New XMM hardware
Dr_Acula
I'd like to test out GCC with the latest touchscreen schematic. I've read this page http://code.google.com/p/propgcc/wiki/PropGccExternalMemory
The cog pasm routines are already written and so hopefully are easy to integrate. I see some clever person has added the Dracblade. This was built on software originally written by Cluso99 that had a very simple interface format between spin and the cog. Send 4 longs:
1) is a single ascii character instruction eg "A" is move a block from hub to ram, "B" is move a block from ram to hub etc ("I" is reserved for "initialize")
2) is the hub address
3) is the external ram address
4) is the number of bytes.
and then wait for a long to change to say the operation is completed.
The touchscreen external ram driver uses the same interface, so whatever is working on the Dracblade ought to be possible to port over to the touchscreen without too many changes.
Can some kind soul please point me in the direction of the code used for the Dracblade external ram driver - I'm hoping I can just make a few changes and post the new pasm code.
Many thanks in advance.
http://propgcc.googlecode.com/hg/loader/spin/dracblade_cache.spin
Hope you can read it. David will probably be around tomorrow if you have questions.
You can use BSTC -C to compile your new cache driver and put it in the c:\propgcc\propeller-loader path. This can be compiled in a SimpleIDE project, but you have to copy the new driver to the aforementioned path. The resulting file will be something like newdriver_cache.dat assuming your source is newdriver_cache.spin
You might consider a temporary config file name like dractouch.cfg or something, I'll use that here for simplicity.
All you have to do to use newdriver_cache.dat is copy the file in c:\propgcc\propeller-loader\dracblade.cfg to some new file such as c:\propgcc\propeller-loader\dractouch.cfg and then change the "cache-driver: dracblade_cache.dat" line in dractouch.cfg to "cache-driver: newdriver_cache.dat".
Once you have a new dractouch.cfg all setup, just click the jigsaw puzzle piece in SimpleIDE to reload the board config types.
Then you can choose dractouch.cfg before clicking the blue right arrow Run Console button F8 or the green right arrow Run button F10.
There is a tool available for testing a newdriver_cache.spin in the repository.
It's here: http://propgcc.googlecode.com/hg/loader/spin/test_cache.spin
You will also need this: http://propgcc.googlecode.com/hg/loader/spin/cache_interface.spin
In test_cache.spin, you can change the "mdev" object from mdev : "eeprom_cache" to mdev : "newdriver_cache".
As for the program to compile and load, well I can't with that tonight or tomorrow. Busy day ahead for me tomorrow.
Hope this helps some.
--Steve
Forum software is horrible these days
Quick question;
BREAD call #BSTART rdloop call #read_memory_byte ' read byte from address into data_8 wrbyte data_8,ptr ' write data_8 to hubaddr ie copy byte to hub add ptr,#1 ' add 1 to hub address add address,#1 ' add 1 to ram address djnz count,#rdloop ' loop until done BREAD_RET retThe touchscreen is reading and writing in words rather than bytes. Simple answer is to shift count >>1. Can I assume that "count" is always an even number?
Also, I'm working through the step-by-step instructions in the Quickstart pdf file and there does not seem to be a "demos" folder. In fact, searching through all the files in the propgcc folder, I have lots of .h files but windows could not find a single .c file nor anything with toggle.* Seems a bit odd.
I'm not sure about why you can't find the demos directory. You can find it in Google Code here: http://code.google.com/p/propgcc/source/browse/#hg%2Fdemos
You'll find a 'toggle' directory under 'demos' with lots of versions of the toggle program.
Ok, what I have is a board in front of me doing all sorts of cool icons and touchscreen things. But the design is about to be superseded by a new design (based on a brilliant idea from jazzed) and that board won't be here till next week. Coding the pasm driver can be done on the board I have but the code will end up being changed very soon. So I think I will wait till the new board arrives. It will need some code to drive the 74HC237 (even though that will only be a few lines of code, I put some debugging leds on the board as I've never used this chip before). On the plus side, I've ordered 10 boards so if they work I've got spares I can give away to anyone wanting to help out.
Which brings up the next step - debugging. On the touchscreen I wrote a slow routine that takes the propeller font from inside the propeller and puts it on the touchscreen. This works without an SD card so you can display a message to say there is no SD card.
But for debugging C right at the very start, I wonder if the serial port might be easier as it can be used to get things working before the display is working.
So...
would anyone have a very simple C program that sends "Hello World" back up the P30/P31 serial lines to a terminal program? And if possible, maybe add a 5 second delay so there is time to do a download and then fire up a terminal program to check the data coming back.
I'm thinking of the way I got the current version working, which was to code every pin logic level change in Spin first, and then port each spin routine over to pasm. So I guess that might be one way to do it in C as well. On the other hand, you might look at the pasm and say - hey that is easy to port over. Maybe it is - it does work rather like a cache. The display startup is still in spin though and so would go to C. And so I guess I'll be asking dumb things like how to do dira and outa in C.
SimpleIDE packages come with a hello demo for P30/31. Other demo programs are also included.
Download here: http://propside.googlecode.com/files/Simple-IDE_0-6-7_setup.zip
User guide is here: https://sites.google.com/site/propellergcc/simpleide/user-s-guide
A: YES!
See attached screenshot. Download the program, F10 and open the terminal.
Well, hats off to the GCC team and congratulations. You guys have made C super easy to use on the propeller.
1) Toggle a led in C
2) Toggle a led by calling a pasm routine from C, and the pasm routine toggles the led
3) Write xmm driver primitives in C to send a byte to xmm, and return a byte
4) Port each routine over to cog pasm code
5) Test running this as actual xmm
I'm up to step 2. Use link from post #7 David Betz for the demos
Scroll to the "toggle" program.
Grab both the C code and the Spin code.
From the way these are separate I surmise that GCC is working with "binary blobs", precompiled in a spin compiler.
