EDE1144 Resonater center lead - + or - BOTH ok?
xanatos
While I have apparently verified that it is OK to use either Vdd or Vss on the center lead of the 4mHz resonator I am using with my EDE1144 keyboard encoder chip, before I commit this to PC Board immortalization, I wanted to check with the folks on here to be SURE there is no issue with using Vdd instead of Vss for the center lead on the resonator. Yes, it is working on my breadboard setup... but I never trust things until I have multiple verifications... :-)
Thanks for the info,
Dave
Dave
Dave
That said, it's always a good idea to have a bypass cap nearby to guarantee a localized low impedance AC path to ground.
