Infininty Mirror
There are a lot of tutorials online about how to make the mirror part. Basically it's a regular mirror in the back, then a piece of glass about an inch above it with mirrored privacy tint on it. Then anything you put in the sides reflects to 'infinity'.
This mirror is about to go to a frame shop to be finished and I won't have it for another 2 weeks, then it's off to my girlfriends house so I thought I'd share.
The code for that is nothing more than a bunch of
And the 10 LEDs are wired to NPNs connected to the 0-9 Prop pins.
dira[0..9] := 11111111
repeat
outa[0..9] := 00000000
waitcnt(clkfreq/50 + cnt)
'etc....
Could you use a somewhat flexible mirror at the rear, one that you could bend with an actuator, and make the infinity illusion move around, warping in and out or side to side? Just thinking.
I was thinking that and hadn't thought of a flexible mirror. I toyed with connecting a servos directly to the stiff mirror and you get a cool effect but it wasn't symmetrical enough. I really want to invest the time into shiftout/MAX drivers and tri-color LEDs and put it on a gimble. It would make a sick display case for the prop in the middle too. If I make one for me it would wifi or xbee as well.
Radio Shack once sold an 'infinity mirror' with LEDs, too - red ones they were, T1s, but they didn't blink or do patterns, they were just on.
How about some fades or pulsating stuff?
That's interesting that RS sold something like it. I guess I'm writing the code for it while it's getting framed. I will do some audio reactive lighting maybe a Prop based VU meter, that will take at least two weeks
Lowes has a roll 3' wide for $29. Is that what you used or some like it??
http://www.lowes.com/pd_88148-74130-PRS361_4294935484+4294796833__?productId=1103235&Ntt=window+film&pl=1¤tURL=%2Fpl_Privacydecorative_4294935484%2B4294796833__s%3FNtt%3Dwindow%2Bfilm&facetInfo=Privacy/decorative
I thought it'd make more sense to just buy the dumb one-way mirror but they are surprisingly expensive.
