Obstacle course navigation
I am making a robot that has to navigate an obstacle course that contains barriers and stays within a tape boundary. I attached the code I am using and I do not know how to make it work. I am using IR dectors for obstacle avoidance and photoresistors to navigate and stay within the boundaries. When I apply the codes individually they both work, but when I try and combine them only the IR obstacle avoidance works and the photoresistors run. PLEASE help me fix this code, I need to race the robot by the end of this week!!
Here is the code, I am having trouble adding it as an attachment:
' Robotics with the Boe-Bot - fastIRRoaming.bs2
' {$Stamp BS2}
' {$PBASIC 2.5}
pulseLeft VAR Word
pulseRight VAR Word
irDetectLeft VAR Bit
irDetectRight VAR Bit
timeLeft VAR Word
timeRight VAR Word
LeftFloor CON 17
RightFloor CON 12
LeftTape CON 20
RightTape CON 15
LeftAvg CON leftFloor + LeftTape / 2
RightAvg CON RightFloor + RightTape / 2
FREQOUT 4, 2000, 3000
Main:
DO
GOSUB Check_IRs
LOOP WHILE (irDetectLeft = 0) AND (irDetectRight = 0)
DO
GOSUB IRDetect
LOOP
IRDetect:
DO
FREQOUT 8, 1, 38500
irDetectLeft = IN9
FREQOUT 2, 1, 38500
irDetectRight = IN0
HIGH 6
PAUSE 3
RCTIME 6, 1, timeLeft
HIGH 3
PAUSE 3
RCTIME 3, 1, timeRight
RETURN
IF (irDetectLeft = 0) AND (irDetectRight = 0) AND (timeLeft > LeftAvg) AND (timeRight > RightAvg) THEN
pulseLeft = 650
pulseRight = 850
ELSEIF (irDetectLeft = 0) OR (timeLef
t > LeftAvg)THEN
pulseLeft = 850
pulseRight = 850
ELSEIF (irDetectRight = 0)OR (timeRight >RightAvg) THEN
pulseLeft = 650
pulseRight = 650
ELSE
pulseLeft = 850
pulseRight = 650
ENDIF
PULSOUT 13, pulseLeft
PULSOUT 12, PulseRight
PAUSE 5
GOSUB Check_IRs
LOOP
RETURN
'Check_IRs:
' FREQOUT 8, 1, 38500
' irDetectLeft = IN9
' FREQOUT 2, 1, 38500
' irDetectRight = IN0
' RETURN
' {$Stamp BS2}
' {$PBASIC 2.5}
pulseLeft VAR Word
pulseRight VAR Word
timeLeft VAR Word
timeRight VAR Word
LeftFloor CON 17
RightFloor CON 12
LeftTape CON 20
RightTape CON 15
Main:
DO
GOSUB Check_IRs
DO
GOSUB IRDetect
LOOP
IRDetect:
DO
FREQOUT 8, 1, 38500
irDetectLeft = IN9
FREQOUT 2, 1, 38500
irDetectRight = IN0
HIGH 6
PAUSE 3
HIGH 3
PAUSE 3
RETURN
pulseLeft = 650
pulseRight = 850
t > LeftAvg)THEN
pulseLeft = 850
pulseRight = 850
pulseLeft = 650
pulseRight = 650
ELSE
pulseLeft = 850
pulseRight = 650
ENDIF
PAUSE 5
GOSUB Check_IRs
LOOP
RETURN
'Check_IRs:
' RETURN
needs to be joined with the following line.
Of course you have commented out the whole Check_IRs subroutine, so that's another syntax error.
Looks like the trouble lies in the following segment, which will never execute; there's no way in. I'm guessing that's your new replacement for the Check_IRs subroutine, so figure out how to use it and get to it.
' {$Stamp BS2}
' {$PBASIC 2.5}
pulseLeft VAR Word
pulseRight VAR Word
timeLeft VAR Word
timeRight VAR Word
LeftFloor CON 17
RightFloor CON 12
LeftTape CON 20
RightTape CON 15
Main:
DO
GOSUB Check_IRs
DO
GOSUB IRDetect
GOSUB Test_photoresistors
LOOP
IRDetect:
DO
FREQOUT 8, 1, 38500
irDetectLeft = IN9
FREQOUT 2, 1, 38500
irDetectRight = IN0
HIGH 6
PAUSE 3
HIGH 3
PAUSE 3
RETURN
pulseLeft = 650
pulseRight = 850
ELSEIF (irDetectLeft = 0) OR (timeLeft > LeftAvg)THEN
pulseLeft = 850
pulseRight = 850
pulseLeft = 650
pulseRight = 650
ELSE
pulseLeft = 850
pulseRight = 650
ENDIF
PAUSE 5
GOSUB Check_IRs
LOOP
RETURN
Check_IRs:
FREQOUT 8, 1, 38500
irDetectLeft = IN9
FREQOUT 2, 1, 38500
irDetectRight = IN0
RETURN
Test_photoresistors:
HIGH 6
PAUSE 3
HIGH 3
PAUSE 3
RETURN