This is the spin bit
{{ toggle.spin Propgcc - PASM toggle demo Simple PASM routine to demonstrate interaction between PASM subroutines an PROPGCC main program. The code running in the C address space to talk to exchange data values with PASM code running in a COG. The C program has visibility/access to the mailbox variables as normal C variables. The PASM program has visibility/access to the mailbox variables through the PAR register initialized by the COGNEW and hte RDLONG/RDWORD/RDCHAR and WRLONG/WRWORD/WRCHAR instructions. C program starts the PASM routine via cognew() function, passing strat address and PAR register value. PAR register should be the address of a STATIC data area of LONGs in the C program. For this example: PAR -> static unsigned int delay; static unsigned int pins; static unsigned int loop_cnt; static unsigned int pasm_done; The first three variables are used as input to the PASM routine, the last is used to act as a semaphore back to the C routine. This could have been written as more efficient PASM code but for the examples, I was going for maximum clarity at this point. Copyright (c) 2011, Steve Denson, Rick Post MIT Licensed. Terms of use below. }} pub start(pinptr) cognew(@pasm, pinptr) dat org 0 pasm mov mailbox_ptr,par ' save the pointer to the STATIC parameter (HUB) memory area ' the PAR register is initialized by the cognew() function and is a pointer to ' the first STATIC int declared in the C code as the mailbox ' mailbox_ptr will be changed as the code executes. You can reload ' the initial pointer from PAR if you ever need it to point to ' the start of the mailbox again rdlong waitdelay, mailbox_ptr ' read the wait delay from HUB - it is initialized by the C program ' in C program: delay = CLKFREQ>>1; add mailbox_ptr,#4 ' point to the next LONG in HUB rdlong pins,mailbox_ptr ' the caller's PIN mask as initialized in the C program ' in C program: pins = 0x3fffffff; add mailbox_ptr, #4 ' point to the next LONG (4 bytes each) rdlong loopcounter,mailbox_ptr ' set the loop count as provided by the C program ' in C program: loop_cnt = 20; add mailbox_ptr, #4 ' point to the next LONG which is the semaphore we are setting when done mov dira, pins ' set pins provided by C program to OUTPUT mov nextcnt, waitdelay add nextcnt, cnt ' best to add cnt last :loop xor outa, pins ' toggle pins waitcnt nextcnt, waitdelay ' wait for user specified delay djnz loopcounter,#:loop ' loop until the C provided counter hits zero mov done_flag,#1 ' set the semaphore to one wrlong done_flag, mailbox_ptr ' and save it back into hub memory via the ptr provided by the C program ' in C program: while(!pasm_done) to test for update from PASM jmp #$ ' to infinity and BEYOND!! ' these do not need to be in any particular order or have particular names. There is no relationship between these ' local copies of the C variable except when you create via the PAR register and HUB instructions ' there is no address resolution or linkage done by propgcc or the loader ' mailbox_ptr long 0 ' working ptr into the HUB area - reload from PAR if needed pins long 0 ' local copy of the user's PIN mask waitdelay long 0 ' local copy of the user's delay loopcounter long 0 ' local copy of the user's loop counter done_flag long 0 ' local copy of the semaphore to return to the C program nextcnt long 0 ' local variable to save target value from waitcnt {{ MIT Licensed. +-------------------------------------------------------------------- TERMS OF USE: MIT License +-------------------------------------------------------------------- Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +-------------------------------------------------------------------- }}and this is the C bit
/** * @file toggle.c * This program demonstrates starting a PASM COG * and being able to pass parameters from a C program to a PASM program * and from PASM back to C. * * C to PASM Mailbox example * * WARNING: This code makes all IO pins except 30/31 toggle HIGH/LOW. Check if this is OK * for the board you are using. * * * to use: * from directory containing source * make clean * make * propeller-load -pn -t -r toggle.elf (where n is port #) * * Copyright (c) 2011, Steve Denson, Rick Post * MIT Licensed - terms of use below. */ #include <stdio.h> #include <propeller.h> // propeller specific definitions // the STATIC HUB mailbox for communication to PASM routine // static unsigned int delay; // a pointer to this gets passed to the PASM code as the PAR register static unsigned int pins; static int loop_cnt; static int pasm_done; // C stub function to start the PASM routine // need to be able to provide the entry point to the PASM // and a pointer to the STATIC HUB mailbox // the cognew function in the propeller.c library returns the COG # // int start(unsigned int *pinptr) { // The label binary_toggle_dat_start is automatically placed // on the cog code from toggle.dat by objcopy (see the Makefile). extern unsigned int binary_toggle_dat_start[]; return cognew(&binary_toggle_dat_start, pinptr); } void usleep(int t) { if(t < 10) // very small t values will cause a hang return; // don't bother function delay is likely enough waitcnt((CLKFREQ/1000000)*t+CNT); } // C main function // LMM model void main (int argc, char* argv[]) { printf("hello, world!\n"); // let the lead LMM COG say hello delay = CLKFREQ>>1; // set the delay rate in the STATIC mailbox // this is actually the duty cycle of the blink 0.5 sec on, 0.5 sec off pins = 0x3fFFffff; // set the PIN mask into the STATIC mailbox // light up all pins except 30 & 31 since we don't know board config loop_cnt = 20; // number of time through the loop (20 toggles, 10 on/off cycles) pasm_done = 0; // make sure it's zero since we'll sit and wait on it to change in a few lines printf ("New COG# %d started.\n",start(&delay)); // start a new COG passing a pointer to the STATIC mailbox structure printf ("waiting for semaphore to be set by PASM code.\n"); while (!pasm_done) { usleep(10); // wait for the PASM code to clear the loop counter } printf("goodbyte, world!\n"); while(1); //let the original COG sit and spin } /* +-------------------------------------------------------------------- TERMS OF USE: MIT License +-------------------------------------------------------------------- Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +-------------------------------------------------------------------- */Now in Spin, that would be one program, not two. This sort of thing can be glued into one program - I wrote an IDE for Catalina that put some tags around the pasm/spin bit and then wrote a simple program the split it all up, send the pasm bits off to BST and the C bit off to the C compiler.
So here is a question. If there is a "COG" mode in SimpleIDE and also a "LMM" mode, can you combine both in the same program? Have some C code that goes into a cog, and some C code that is the "main" program. Maybe with some sort of tag around the bit of code that goes into the cogs. Then it becomes one program, not two like "toggle" above?
If that is possible, then the whole program can be pure C and you don't have to learn pasm.
I'd have not said such a thing until recently when heater pointed out his FFT was running almost the same speed compiled from C as it was in native pasm.
Meanwhile - thinking about that some more, I think I'll do things in a different order. I have xmm code already working in a spin program. So I think I'll just grab the pasm bit plus the minimal spin so it compiles and turn that into a binary blob. Then translate the Spin driver into C.
Well, the SimpleIDE might be simple to use but it is very clever behind the scenes. A little drop-down menu in the top right corner with all the hardware boards. The Dracblade works for a XMMC program right out of the box. All those hardware configs had be coded and that must have been a lot of work.
