Serial Comm Question
Hello,
I have a serial signal coming out of an android phone from the audio port with a 5v level. I want to use the prop to view the results using the parallax serial terminal. What are some hardware considerations do I need?
Curtis
Curtis
I am using an earphone jack from the android to a 4.7k resistor on the signal line to the inverting pin of the lm324 op amp and a 5 volt divider to the non-inverting pin. The output pin of the lm324 goes to a 100 ohm resistor to the scope. I see a signal from 60mv to 4.1 volts modulated coming out (squarewave). I use the voltage divider to set the threshold for the baud rate. I used the circuit and the android serial software from: http://robots-everywhere.com/re_wiki/index.php?title=Serial_on_Android_using_the_audio_port
Cenlasoft
You've used the circuit and software provided, what hardware considerations are you asking about, the micro controller?
In the video, he's using a propeller proto board. That or any stock prop board should work, as the prop chip is always the same.
I have all the prop boards that parallax makes. In the video, he never elaborates how he hooks the prop from the output of the lm324. At the end of the web site he states to use a picaxe chip. I have one, but I prefer to use the prop. The picaxe is a 5v chip. Thanks,
Cenlasoft.
Keep on it!
