TCS 3200-DB Color Sensor Module
I'm using Parallax DB Expander to interface the TCS3200 color sensor module on the propeller demoboard.
I fixed the sensor module to the db expander but the leds are not glowing when I gave +5v from the demoboard to the +5v of the db expander and GND of demo board to that of DB Expander.
Please help me with all these basic connections.I already got the code.
{ This is the example code for the TAOSDriver. Pins are connected as follows: 0 = PinC = OUT 1 = PinD = LED 2 = PinE = S2 3 = PinF = S3 The method calls are as follows: taos.getClear(PIN) taos.getRed(PIN) taos.getBlue(PIN) taos.getGreen(PIN) Where PIN is Pin 0 (OUT) When running this code, open the Parallax Serial Terminal and set the Buad to 115200. You should see simillar: Clear = 125 Red = 131 Blue = 512 Green = 142 } CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ taos : "TAOSDriver" pst : "Parallax Serial Terminal" PUB main pst.start(115200) repeat pst.Clear 'Clear screen pst.str(string("Clear:")) 'Clear sensor readings. pst.dec(taos.getClear(0)) pst.NewLine pst.str(string("Red:")) 'Red sensor readings. pst.dec(taos.getRed(0)) pst.NewLine pst.str(string("Blue:")) 'Blue sensor readings. pst.dec(taos.getBlue(0)) pst.NewLine pst.str(string("Green:")) 'Green sensor readings. pst.dec(taos.getGreen(0)) pst.NewLine waitcnt(clkfreq/10 + cnt)The values it is displaying,(though they are varying continuously) is;Blue:1416
Red:876
Green:1157.
I am not able to understand what these values indicate.