Also the text highlighting in the code. I've written code to do that and it is very complicated. Again, it is all there and working and easy to work out without even reading a help file.
Ok, a new driver.
This is the Dracblade driver using latches to talk to an external ram chip
DAT '' +--------------------------------------------------------------------------+ '' | Dracblade Ram Driver (with grateful acknowlegements to Cluso) | '' +--------------------------------------------------------------------------+ org 0 tbp2_start ' setup the pointers to the hub command interface (saves execution time later ' +-- These instructions are overwritten as variables after start comptr mov comptr, par ' -| hub pointer to command hubptr mov hubptr, par ' | hub pointer to hub address ramptr add hubptr, #4 ' | hub pointer to ram address lenptr mov ramptr, par ' | hub pointer to length errptr add ramptr, #8 ' | hub pointer to error status cmd mov lenptr, par ' | command I/R/W/G/P/Q hubaddr add lenptr, #12 ' | hub address ramaddr mov errptr, par ' | ram address len add errptr, #16 ' | length err nop ' -+ error status returned (=0=false=good) ' Initialise hardware (unlike the triblade, just tristates everything and read/write set the pins) init mov err, #0 ' reset err=false=good mov dira,zero ' tristate the pins done wrlong err, errptr ' status =0=false=good, else error x wrlong zero, comptr ' command =0 (done) ' wait for a command (pause short time to reduce power) pause mov ctr, delay wz ' if =0 no pause if_nz add ctr, cnt if_nz waitcnt ctr, #0 ' wait for a short time (reduces power) rdlong cmd, comptr wz ' command ? if_z jmp #pause ' not yet ' decode command cmp cmd, #"R" wz ' R = read block if_z jmp #rdblock cmp cmd, #"W" wz ' W = write block if_z jmp #wrblock cmp cmd, #"N" wz ' N= led on if_z jmp #led_turn_on cmp cmd, #"F" wz ' F = led off if_z jmp #led_turn_off cmp cmd, #"H" wz ' H sets the high latch if_z jmp #sethighlatch mov err, cmd ' error = cmd (unknown command) jmp #done tristate mov dira,zero ' all inputs to zero jmp #done ' turn led on led_turn_on or HighLatch,ledpin ' set the led pin high jmp #OutputHighLatch ' send this out led_turn_off andn HighLatch,ledpin ' set the led pin low jmp #OutputHighLatch ' send this out ' set high address bytes with command H, pass value in third variable of the DoCmd ' 4 bytes - masks off all but bits 16 to 23 sethighlatch call #ram_open ' gets address value in 'address' shr address,#16 ' shift right by 16 places and address,#$FF ' ensure rest of bits zero mov HighLatch,address ' put value into HighLatch jmp #OutputHighLatch ' and output it '--------------------------------------------------------------------------------------------------------- 'Memory Access Functions rdblock call #ram_open ' get variables from hub variables rdloop call #read_memory_byte ' read byte from address into data_8 wrbyte data_8,hubaddr ' write data_8 to hubaddr ie copy byte to hub add hubaddr,#1 ' add 1 to hub address add address,#1 ' add 1 to ram address djnz len,#rdloop ' loop until done jmp #init ' reinitialise wrblock call #ram_open wrloop rdbyte data_8, hubaddr ' copy byte from hub call #write_memory_byte ' write byte from data_8 to address add hubaddr,#1 ' add 1 to hub address add address,#1 ' add 1 to ram address djnz len,#wrloop ' loop until done jmp #init ' reinitialise ram_open rdlong hubaddr, hubptr ' get hub address rdlong ramaddr, ramptr ' get ram address rdlong len, lenptr ' get length mov err, #5 ' err=5 mov address,ramaddr ' cluso's variable 'ramaddr' to dracblade variable 'address' ram_open_ret ret read_memory_byte call #RamAddress ' sets up the latches with the correct ram address mov dira,LatchDirection2 ' for reads so P0-P7 tristate till do read mov outa,GateHigh ' actually ReadEnable but they are the same andn outa,GateHigh ' set gate low nop ' short delay to stabilise nop mov data_8, ina ' read SRAM and data_8, #$FF ' extract 8 bits or outa,GateHigh ' set the gate high again read_memory_byte_ret ret write_memory_byte call #RamAddress ' sets up the latches with the correct ram address mov outx,data_8 ' get the byte to output and outx, #$FF ' ensure upper bytes=0 or outx,WriteEnable ' or with correct 138 address mov outa,outx ' send it out andn outa,GateHigh ' set gate low nop ' no nop doesn't work, one does, so put in two to be sure nop ' another NOP or outa,GateHigh ' set it high again write_memory_byte_ret ret RamAddress ' sets up the ram latches. Assumes high latch A16-A18 low so only accesses 64k of ram mov dira,LatchDirection ' set up the pins for programming latch chips mov outx,address ' get the address into a temp variable and outx,#$FF ' mask the low byte or outx,LowAddress ' or with 138 low address mov outa,outx ' send it out andn outa,GateHigh ' set gate low ' ?? a NOP or outa,GateHigh ' set it high again ' now repeat for the middle byte mov outx,address ' get the address into a temp variable shr outx,#8 ' shift right by 8 places and outx,#$FF ' mask the low byte or outx,MiddleAddress ' or with 138 middle address mov outa,outx ' send it out andn outa,GateHigh ' set gate low or outa,GateHigh ' set it high again RamAddress_ret ret OutputHighLatch ' sends out HighLatch to the 374 that does A16-19, led and the 4 spare outputs mov dira,latchdirection ' setup active pins 138 and bus mov outa,HighLatch ' send out HighLatch or outa,HighAddress ' or with the high address andn outa,GateHigh ' set gate low or outa,GateHigh ' set the gate high again OutputHighLatch_ret jmp #tristate ' set pins tristate delay long 80 ' waitcnt delay to reduce power (#80 = 1uS approx) ctr long 0 ' used to pause execution (lower power use) & byte counter GateHigh long %00000000_00000000_00000001_00000000 ' HC138 gate high, all others must be low Outx long 0 ' for temp use, same as n in the spin code LatchDirection long %00000000_00000000_00001111_11111111 ' 138 active, gate active and 8 data lines active LatchDirection2 long %00000000_00000000_00001111_00000000 ' for reads so data lines are tristate till the read LowAddress long %00000000_00000000_00000101_00000000 ' low address latch = xxxx010x and gate high