There's no way I personally could ever get that little booger of a component back into its position. I'm terrible when it comes to these tiny things.
Thanks again.
thanks for your help. I got it working tonight and all seems well.
