XBee load during SLEEP more than expected
I'm using the Series 1 XBee and a BS2 on a battery to send a few BYTES when a condition changes. Most of the time the XBEE is in Hibernate Sleep mode 1 which, according to the documentation, should draw <10 uA. My XBEE is drawing 3.4 mA during the Hibernate Sleep periods.
I am using the 32401 5V/3.3V Adapter Board. Would the circuitry in this Adapter Board increase the load that much?
Also, is there a way to disable the Blue Power LED on this Adapter Board. I don't need it and I want to minimize the power draw as much as possible
falcon
falcon
The datasheet for the regulator on the adapter board looks like it has a low quiescent current as well. You may find that disconnecting the LED will drop the minimum supply current enough for your needs ( <30uA)
Another thing to watch out for is the pullup resistors on the xbee, depending on what you have attached to the pins. Pullup resistors can be disabled or enabled using the ATPR command, and they are all enabled by default. For example, there is a pullup resistor on pin 16 of the XBee (RTS\), and if you were to connect the external input RTSn to ground, then level shifter would always be left sinking about 25µA current through that pullup resistor. Unused i/o pins should be left with their pullups enabled, just as with the BS2.
XBee pin 9, sleep_rq, also has a pullup, so if you are interfacing to sleep_rq from the Stamp, you can do so through a transistor for level shifting, not via a driven connection from stamp pin to XBee pin.
I appreciate the suggestions.
Mike, Transmitter reaction time is not a critical factor so I am considering using a transistor and BS2 I/O pin to control power to the XBee/Adapter Board. This would avoid disabling the LED. Would this approach (one wake/transmit/sleep cycle every 15-30 minutes) cause excessive wear on the XBee? What other parameter changes would be helpful with this approach?
Tracy, I'm only using the DIN, DOUT and sleep_rq pins...no I/O. I will check the pull-up resistors and see if I can work that transistor into the sleep_rq circuit.
falcon
Power cycling wouldn't cause wear. There are no moving parts and no power surges (like in a high power device).