xxxxxxx1 MiddleAddress long %00000000_00000000_00000111_00000000 ' middle address latch = xxxx011x and gate high xxxxxxx1 HighAddress long %00000000_00000000_00001001_00000000 ' high address latch = xxxx100x and gate high xxxxxxx1 'ReadEnable long %00000000_00000000_00000001_00000000 ' /RD = xxxx000x and gate high xxxxxxx1 ' commented out as the same as GateHigh WriteEnable long %00000000_00000000_00000011_00000000 ' /WE = xxxx001x and gate high xxxxxxx1 Zero long %00000000_00000000_00000000_00000000 ' for tristating all pins data_8 long %00000000_00000000_00000000_00000000 ' so code compatability with zicog driver address long %00000000_00000000_00000000_00000000 ' address for ram chip ledpin long %00000000_00000000_00000000_00001000 ' to turn on led HighLatch long %00000000_00000000_00000000_00000000 ' static value for the 374 latch that does the led, hA16-A19 and the other 4 outputsThis is the very clever code David Betz wrote http://propgcc.googlecode.com/hg/loader/spin/dracblade_cache.spin
DAT org $0 ' initialization structure offsets ' $0: pointer to a two word mailbox ' $4: pointer to where to store the cache lines in hub ram ' $8: number of bits in the cache line index if non-zero (default is DEFAULT_INDEX_WIDTH) ' $a: number of bits in the cache line offset if non-zero (default is DEFAULT_OFFSET_WIDTH) ' note that $4 must be at least 2^($8+$a) bytes in size ' the cache line mask is returned in $0 init_vm mov t1, par ' get the address of the initialization structure rdlong pvmcmd, t1 ' pvmcmd is a pointer to the virtual address and read/write bit mov pvmaddr, pvmcmd ' pvmaddr is a pointer into the cache line on return add pvmaddr, #4 add t1, #4 rdlong cacheptr, t1 ' cacheptr is the base address in hub ram of the cache add t1, #4 rdlong t2, t1 wz if_nz mov index_width, t2 ' override the index_width default value add t1, #4 rdlong t2, t1 wz if_nz mov offset_width, t2 ' override the offset_width default value mov index_count, #1 shl index_count, index_width mov index_mask, index_count sub index_mask, #1 mov line_size, #1 shl line_size, offset_width mov t1, line_size sub t1, #1 wrlong t1, par jmp #vmflush fillme long 0[128-fillme] ' first 128 cog locations are used for a direct mapped page table fit 128 ' initialize the cache lines vmflush movd :flush, #0 mov t1, index_count :flush mov 0-0, empty_mask add :flush, dstinc djnz t1, #:flush ' start the command loop waitcmd mov dira, #0 ' release the pins for other SPI clients wrlong zero, pvmcmd :wait rdlong vmpage, pvmcmd wz if_z jmp #:wait shr vmpage, offset_width wc ' carry is now one for read and zero for write mov set_dirty_bit, #0 ' make mask to set dirty bit on writes muxnc set_dirty_bit, dirty_mask mov line, vmpage ' get the cache line index and line, index_mask mov hubaddr, line shl hubaddr, offset_width add hubaddr, cacheptr ' get the address of the cache line wrlong hubaddr, pvmaddr ' return the address of the cache line movs :ld, line movd :st, line :ld mov vmcurrent, 0-0 ' get the cache line tag and vmcurrent, tag_mask cmp vmcurrent, vmpage wz ' z set means there was a cache hit if_nz call #miss ' handle a cache miss :st or 0-0, set_dirty_bit ' set the dirty bit on writes jmp #waitcmd ' wait for a new command ' line is the cache line index ' vmcurrent is current page ' vmpage is new page ' hubaddr is the address of the cache line miss movd :test, line movd :st, line :test test 0-0, dirty_mask wz if_z jmp #:rd ' current page is clean, just read new page mov vmaddr, vmcurrent shl vmaddr, offset_width call #BWRITE ' write current page :rd mov vmaddr, vmpage shl vmaddr, offset_width call #BREAD ' read new page :st mov 0-0, vmpage miss_ret ret ' pointers to mailbox entries pvmcmd long 0 ' on call this is the virtual address and read/write bit pvmaddr long 0 ' on return this is the address of the cache line containing the virtual address cacheptr long 0 ' address in hub ram where cache lines are stored vmpage long 0 ' page containing the virtual address vmcurrent long 0 ' current page in selected cache line (same as vmpage on a cache hit) line long 0 ' current cache line index set_dirty_bit long 0 ' DIRTY_BIT set on writes, clear on reads zero long 0 ' zero constant dstinc long 1<<9 ' increment for the destination field of an instruction t1 long 0 ' temporary variable t2 long 0 ' temporary variable tag_mask long !(1<<DIRTY_BIT) ' includes EMPTY_BIT index_width long DEFAULT_INDEX_WIDTH index_mask long 0 index_count long 0 offset_width long DEFAULT_OFFSET_WIDTH line_size long 0 ' line size in longs empty_mask long (1<<EMPTY_BIT) dirty_mask long (1<<DIRTY_BIT) '---------------------------------------------------------------------------------------------------- ' ' BSTART ' ' setup the high order address byte ' '---------------------------------------------------------------------------------------------------- BSTART mov address,vmaddr ' get the high address byte shr address,#16 ' shift right by 16 places and address,#$FF ' ensure rest of bits zero mov HighLatch,address ' put value into HighLatch mov dira,LatchDirection ' setup active pins 138 and bus mov outa,HighLatch ' send out HighLatch or outa,HighAddress ' or with the high address andn outa,GateHigh ' set gate low or outa,GateHigh ' set the gate high again mov ptr, hubaddr ' hubaddr = hub page address mov address, vmaddr mov count, line_size BSTART_RET ret '---------------------------------------------------------------------------------------------------- ' ' BREAD ' ' vmaddr is the virtual memory address to read ' hubaddr is the hub memory address to write ' count is the number of longs to read ' ' trashes count, ptr ' '---------------------------------------------------------------------------------------------------- BREAD call #BSTART rdloop call #read_memory_byte ' read byte from address into data_8 wrbyte data_8,ptr ' write data_8 to hubaddr ie copy byte to hub add ptr,#1 ' add 1 to hub address add address,#1 ' add 1 to ram address djnz count,#rdloop ' loop until done BREAD_RET ret '---------------------------------------------------------------------------------------------------- ' ' BWRITE ' ' vmaddr