Telepresence Robot motor mounts — Parallax Forums
jdoleckijdolecki Posts: 726
edited 2012-05-02 08:53 in Robotics
Was finally able to finish making and welding the motor mounts onto the base.
The motors and wheels are from a wheelchair.
The cart was originally a computer cart from a hospital.
    edited 2012-03-28 08:30
    Looks like a nice welding job! That is a great platform for a telepresence robot. Was there any brand name or model of that computer cart?
    If you haven't heard of the LEAF project you may want to checkout:
    http://www.leafproject.org/
    It may be a good project to run on your platform. I'm using it on one of my larger robots with excellent results. Besides the base LEAF setup I also use a Propeller as a co-processor.
    Robert
  • jdoleckijdolecki Posts: 726
    edited 2012-03-28 08:50
    Good thing i'm a better welder than programmer.
    The cart came from my local electronics recycle. there on e-bay just type hospital computer cart.
    I read about the leaf project a couple years ago It didn't seem to catch my interest but I will revisit it.
    I really want to give Microsoft robotics studio a try, I'm a firm believer that that's the way to go since everything else
    in the world runs on Microsoft.
    edited 2012-03-31 17:08
    Next problem is getting it all to fit
    The mother board
    2 batteries
    Computer power supply
    Motor driver
    All the wiring
    Hard drive
    Propeller board I'm still thinking about getting and Eddie board right now i have a gadget gangster board
    I thought the sticker above the e-stop button was funny but my wife says I'm a dork!
    1024 x 1371 - 190K
    1024 x 765 - 114K
    1024 x 765 - 101K
    1024 x 765 - 93K
    1024 x 1371 - 99K
  • CerinCerin Posts: 1
    edited 2012-04-03 08:28
    jdolecki wrote: »
    You're joking right? Not to sound like a snob, but I don't know anyone using Microsoft robotics studio for "real" robotics development. It's Linux all the way.
  • Tom CTom C Posts: 461
    edited 2012-04-03 10:03
    Cerin wrote: »
    Cerin,
    Before you make a statement like that, you need to search the web to see how involved MS plans to be in the world of robotics. Since MS is giving RDS away for free, it is going to be hard to compete with them in the long run. Remember when PCs were a "hobby" type of electronic gagdet and nobody knew who Bill Gates and Steve Jobs were? MS is a power to be reckoned with in the world of robotics.
    Just a thought.
    TCIII
    edited 2012-04-03 12:08
    I currently Have Ubuntu running ROS on that mother board you see laying there on the table.
    I'm open to all operating systems and will try as many as I can.
    edited 2012-04-05 01:59
    Finally got it on the ground and moving under RC control.
    http://www.youtube.com/watch?v=yp7jta9wNXk
    1024 x 1371 - 188K
    ro1.jpg 187.6K
    edited 2012-04-09 10:38
    I was able to get the encoder boards mounted to the gearboxes this weekend.
    Reprap 10 bit magnetic encoders.
    Soldered them myself
    took apart the gearbox.
    Made slug to center the board.
    spot faced the case for the standoffs
    6-32 screws to hold it on
    Since the shafts are hardened I will glue the magnets to the ends.
    Now were are those special magnets?
    1024 x 765 - 81K
    1024 x 765 - 69K
    1024 x 765 - 71K
    1024 x 765 - 93K
    1024 x 765 - 69K
    edited 2012-04-14 15:48
    Finished the encoder magnet mounts
    Made from nylon stock
    Since the shaft was hardened it epoxied the mounts to the end of it.
    1024 x 765 - 81K
    edited 2012-04-28 20:14
    I finally figured out how to get all the components into the case
    I had to grind out all the factory standoffs and ribs
    There is now a aluminum box surrounding the batteries that will be welded to a bottom plate.
    The components are mounted to that plate.I will weld it all together once i fix a few interference issues
    1024 x 765 - 87K
    1024 x 765 - 95K
    1024 x 765 - 103K
    1024 x 765 - 94K
    edited 2012-04-28 21:24
    Hi Cerin - Welcome to the Forums! :thumb:
    ..."real" robotics development...
    What's that mean? I mean, from your viewpoint, what constitutes a "real robot"?
    -MattG
    edited 2012-04-28 21:37
    Hey jdolecki-
    Looks great! I am watching this project with great interest
    :thumb:
    -MattG
    edited 2012-05-02 02:51
    Welded the "Cube"together and started mounted the components.
    Moved some of the components around again to get the most clearance between them and the case.
    All boards are mounted with nylon screws and standoffs.
    Fabrication left to do: Mount for 4 ping sensors"Ping Ring", Battery hold down and Gadget Gangster mount plate.
    Wiring: Quick connects between the Controls and robot. ( Motors, encoders, monitor and Kinect)
    Plan to finish the wiring and upload the Eddie firmware this weekend and attempt to drive it with the wireless Xbox controller.
    Ye-ha let the Robot Assimilation begin.
    I plan on bring It to UPEC.
    1024 x 765 - 98K
    1024 x 765 - 78K
    Looks like you've been busy jdolecki, It is a very cool platform.
    Kinda looks like the Borg cube from Star Trek...:thumb:
    -Tommy
