Boe-Bot servo problem
Hello,
The Boebot's servo's do not stop simultaneously. So, when the right servo stops the left servo continues spinning for a sec or 2.
Am I able to solve this problem? As far as I know it is not a software problem and neither is it a centering problem.
Thanks in advance!
Cheers
Thanks in advance!
Cheers
I took another look and concluded that I judged the lag to be longer than it is. It might be just around 10 ms. So I'll just have to live with the minor twitch the robot makes when it stops. That turned the problem into a little issue!
{$STAMP BS2} ' {$PBASIC 2.5} ' 'Continuous Servo Super Centering ' 'My servo's null range is min 748 max 752. The min value must be equal 'distance from max value and always centered on 750. ' 'Center your servo using pulsout 750. Then: ' 'You should setup the null zone for your servo by testing one pulsout 'at a time until you cover the range of values that do not move the 'servo. Once you have that range, you adjust it so the center of your 'range is based on pulsout 750. Pulsout all the positions in the null 'zone and then adjust potentiometer. You may want to delete the highest 'and lowest pulsout to make it a little easier. servo CON 12 'set this to servo pin DO PULSOUT servo, 748 PAUSE 20 PULSOUT servo, 749 PAUSE 20 PULSOUT servo, 750 PAUSE 20 PULSOUT servo, 751 PAUSE 20 PULSOUT servo, 752 PAUSE 20 LOOP1) Coasting: Just stop sending pulsouts to the servos and they'll coast a little while as they stop.
2) Braking: Continuing to send a stream of PULSOUT 750's to both servos applies dynamic braking for faster stopping.
Try both approaches and see which works best for your situation.
