Volt Amps and Watts
I was lookin' at http://search.digikey.com/us/en/products/241-7-28/595-1062-ND/952932, it is a 28VAC, 2A CT transformer, so it is 56VA. If I were to rectify its output, I should get around, 28*1.414-1.1=38.5VDC. Can I still get 2 amps out of it when it is rectified? This would be 77W, of course a smoothing capacitor would be needed, but could I get 77W out of it?
Sorry bout that. For power supplies I usually use one that has a current rating at least 1.25 times more than the expected current draw.
http://www.onsemi.com/pub_link/Collateral/HB206-D.PDF
And if you can find/buy an old copy of the National Voltage Regulator Handbook (cica 1977), there's a section that delves into the details of transformer considerations.
It'd be interesting to hear about your efforts as you progress.
