Some crystal troubleshooting?
ok so im having some issues with my prop pertaining to crystals and frequencies. i posted a thread a while back a little similar. I was having problems with a 5mhz xtal but everythinga went smooth with a 6.25 xtal. Well i came to the conclusion that i mist have killed my 5mhz xtal, so i just ordered a new one.
well my digikey box arrived today with all my goodies including xtals from 5mhz to 16mhz. first thing i did was stick the 5 in and boot up my board. the monitor nor speakers came on so im like what the hell is going on, then realized i had ordered a 5mhz xtal thats capacitive inductance rating was series(can someone tell me what series means can i just stick a 20pf cap in series with it?) not 20pf like the rest. would this stop the board dead from booting?? also is there a way to test my original xtal?
Ive also been having problems with certain spin programs at 100mhz. they wont display on a vga. this only happens with certain programs and not the super taxing ones used to test the oc. do some vga drivers have a hard time syncing with the monitor on non standard prop frequencys? this is really the only reason i got a 5mhz xtal.
i was also wondering if anyone could tell me when you pick an xtal over an oscilator and what advantages they have. i like the idea of using the props internal oscillator when u dont need alot of speed. the only issue i have is that rcslow and fast tend to drift. i was thinking of getting a 1mhz xtal just so i can run low freq withoit drift, this then made me ask myself why the the internal oscillator drifts and if using an oscillator in a pll is ever a good idea
Some monitors have problems syncing with some combinations of horizontal and vertical sync pulse frequencies. When you over-clock, some VGA I/O drivers won't completely adjust themselves to the system clock frequency used. It depends on the I/O driver you're using and how it's written.
The internal oscillators drift because they use on-chip resistors and capacitors to set the frequency and those are temperature and supply voltage sensitive. Their values also are not very accurate and vary from chip to chip as well. As a result, the actual frequency can be anywhere in a broad range, then it can drift over time based on environmental conditions. If you need an accurate frequency standard for serial I/O or video generation, you can't use the internal clocks.
This Wikipedia article should explain things much better than I can. This article is about Pierce oscillators, commonly used in logic circuits.
so with out any kond of quick access to another 5mhz 20pf crystal is there a way i can tell if my xtal is somehow dead or if my prop chip is having problems at 80mhz for some reason, is that even possible? i mean the thing runs fine at pll4,8,16 with a 6.25mhz crystal. i dont understand how a chip would dislike a certain freq all the sudden but there are smarter people than i out there, that may have some insight into this!
Sure. You just need a multimeter, and a 1M resistor, and a small signal diode 1N4148/BAW62.
Step 1: Place the Meter +ve on Vcc, and connect the diode [Meter-] --|>|-- [Xtal2] and measure the voltage, with the Crystal shorted, and working normally.
Now do the mirror of Meter -ve to GND and connect the diode [Meter-] --|<|-- [Xtal2] and measure the voltage, with the Crystal shorted, and working normally.
You now have indications of the High frequency AC swing on the Oscillator.
If there is no change Shorted/working, you have a dud crystal.
Check the Inverter in the Prop, with the 1M resistor at your Meter probe end, measure both Xtal pins.
Common inverters are 50% Vcc, with the IP pin measuring a little lower, depending on your meter impedance, and the Inverter feedback resistor value. If you do this both ways like the example above, you can even calculate the Inverter feedback resistor value.
If you want to check the frequency, google Sound Card frequency Counter.
These work best on sloped waveforms, rather than square waves as then they can use the precision in the analog domain to calculate a zero crossing better than the sample rate.
If you are patient, you can get your PC's PPM precision from this. (eg Mine is about 18.2ppm high.)
A couple of examples
http://www.daqarta.com/dw_freq.htm
http://opend.co.za/hardware/freqmeter1/index.htm
Of course, if you already have one of these (or a mate with one)
http://www.thinksrs.com/products/SR620.htm
you can skip the Sound card Step...
Or you can generate a frequency, and measure that on the Prop, but that is slightly more work...
Precision is getting ever-cheaper, Digikey now shows these :
±20ppb $39.32 CW727-1-ND
±100ppb $31.13 CW700-1-ND
±250ppb $21.00 CW663-ND
im interpreting the inverter test goes like this. stick a 1m resistor on probe read xo and xi, if they are 50% of 3.3v or 1.65v in this case then the inverter is working?
also with the freq counter isnt the prop circuit going to put out square dc waves? if im looking for freq how does the crystals ppm value relate? im sorry if i should know this stuff, gotta start somewhere i guess
http://en.wikipedia.org/wiki/Crystal_oscillator#Resonance_modes is quite useful here.
It does appear to be a series resonant crystal, which is unusual. It should work OK with the Propeller, although the frequency will be slightly off.
The fast diode is placed in series, right at the meter probe tip, so it peak-detects the oscillator amplitude, into the Meters lead capacitance, giving you close to a RF probe.
Shorting the crystal ensures no oscillation - removing the short, should give normal oscillation, which the probe will show.
The system should operate normally while the Xtal is active and the AC measurement is made.
@leon sorry about that been up a little to long. Well the fact that u say it should work fine, and that my other 5 mhz xtal doesn't work and is hard to break is a little disheartening. I'm definately going to try jmgs test methods.
Not perhaps as unusual for a radio local-oscillator application as for a microprocessor clock... Series resonance is sharper and less affected by stray impedances.
