Motor help
We have been using these motors - http://www.hobbypartz.com/86ma64-2215-740kv.html
We want quite a few, but with a shortened shaft. Hobbypartz/exceedrc are unable to do this for us. Any ideas out there where we can get an equivalent semi custom motor?
Use like a dremel tool wheel and it's cutoff wheel.
Just curious.
I've worked on a few of these. Sometime the shaft is "easily" replaceable; Easily being a term used loosely. This means that you might be able to remove the shaft for cutting, times a hundred of course
Also, if you made a jig from an aluminum block that would clamp and seal the motor away from your cutting operation the aluminum will wick away heat rapidly.... With a jig, that would make your modifications go much faster..... said without knowing the final shaft length you need. It seems reasonable you could cut one a minute like this.... after spending 6hrs making the fixture of course. What I imagine would be based on a shaft support: http://www.mcmaster.com/#shaft-supports/=h4ty44 but 1/8" DIA is pretty small. That sounds like something Stock Drive Products might have: http://www.sdp-si.com/
To remove the shaft, a c clip has to be removed. They apparently use some type of bearing preloader or something, because it is very difficult to get the c clip back in place. I am experimenting with no c clip in place, I am unclear if the bearings need it to operate properly. I am using the face of the motor to drive the magnetic drive for the pump.
I'd be surprised if it takes more than 10 minutes to make a jig like that with a chunk of aluminum, a drill press and a bandsaw.
More like 5 minutes. GO!
And you can't risk cutting debris getting into the bearing either... Besides the shaft will spin. Usually motor shafts are replaced by pushing them out of the armature with the right tool (apparently this is commonly done with RC electric motors).
In the UK the steel alloy used for shafts is called silver steel. Its a tool-grade steel that can't be easily machined.
Fine metal shavings in an unsealed bearing is not good news for a motor that runs 1100 hours a year.
I utilize motors quite often, and I often machine the shafts to some degree, by either shortening the shafts or milling flats for set screws. I would have to agree with some of the other folks and just cut the darn things. For that matter, cut one and test it for an extended period of time to see if the machining procedure caused any problems to the bearing.
As for the machining procedure, here is what I would do just to shorten the shaft.
- Layout a motor mount from aluminum angle stock with very tight clearances around the shaft to prevent unnecessary debris from entering the motor or bearing surfaces. Additionally make 2 or 4 mounting holes to bolt the motor mount to a work surface.
- Layout a chuck holder from aluminum angle stock being inline with the center of the motor shaft. The chuck will keep the motor shaft from spinning and act as a heat sink. Additionally make 2 or 4 mounting holes to bolt the chuck holder to a work surface.
- Attach motor to bolted down motor mount.
- Attach chuck and chuck holder to motor shaft, shim any slight discrepancies, and fasten chuck holder to the work surface.
- Cut shaft with a Dremel cutoff.
- Unfasten chuck holder from work surface and move out of the way.
- Run motor and dress up cut shaft with an appropriate file, however, hardened shafts will damage a file.
BruceEDIT: Additionally, I would make the cut off in several passes to eliminate bearing lubrication breakdown
EDIT: As opposed to a chuck and chuck holder, you could also machine a shaft clamp to act as a heat sink and to keep the shaft from spinning.
EDIT: A little effort put into machining the proper tooling can go a long way into simplifying a tedious and painful task.
http://images.search.yahoo.com/search/images;_ylt=A0oG7t_L3oxPoEwAKidXNyoA?p=abrasive+metal+cutoff+saws&fr=yfp-t-521-s&fr2=piv-web
Okay, I agree that a shop grade metal cutoff saw with a thin abrasive wheel would be the right tool for the job, providing that it would be several cuts instead of one pass, to avoid heat build up.
Bruce
Then get some good thermal paste and add a little bit in the clamp to further increase the thermal transfer.
Cutting should be water or oil cooled if you do not to reduce the steel's properties.
Frankly, the hobby part market is generally what you see is what you get. And with motors, I suspect that a company would want an order of thousands before they would fill to a custom specification.
Regarding assembly and disassembly, there may just be a learning curve about getting the c-clip into place. Preloading is usually an issue with big motors - 100s of horsepower, not these tiny items. But there may be a spring metal washer (appears to be bent, but that is as it should be) that takes up end play. I'd not try to leave out a c-clip or any parts.
BTW, $13USD per motor is a bargain price. These brushless motors can easily cost 10x that. Some brushless suppliers sell replacement shafts. If you can locate one of suitable dimensions that would be ideal, but again I suspect that this would be a special order and cost more than $13 per unit.
http://servocity.com/html/shafts__rod___tubing.html <== Try hear for shafts if you need replacements.
Wow you cut that close didn't you? I know a couple redneck machine shops that would love to do this for $200, maybe you have some in your area?
Can you use off-the-shelf female-male or female-female standoffs to lift the motor off the floor and keep the stock length shaft?
Somewhat off topic: Consider moving fresh air around the motor to cool it. Them babies will get hot spinning stationary with no prop on the end. The cooler you keep it, the longer the bearings will last...... but you probably already thought of all that.
The point here is, I would like to ask the manufacturer how many I have to do to get this done. I have no link the manufacturer, and the link doesn't feel it can't be done for any price.
Economies of scale require manufacturing runs of 10,000. If you are not a player at that level, you are generally ignored.
