Eddie Wheel Encoder Error?
This is somewhat related to my "Eddie and RDS4" post but I've removed RDS for now to make things more generic to Eddie.
When I use the serial terminal to issue "turn b4 10" which (I believe) should be a 180 degree turn Eddie stops short. I have to enter "turn BC 10" which equates to 188 degrees but the turn is consistent.
After the turn I request "head" and receive B2, 178 degrees.
To get a 90 degree turn I have to specify hex 62 which is 98 degrees, but consistent.
Has anyone else seen this?
tlc
tlc
Some Eddies have more friction in their motors than others, and different floor surfaces and load weights will also effect how fast or slow a slow speed is. The Eddie firmware can be tuned to be more aggressive when trying to reach an end point. Look for the following line in the firmware, and decrease the number '16' to make your Eddie try harder to go the last inch or two when it is traveling:
Kp long Motors#MAX_ON_TIME / 16 ' Proportional error feedback gain
— David Carrier
Parallax Inc.