is the virtual memory address to write ' hubaddr is the hub memory address to read ' count is the number of longs to write ' ' trashes count, ptr, count ' '---------------------------------------------------------------------------------------------------- BWRITE call #BSTART wrloop rdbyte data_8, ptr ' copy byte from hub call #write_memory_byte ' write byte from data_8 to address add ptr,#1 ' add 1 to hub address add address,#1 ' add 1 to ram address djnz count,#wrloop ' loop until done BWRITE_RET ret ' input parameters to BREAD and BWRITE vmaddr long 0 ' virtual address hubaddr long 0 ' hub memory address to read from or write to ' temporaries used by BREAD and BWRITE ptr long 0 count long 0 ''From Dracblade driver for talking to a ram chip via three latches '' Modified code from Cluso's triblade '--------------------------------------------------------------------------------------------------------- 'Memory Access Functions read_memory_byte call #RamAddress ' sets up the latches with the correct ram address mov dira,LatchDirection2 ' for reads so P0-P7 tristate till do read mov outa,GateHigh ' actually ReadEnable but they are the same andn outa,GateHigh ' set gate low nop ' short delay to stabilise nop mov data_8, ina ' read SRAM and data_8, #$FF ' extract 8 bits or outa,GateHigh ' set the gate high again read_memory_byte_ret ret write_memory_byte call #RamAddress ' sets up the latches with the correct ram address mov outx,data_8 ' get the byte to output and outx, #$FF ' ensure upper bytes=0 or outx,WriteEnable ' or with correct 138 address mov outa,outx ' send it out andn outa,GateHigh ' set gate low nop ' no nop doesn't work, one does, so put in two to be sure nop ' another NOP or outa,GateHigh ' set it high again write_memory_byte_ret ret RamAddress ' sets up the ram latches. Assumes high latch A16-A18 low so only accesses 64k of ram mov dira,LatchDirection ' set up the pins for programming latch chips mov outx,address ' get the address into a temp variable and outx,#$FF ' mask the low byte or outx,LowAddress ' or with 138 low address mov outa,outx ' send it out andn outa,GateHigh ' set gate low or outa,GateHigh ' set it high again ' now repeat for the middle byte mov outx,address ' get the address into a temp variable shr outx,#8 ' shift right by 8 places and outx,#$FF ' mask the low byte or outx,MiddleAddress ' or with 138 middle address mov outa,outx ' send it out andn outa,GateHigh ' set gate low or outa,GateHigh ' set it high again RamAddress_ret ret GateHigh long %00000000_00000000_00000001_00000000 ' HC138 gate high, all others must be low - also used as ReadEnable outx long 0 ' for temp use, same as n in the spin code LatchDirection long %00000000_00000000_00001111_11111111 ' 138 active, gate active and 8 data lines active LatchDirection2 long %00000000_00000000_00001111_00000000 ' for reads so data lines are tristate till the read LowAddress long %00000000_00000000_00000101_00000000 ' low address latch = xxxx010x and gate high xxxxxxx1 MiddleAddress long %00000000_00000000_00000111_00000000 ' middle address latch = xxxx011x and gate high xxxxxxx1 HighAddress long %00000000_00000000_00001001_00000000 ' high address latch = xxxx100x and gate high xxxxxxx1 WriteEnable long %00000000_00000000_00000011_00000000 ' /WE = xxxx001x and gate high xxxxxxx1 data_8 long %00000000_00000000_00000000_00000000 ' so code compatability with zicog driver address long %00000000_00000000_00000000_00000000 ' address for ram chip HighLatch long %00000000_00000000_00000000_00000000 ' static value for the 374 latch that does the led, hA16-A19 and the other 4 outputs fit 496and this is the complete driver code for the touchscreen
DAT '' +-----------------------------------------------------------------------------------------------+ '' | Touchblade 161 Ram Driver (with grateful acknowlegements to Cluso and Average Joe) | '' +-----------------------------------------------------------------------------------------------+ org 0 tbp2_start ' setup the pointers to the hub command interface (saves execution time later ' +-- These instructions are overwritten as variables after start comptr mov comptr, par ' -| hub pointer to command hubptr mov hubptr, par ' | hub pointer to hub address ramptr add hubptr, #4 ' | hub pointer to ram address lenptr mov ramptr, par ' | hub pointer to length errptr add ramptr, #8 ' | hub pointer to error status cmd mov lenptr, par ' | command I/R/W/G/P/Q hubaddr add lenptr, #12 ' | hub address ramaddr mov errptr, par ' | ram address len add errptr, #16 ' | length err nop ' -+ error status returned (=0=false=good) ' Initialise hardware tristates everything and read/write set the pins init mov err, #0 ' reset err=false=good mov dira,zero ' tristate the pins with the cog dira done wrlong err, errptr ' status =0=false=good, else error x wrlong zero, comptr ' command =0 (done) ' wait for a command (pause short time to reduce power) pause ' mov ctr, delay wz ' if =0 no pause ' if_nz add ctr, cnt ' if_nz waitcnt ctr, #0 ' wait for a short time (reduces power) rdlong cmd, comptr wz ' command ? if_z jmp #pause ' not yet ' decode command cmp cmd, #"S" wz ' hub to ram if_z jmp #pasmhubtoram cmp cmd, #"T" wz ' ram to hub if_z jmp #pasmramtohub cmp cmd, #"U" wz ' ram to display if_z jmp #pasmramtodisplay cmp cmd, #"V" wz ' hub to display if_z jmp #pasmhubtodisplay cmp cmd, #"E" wz ' convert 3 byte .raw format to 2 byte .ili format - hub to hub if_z jmp #rawtoiliformat cmp cmd, #"F" wz ' convert 3 byte .bmp format BGR to 2 byte ili format (same as E but order reversed) if_z jmp #bmptoiliformat ' cmp cmd, #"W" wz ' lcdwritecom in pasm, not working ' if_z jmp #pasmlcdwritecom cmp cmd, #"X" wz ' merge icon and background based on a mask if_z jmp #mergeicons cmp cmd, #"I" wz ' init if_z jmp #init mov err, cmd ' error = cmd (unknown command) jmp #done ' ----------------- common routines ------------------------------------- get_values rdlong hubaddr, hubptr ' get hub address rdlong ramaddr, ramptr ' get ram address rdlong len, lenptr ' get length mov err, #5 ' err=5 get_values_ret ret ' ??come to this with possibly all pins