How to detect noisy electrical environments?
In a building where there are tons of 270V cable runs, ballasts, AC handling motors, etc. is there an instrument that is hand held designed to walk around and detect noise that would be potential cause for low voltage problems. For example, a Propeller has sensors and button inputs over 20' cable runs, with lots of false signals even though there are caps attempting to filter noise. I need something like one of those things you see on TV that they are using to detect ghosts, only I want to 'see' the noise or try to pin point cables in walls, motors, etc that are offenders.
As a thought for a crude device, what about a Prop with a wire attached that is not shielded, not filtered with caps, with a beeper. If the cable detects changes, make a beep. This would of course require a voltage higher than the trip point on the Prop, so an alternative for a more sensitive method might be an ADC, with user defined trip point going positive?
Anyway, do a Web search for EM meter and you'll find plenty, along with circuits to build your own. The "natural" or "background" ones are aimed at the ghost hunters. You don't really need or want a super-sensitive one.
-- Gordon
Here is a story about people's car keyless remotes not working due to this electrical noise in the air...
http://www.washingtonpost.com/wp-dyn/articles/A28217-2004Jul4.html
Best to use shielded wire grounded at one end only as suggested above.
