New FTDI chips - Page 2 — Parallax Forums
New FTDI chips
2»
  • TubularTubular Posts: 4,771
    edited 2012-04-18 13:06
    I'm not sure why the FT231XS is so big compared to the FT230XS.
    The QFN versions of both are 4mm x 4mm, so its not the die size
    edited 2012-04-18 13:23
    There's not much space savings considering the extra 4 components needed for the 231X.
  • pedwardpedward Posts: 1,642
    edited 2012-04-18 13:48
    Looks like it might be a 24 pin package with a 20 pin lead frame. Maybe it was designed as a 24pin and they opted for a 20pin lead frame at the last minute, then updated the datasheet to match.
  • RaymanRayman Posts: 16,256
    edited 2012-07-16 16:51
    Just got a notice from FTDI that there is a design flaw with the current X-chip family.... Ouch...
    Seems sending a certian bit pattern will make it go into suspend mode...
    Workaround is to force it to stay awake by disabling suspend...
    edited 2012-07-16 17:02
    You know I was just thinking yesterday of changing a couple of designs over to the new chip.
    Oddly, I feel more comfortable now that they have found a reasonable sized bug (so long as suspend mode is not required). I'm surprised though that something that big wasn't found earlier... guess it depends on the size of the vector pattern
    Thanks for sharing...
  • jmgjmg Posts: 15,200
    edited 2012-07-16 21:19
    pedward wrote: »
    I think that is just a quirk in the SSOP20 package generally, as you say, they have one molding machine for two pin counts.
    edited 2012-08-02 12:31
    FYI: The first two versions of this FT230X chip have issues and are being recalled. A partial snippet from the notice:
    As part of our business’ quality management system, we have identified an issue with the
    X-Chip Product family that in certain user applications can cause the transfer of data over
    USB to stop unexpectedly.
    Our investigations into this matter have identified that the device may go into suspend
    mode during a transfer of certain data patterns most notably with binary zeros. This can
    halt the data transfer in certain circumstances and will require the device to be reenumerated
    to recover.
    Analysis has revealed that the issue is application specific, and where devices have been
    utilised within a new design specification and functioned correctly, there is likely to be no
    subsequent issue; however we would not recommend the use of current revision B and C
    devices for mass production volumes.
    edited 2012-08-02 14:25
    Thanks WBA
    I had assumed the bit pattern might be something more complicated than all zeros! That sounds nasty.
    I hope they'll patch it up for rev D and we can be up and running again.
    edited 2012-08-02 14:32
    I thought it might be worth posting the recommended solution here:-
    "This issue can be avoided by utilising the keep awake function of the chip. This will disable the USB
    suspend function of the chip and is therefore an intermediate workaround until revision D silicon is
    released with a permanent fix.
    NB. With the workaround the chip will never enter lower powered suspend. However the keep awake
    current will be approximately 3mA.
    To enable the keep awake function in the EEPROM, one of the CBUS pins needs to be configured as KeepAwake#. This pin then needs to be tied to ground on the PCB. The FT_Prog utility can be used to
    configure the CBUS pin."
    edited 2012-08-03 00:27
    Tubular, I completely agree. Fortunately, my board with this FT230X (designed mostly by a colleague) appears to be working fine without using KeepAwake#. The FTDI chip is powered from the 5 volt output of the buck/boost switcher circuit (not Vusb 5V). Then, CBUS3 is pulled to 3.3v through a voltage divider circuit off of 5V and CBUS3 on the FTDI is reprogrammed to VBUS_Sense. In effect, this prevents the FTDI from being powered down as well, but with the resistor voltage divider circuit, you can pull the CBUS3 pin high or low (by changing resistors loaded) and set CBUS3 to one of the other options to change the operation of the FTDI depending need.
    After debugging a reset issue on our prototypes tonight, the board is working fine. From that, I can say that the FT230X chip has been proven as usable with the Propeller. (of course you must change the reset drive in PropTool to "RTS & DTR" so it works with both FT230X circuits and the normal FTDI USB circuit used on all other USB Propeller boards) I hope to share details of our design in a few weeks.
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-01-11 11:50
    My PropWifi design uses the FT230X
    http://www.mouser.com/ProductDetail/FTDI/FT230XQ-R/?qs=sGAEpiMZZMvVkErl6zY%252bqeI5xuGNHfx4
    Though I can see that I can reverse RTS# in its MTP memory, there is no settings for Push/Pull vs open drain.
    As I have no push-reset button, but I guess the Prop can pull the RESn line to ground in software and causing a short.
    Is the cap in series, plus pulldown and transistor still the best (least parts) option?
  • AribaAriba Posts: 2,697
    edited 2013-01-11 13:24
    If you can invert the RTS then a Cap (~1nF) between RTS and RES input is all you need. BOEn must be connected to Ground to enable the internal PullUp at the Reset input.
    The Propeller pulls the RES line only to Ground if a BrownOut occurs, and with BOEn Low this is disabled.
    Andy
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2014-04-11 10:19
    Note: After adding the FTDI FT230X to a design, I am rather frustrated, as it is rather buggy. Nothing like the proven ft232 so far. I have rev D, which is supposed to be fixed from something. My suggestion is to avoid this chip like the plague.
    Problems:
    Randomly quits working after 5-30 minutes, just quits passing data, dying on the chip level perhaps, the TX/RX lights quit blinking.
    As of this writing, I have a chip that windows won't recognize, from nothing more than unplugging and replugging after a problem. I have never seen anything like this in the ft232 series.
    edited 2014-04-13 16:57
    I think Parallax now use the FT230X on a number of boards, so you could check one of theirs, or one of the UMFT230X modules, to see if the same issues appear ?
    The new FT51 looks interesting too, slightly more in price, but much smarter. with i2c and ADC and DAC, so a Prop board could add that for Fast Serial as well as a i2c ADC/DAC expander.