tristated so need to make P16-P20 high before changing the 138 value set138 shl pasm_n,#25 ' pass n =0 to 7 or dira,maskP0P20P25P27 ' make P25-P27 outputs as well as P0 to P20 andn outa,mask138 ' make these three pins low or outa,pasm_n ' set the 138 pins set138_ret ret load161pasm ' uses ramaddr mov pasm_n,#7 call #set138 ' deselect previous 138 value or dira,maskP0P20 ' %00000000_00011111_11111111_11111111 ' P0-P18 enabled for output plus P19,P20 and outa,maskP18low ' %00001111_11111000_00000000_00000000 ' preserve previous values but set A0-18 low or outa,ramaddr ' output address to 161 chips andn outa,maskP19 ' set pin 19 low = 161 clock mov pasm_n,#1 ' 161 load low call #set138 ' set it low or outa,maskP19 ' set pin 19 high = 161 clock or outa,maskP16P20 ' %00000000_00011111_00000000_00000000 ' set P16-P20 high prior to changing 138 mov pasm_n,#2 ' 161 load high and back to mem transfer call #set138 ' send out load161pasm_ret ret stop jmp #stop ' for debugging ' ------------------ single letter commands ------------------------------------- ' command S pasmhubtoram call #get_values ' get hubaddr,ramaddr,len call #load161pasm ' load the 161 counters with ramaddr hubtoram_loop and outa,maskP16P31 '%11111111_11111111_00000000_00000000 ' clear for output rdword data_16,hubaddr ' get the word from hub and data_16,maskP0P15 ' mask to a word only or outa,data_16 ' send out the byte to P0-P15 andn outa,maskP20 ' set write low add hubaddr,#2 ' increment by 2 bytes = 1 word. Put this here for small delay while writes or outa,maskP20 ' write high andn outa,maskP19 ' clock 161 low or outa,maskP19 ' clock 161 high djnz len,#hubtoram_loop ' loop this many times jmp #init ' tristate pins and listen for commands ' command T pasmramtohub call #get_values ' get hubaddr,ramaddr,len call #load161pasm ' load the 161 counters with ramaddr and dira,maskP16P27 ' %00001111_11111111_00000000_00000000 set P0-P15 as inputs andn outa,maskP16 ' memory /rd low ramtohub_loop mov data_16,ina ' get the data wrword data_16,hubaddr ' move data to hub andn outa,maskP19 ' clock 161 low or outa,maskP19 ' clock 161 high add hubaddr,#2 ' increment the hub address djnz len,#ramtohub_loop or outa,maskP16 ' memory /rd high or dira,maskP0P15 ' %00000000_00000000_11111111_11111111 restore P0-P15as outputs jmp #init ' ' tristate pins and listen for commands ' command U pasmramtodisplay call #get_values ' get hubaddr,ramaddr,len call #load161pasm ' load the 161 counters with ramaddr or outa,maskP18 ' ILI_RS high andn outa,maskP16 ' memory /rd low and dira,maskP16P27 ' disable prop pins %00001111_11111111_00000000_00000000 set P0-P15 as inputs ramtodisplay_loop andn outa,maskP17 ' ILI write low or outa,maskP17 ' ILI write high andn outa,maskP19 ' clock 161 low or outa,maskP19 ' clock 161 high djnz len,#ramtodisplay_loop or outa,maskP16 ' memory /rd high or dira,maskP0P15 ' %00000000_00000000_11111111_11111111 restore P0-P15as outputs jmp #init ' command V pasmhubtodisplay call #get_values ' get hubaddr,ramaddr,len or outa,maskP16P20 ' %00000000_00011111_00000000_00000000 ' set P16-P20 high prior to changing 138 mov pasm_n,#7 call #set138 ' deselect previous 138 value mov pasm_n,#2 ' mem transfer call #set138 ' send out hubtodisplay_loop and outa,maskP16P31 '%11111111_11111111_00000000_00000000 ' clear for output rdword data_16,hubaddr ' get the word from hub and data_16,maskP0P15 ' mask to a word only or outa,data_16 ' send out the byte to P0-P15 andn outa,maskP17 ' ILI write low or outa,maskP17 ' ILI write high add hubaddr,#2 ' one word djnz len,#hubtodisplay_loop jmp #init 'command E RawtoILIformat ' takes a .raw 3 byte RRRRRRRR GGGGGGGG BBBBBBBB and converts to 2 byte RRRRRGGG GGGBBBBB ' pass hubaddr, ramaddr and len ' hubaddr is source location, len is number of pixels ' ramaddr is destination in hub (messy naming) and length is 2/3 of blocklength call #get_values ' gets hubaddress, ramaddress and len (ignores ramaddress) rawloop rdbyte red,hubaddr add hubaddr,#1 rdbyte green,hubaddr add hubaddr,#1 rdbyte blue,hubaddr add hubaddr,#1 call #rgbtoili wrbyte ililow,ramaddr add ramaddr,#1 wrbyte ilihigh,ramaddr add ramaddr,#1 djnz len,#rawloop ' loop until done jmp #init ' set pins to tristate RGBtoILI ' pass red,green, blue, returns ililow and ilihigh shr red,#3 ' 000RRRRR shl red,#3 ' RRRRR000 shr green,#2 ' 00GGGGGG mov ilihigh,green ' ilihigh = 00GGGGGG shr ilihigh,#3 ' ilihigh = 00000GGG or ilihigh,red ' ilihigh = RRRRRGGG and green,#%00000111 ' 00000GGG shl green,#5 ' GGG00000 mov ililow,green ' ililow = GGG00000 shr blue,#3 ' blue = 000BBBBB or ililow,blue ' ililow = GGGBBBBB RGBtoILI_ret ret BMPtoILIformat ' takes a .bmp 3 byte BBBBBBBB GGGGGGGG RRRRRRRR and converts to 2 byte RRRRRGGG GGGBBBBB ' same as E above but BGR instead of RGB ' pass hubaddr, ramaddr and len ' hubaddr is source location, len is number of pixels ' ramaddr is destination in hub (messy naming) and length is 2/3 of blocklength call #get_values ' gets hubaddress, ramaddress and len (ignores ramaddress) bmploop rdbyte blue,hubaddr add hubaddr,#1 rdbyte green,hubaddr add hubaddr,#1 rdbyte red,hubaddr add hubaddr,#1 call #rgbtoili wrbyte ililow,ramaddr add ramaddr,#1 wrbyte ilihigh,ramaddr add ramaddr,#1 djnz len,#bmploop ' loop until done jmp #init ' set pins to tristate ' **** command X ********************* MergeIcons call #get_values ' gets hubaddress, ramaddress,len which are used here as background,icon,mask mov pasm_n,#59 ' do a single row mergeiconsloop rdbyte ililow,len ' reuse ililow, so this is rdword mask,maskcounter and ililow,#%11111 ' mask off low 5 bits and use just the blue as this is a grayscale bitmap rdword red,hubaddr ' reuse red, so actually this is rdword background,backgroundcounter cmp ililow,#%10000 wc ' compare if >128 (ie mid level gray) if_c jmp #mergeskip rdword green,ramaddr ' reuse green, so this is rdword iconpixel, iconpixelcounter wrword green,hubaddr ' if replace, then move icon pixel to the background mergeskip add hubaddr,#2 add ramaddr,#2 add len,#2 djnz pasm_n,#mergeiconsloop ' loop until done jmp #init 'set pins to tristate 'pasmlcdwritecom call #get_values ' use hubaddr as the data ' or dira,maskP0P20 ' set these pins high (pass all pins tristated) ' or outa,maskP0P20 ' set pins high ' mov pasm_n,#2 ' mem transfer ' call #set138 ' set the 138 ' andn outa,maskP18 ' P18 ILIRS low ' and outa,maskP16P31 ' set P0-P15 low ' or outa,hubaddr ' send out the data ' andn outa,maskP17 ' ILI write low ' or outa,maskP17 ' ILI write high ' jmp #init ' set pins to tristate ' variables pasm_n long 0 ' general purpose value data_16 long 0 ' general purpose value ililow long 0 ' low data byte ilihigh long 0 ' high data byte red long 0 ' red, green blue variables green long 0 blue long 0 ' constants Zero long %00000000_00000000_00000000_00000000 ' used in several places mask138 long %00001110_00000000_00000000_00000000 ' mask for the three 138 pins maskP0P20 long %00000000_00011111_11111111_11111111 ' P0-P18 enabled for output plus P19,P20 maskP18low long %00001111_11111000_00000000_00000000 ' P0-P18 low maskP16 long %00000000_00000001_00000000_00000000 ' pin 16 maskP17 long %00000000_00000010_00000000_00000000 ' pin 17 maskP18 long %00000000_00000100_00000000_00000000 ' pin 18 maskP19 long %00000000_00001000_00000000_00000000 ' pin 19 maskP20 long %00000000_00010000_00000000_00000000 ' pin 20 maskP16P31 long %11111111_11111111_00000000_00000000 ' pin 16 to pin 31 maskP0P20P25P27 long %00001110_00011111_11111111_11111111 ' enable all pins as outputs except SD pins maskP0P15 long %00000000_00000000_11111111_11111111 ' for masking words maskP16P20 long %00000000_00011111_00000000_00000000 maskP16P27 long %00001111_11111111_00000000_00000000 fit 496I guess the first thing to point out is there are a lot of extra functions in that code that can be ignored. At the core are just two routines - move a block of data from hub to ram, and move a block of data from ram to hub.
In every routine there is one common call, which collects the variables from the calling program
and just to cause myself and others confusion, in the new code this routine has changed names to
It does the same thing though which is this
get_values rdlong hubaddr, hubptr ' get hub address rdlong ramaddr, ramptr ' get ram address rdlong len, lenptr ' get length mov err, #5 ' err=5 get_values_ret retNext thing is a startup routine. David Betz calls this BSTART
For the dracblade this sets the high latch with address A16-A18.
On the touchscreen, the equivalent code is
which loads up the 161 counters with the starting address.
I'll just note here that in the middle of David's BSTART routine there are some cache lines of code eg
and a couple more at the end. So those will need to be replicated in the load161pasm driver code.
So once that is done, I think the aim is to replace this read loop
BREAD call #BSTART rdloop call #read_memory_byte ' read byte from address into data_8 wrbyte data_8,ptr ' write data_8 to hubaddr ie copy byte to hub add ptr,#1 ' add 1 to hub address add address,#1 ' add 1 to ram address djnz count,#rdloop ' loop until done BREAD_RET retwith this code
pasmhubtoram call #get_values ' get hubaddr,ramaddr,len call #load161pasm ' load the 161 counters with ramaddr hubtoram_loop and outa,maskP16P31 '%11111111_11111111_00000000_00000000 ' clear for output rdword data_16,hubaddr ' get the word from hub and data_16,maskP0P15 ' mask to a word only or outa,data_16 ' send out the byte to P0-P15 andn outa,maskP20 ' set write low add hubaddr,#2 ' increment by 2 bytes = 1 word. Put this here for small delay while writes or outa,maskP20 ' write high andn outa,maskP19 ' clock 161 low or outa,maskP19 ' clock 161 high djnz len,#hubtoram_loop ' loop this many times jmp #init ' tristate pins and listen for commandsA couple of things to note there. First, all my routines finish with a jmp #init. All David's routine finish with a ret. Whatever happens, ultimately the cog routine must end by tristating all the propeller pins, ie
init mov err, #0 ' reset err=false=good mov dira,zero ' tristate the pinsAnd the other thing to note is that there are two ram chips so it is reading in a word at a time, not a byte at a time. So hubaddr etc are incremented by 2 rather than by 1 each loop. So somewhere along the line, len will need to be divided by 2 for cache access (but not for access from within C code).
I suppose we have to work out what this board should be called. The easy answer might be a Touchblade, but I don't want to monopolise the "touch" part as I am sure many other touchscreens will end up supported by GCC.
So I think this encapsulates all the code and bits that need to change.
A general question first. The ILI driver code does multiple things in one cog, because each routine is small so lots can be fitted into a cog.
Is it possible to "share" the cache code and the display driver code in one cog?
If so, how do we send commands like Cluso99's single letter commands, and also send a cache command?
OR (and probably easier), split it up and have the cache code run in one cog, and do all the video driver code in another cog.
If we go for option #2, then the code becomes much simpler. Just ram to hub and hub to ram. I might start with that first and then think about combining cogs (to save a cog) later.
Yes. The SD cache driver does just that. It supports the XMM kernels by handling code-memory read cache misses, and it also handles generic block read/write commands for the C library's SD file system interface.
The trick is found in lib/drivers/load_sd_driver.c/file_io.c - in that code, you'll notice code similar to this:
#ifndef __PROPELLER_LMM__ extern uint16_t _xmm_mbox_p; ... sd_mbox = (uint32_t *)(uint32_t)_xmm_mbox_p; #endif static uint32_t __attribute__((section(".hubtext"))) do_cmd(uint32_t cmd) { sd_mbox[0] = cmd; while (sd_mbox[0]); return sd_mbox[1]; }The C library uses this code to send SD sector commands to the underlying cache driver. These are the extended commands that David mentioned. Check out the full source at http://code.google.com/p/propgcc/source/browse/lib/drivers/file_io.c. You might also want to check out the SD cache driver at http://code.google.com/p/propgcc/source/browse/loader/spin/sd_cache.spin.
