Is there a 'more' reliable transistor?
In an application where a Prop will drive IR LEDs at 38K for infinity, is there a transistor that could be deemed more reliable than others? Reliable meaning, under normal temperatures(70-80F) last a long time will the least failures. I am testing 15 IR LEDs(TSAL6200 Vishay). The transistor will be an NPN. Optionally, I do not mind the expense of a mosfet.
In example circuits online, I see 2n2222, BC337.
Temperature rise (and thermal cycling) are a known failure drivers, so a cooler transistor will be deemed more reliable than a hot one. I think oft quoted is a 10'C junction rise, doubles failure rates.
There are also failures due to electron migration so pushing close to a rated current is also not good for reliability.
So choose a power package that is easy to cool, and use a fraction of the rating.
Keep your transistors strongly derated for durability - use the 2N2222a for 100ma at 12 volts or less is likely to last indefinetly.
http://www.eng.yale.edu/ee-labs/morse/compo/datasheets/2n2222.pdf
Heat is the great destroyer. Individual metal packages are better than multiple transistors in epoxy packages. So be wary of SMDs.
MOSfets generally run cooler, but have two disadvantages - they often do not do well when switching is driven by 3.3VDC or 5VDC; and they can be easily damaged by static electricity. So my 'hobby choice' is to keep some 2n2222a on hand. There usually isn't much heat, but if you must have a low-power consumption design, the MOSfets are worth the additional trouble.
I keep a small stock of ZTX1049A (npn) and ZTX1149A (pnp) on hand. They are superbeta, with gain typically 800 or 1000, so I often use them with op-amps in current sources, as well as for switching where that high gain eases the drive requirements. They do seem to be bulletproof. Its TO92 type package is rated for 1W, 4A continuous at saturation, 20A pulse. So it could coast along driving a few leds, and do so with a very low base current.
Whether they would be worth the price premium for you application is quite a different question.
Zetex was a very innovative company, and I was kind of sad to see their identity swallowed in acquisition by Diodes Incorporated.
I use the smt versions of the 2N3904 & 3906 in all of our products and have never seen one blow.
[video=youtube_share;yNDO04g9Ugc]
They are certainly good transistors, but one might as well buy the 2N2222a and the appropriate counterpart 2N2907 for usually similar cost. There are occasions that the 2N2222 and 2N2907 will drive a relay or an H-bridge that is marginal with the 2n3904 and 3906.
Handier, and more economical
Smt is a separate issue as the package is a significant thermal issue. It really helps to just have the transistors off the board and individually cooling. But if 5VDC and 30ma are your usuall parameters, heat is not much of a problem.
I like the SOT223 packages for moderate drive applications.
There, in MOSFETS, Digikey lists
100V 1.7A 350mOhms 56c 1+
30V 5A 60mOhms 68c 1+
