PIR Sensor (Rev B) [555-28027] Reduce cool-down time?
I'm trying to sense when people walk into a room using two PIR (Rev
sensors; so I can tell when they are entering and leaving.
The logic behind it isn't the issue, my problem with the PIR sensors is when they first detect a hot body, they give a signal for the first instance a hot-body is detected but then they will stay lit for another ~3 seconds, during which time they will not detect additional hot-bodies entering the room. Is there a way to reduce the cool-down time between first detection and the sensor resetting?
TL:DR
Can I reduce the cool-down time of the PIR sensors after they first sense a hot body?
If so, how?
Thank you.
TL:DR
If so, how?
Thank you.
This notion of "cool down" time is a bit of a lark, though. PIR sensors don't sense heat as much as they sense change of heat across a pair of detectors. The relative temperature of the sensed object doesn't matter; it's the difference between the two that counts. That's why these things can point to a still-hot asphalt driveway in the evening, and yet detect cooler-bodied people walking up to the house. The on delay is something in Rev B sensors, which I assume was meant to make them a little easier to use. I don't know of a way to adjust it.
-- Gordon
Thanks for your suggestion though, I will look into Rev A and see if can satisfy my needs.
Thanks again!
