Gas Electricity Water puzzle can't be done?
lardom
Someone who works in the office at my job asked if I had seen 'The puzzle'. I couldn't resist. I 'knew' I could figure it out. The idea is that the three houses in the graphic must each recieve all three utilities - gas electricity and water without crossing any lines. You can't go under or over and you can't 'steal' from another house. Try as I might I could only complete eight lines. I'm not a purist so I had no problem Googling the puzzle when I suspected there was no solution.
Is there a solution or an explanation?
Solar Panels on each house, rain water collection system, Liquid Propane tank at each house.
What did I win?
Jim
at least one of the lines goes around the page ==> front - edge - back - edge - front
Cheating? Maybe, but not disallowed by the puzzle rules.
Bruce
Ahh but the lead does not represent the inlet, the pad is the inlet
turns out I overlooked where i had drawn the line I knew i mad the 9th connection unfortunatly i didnt pay attention to where
http://en.wikipedia.org/wiki/Water,_gas,_and_electricity
my solution works does it not?
not to bad considering i was in the back of a car heading down a bumpy road.
The house on the left did not get gas.
You just saved me lots of aggravation
i am embarassed
sorry i jumped on that one.
I love puzzles but the ones with no solution in the inherent structure drives me nuts, cause of course you can alter the puzzle and win, but we can always break or bend the rules.
but I like to remember the rubrix cube. the rules said " try to get all the colors to one side" but did it seem right to pull off the stickers.
i can also think this may work out if you printed this and folded it into the right shape.
Gas doesn't go to the first house.
Don't worry, it's a trick question to begin with.
Some human resource departments give this puzzle to test problem-solving skills. They also use it on those expensive management retreats. They look for such things as trying to re-arrange the houses and utilities (the puzzle still can't be solved). Those who try to rearrange the objects usually get a higher "grade" than those who keep the layout the way they got it. That supposedly shows a higher degree of problem-solving. Those who present a solution that "cheats" get a failing grade. They're looking for problem solving within a framework (i.e. within budget, in time, etc.).
-- Gordon
yet I love puzzles that has the solution and I have to comply with the rules.
MENSA books are fun ^,^
yet if I see something presented as a puzzle I like to have it possible to win within the structure.
though thinking of it for a moment the rules do not say you can not print this and roll it into a cylinder does it?
that may work too.
some my argue you can not alter the real world, yet in a way you can.
anyone going to enter the contest? Parallax is in on it, just a reminder
Seen Mythbusters?
With a large enough sheet of paper you CAN get more folds...
The 3 houses/3 utilities problem is written down in a lot of books dealing with topologies, so quite familiar to me.
Anyone who wants to play with topologies, and especcially planar graphs should check out
http://www.planarity.net
When you pass 50 nodes in the graph it suddenly begins to get challenging...