Note that this code also supports using a separate driver that does just the sector read/writes needed by the library (your "option #2"). This works when you need SD card access in LMM mode and also when you need SD card access and you're using a different caching mechanism (most likely because all the other caching mechanisms are faster than the SD card cache). In these cases, the split driver is necessary because there is no SD cache driver!
To see this, check out http://code.google.com/p/propgcc/source/browse/lib/drivers/sd_driver.s and notice how similar it is to the aforementioned SD cache driver - just the cache code is missing. This file is loaded manually by the library in http://code.google.com/p/propgcc/source/browse/lib/drivers/load_sd_driver.c. (BTW, the sd_driver.spin driver in loader/spin looks almost 100% identical to this driver - but this driver is not used by the C library, it is solely used by the loader.)
Also note that it works 100% fine when both the SD cache driver and the SD library are loaded at the same time (again, your "option #2"). This wastes a cog, but it does work.
Speaking of SD cards, I see there is an option in the dropdown menu "Dracblade-SDXMMC". What does that do?
And are there any xmm models out there where the program is stored on an SD card? Sounds a bit crazy, but with caching, it ought to be no slower than storing a program in serial sram or serial flash.
In SimpleIDE version 0-6-7 the -SDXMMC and -SDLOAD board types don't work. I have fix and will post later today.
The user's guide explains these, but for convenience ....
Program->Run (F10) and Program->Run Console (F8) buttons:
Dracblade-SDLOAD should put your program on SDCard and load it to SRAM and run.
Program->Burn (F11) button:
The AUTORUN.PEX program can be replaced by copying it to SDcard - then you reset the board to run it.
Program->Build (F9) button:
The a.pex file can be copied to SDcard as AUTORUN.PEX for booting after burning the EEPROM.
Tools->Send File to Target SDCard:
By default in XMM modes it will create a new AUTORUN.PEX program.
You can choose to send that or any file serially to the target SDCard.
I often use it to just copy AUTORUN.PEX to the SDCard using the filesystem.
Prof Braino suggested something similar recently too. Thinking of the way a touchscreen OS might work, you have a "main" program that waits for the user to touch a key. Then it loads up an operation, eg a calculator, or a picture viewer, and that would need some cache changes. But while a calculator is running, no cache updates would be needed as it would all fit in a few kilobytes. So maybe SD cache is a "generic" option for many boards?
If so, could one think about a SD cache driver that worked on the dracblade by defining pins 12,13,14,15 and worked on the various demoboards by devining pins 0,1,2,3 and worked on the Touch161 board by defining pins 24,25,26,27.
Maybe you already have this for the demoboards?
Re the 512 byte sector size, all my programs seem to end up with an array "byte sdbuffer[512]" so if you had that and you read in 512 bytes and the next cache read request happened to be already in the buffer, could you detect that and not have to read the sd card again?
Thanks++
If yo have a generic SD XMM version then this might end up a super simple solution for both myself and for others with different boards. Just take the board I have and change the pin numbers. (see post #22. The order of pins on the touch161 is the same order as the dracblade. I'm not sure about gadget ganster boards though).
I've designed boards with multiplexed pins for SD cards but in the end it is simpler to use existing code and just devote 4 propeller pins to SD cards. Which means that a solution for the dracblade will work for the gadget ganster board and the touch161 board. Just change the pin numbers.
This could open up large C programs for a whole lot of people who have boards with SD cards.
# [propboe] # IDE:SDXMMC clkfreq: 80000000 clkmode: XTAL1+PLL16X baudrate: 115200 rxpin: 31 txpin: 30 cache-driver: eeprom_cache.dat cache-size: 8K cache-param1: 0 cache-param2: 0 eeprom-first: TRUE sd-driver: sd_driver.dat sdspi-do: 22 sdspi-clk: 23 sdspi-di: 24 sdspi-cs: 25I'm really excited about the whole "cache and run from an SD card" concept - it has so many possibilities.
Dr. Acula:
I have adding both a full-size- and a micro-SD to the demo board and it works fine. Just like David said, all you have to do is provide the appropriate loader config file in the propeller-load directory.
To convert an existing config to allow it to be used with SD caching:
1) Add the following parameters - these use the pins I used for my demo board:
sdspi-do: 4
sdspi-clk: 5
sdspi-di: 6
sdspi-cs: 7
Note that there are 4 additional sdspi- parameters that allow you to using address multiplexing on the SPI bus - check the code or ask for an explanation if you want to use them.
2) If you're going to use the IDE, add a line near the top like this:
# IDE:SDXMMC
Note that you do not have to include the "sd-driver: sd_driver.dat" line unless your board provides some caching mechanism and you want to run your program using the alternate SD card execution method (the sd-loader method that reads your entire program and tosses it to the cache before starting).
- Ted
I tired doing that but have run into some problems.
1) Change the file "propboe.cfg" so the pins are correct for my sd card. (same order, just add 2 to each number)
corrected file below
# [propboe] # IDE:SDXMMC clkfreq: 80000000 clkmode: XTAL1+PLL16X baudrate: 115200 rxpin: 31 txpin: 30 cache-driver: eeprom_cache.dat cache-size: 8K cache-param1: 0 cache-param2: 0 eeprom-first: TRUE sd-driver: sd_driver.dat sdspi-do: 24 sdspi-clk: 25 sdspi-di: 26 sdspi-cs: 27Now compile a program using simpleIDE. PROPBOE in the dropdown menu at the top. I presume that is right. Memory model is XMMC.
I can't copy and paste the build dialog but it says that it verified sending the data to ram, and then verified sending it to flash.
I did a program to eeprom. However, no file has appeared on the SD card. The program does run though so it appears as if it is in eeprom, not on the SD card.
I tried sending it to PROPBOE-SDXMMC but it says it can't find the board configuration.
Any advice here would be most appreciated!
PROPBOE-SDXMMC must be selected for the IDE to use the SDXMMC mode.
As I mentioned though, version 0-6-7 has a bug regarding this board type.
Please read this message: http://forums.parallax.com/showthread.php?137928-PropGCC-SimpleIDE&p=1094377&viewfull=1#post1094377
