Spin Stamp and Parallax Serial Terminal
Hi All. I just got some spin stamps because I wanted a small form factor and did not need all the pins. I can program the spin stamp fine using a propplug but I cannot get any output to the PC serial terminal program. Weird !!
The test program is just using FullDuplexSerial to send a text string every second. The program works fine on parallax proto board. Is the spin stamp unusable for debugging ? Or am I just missing something ?
What pins are connected to the prop plug?
I can think of ways you might place jumpers on the Spin Stamp module from the existing interface transistors to the PropClip connections, but you'd need magnification and really fine tools so you could cut traces on the module and solder fine jumpers to it. I wouldn't recommend it. Hopefully the traces don't run under the processor chip.
