Options for IR light curtain
Hey guys, question. I have a project I am working on and part of the requirement is to have a light curtain, which is bank of IR LEDs every 6 inches that will detect a break in the curtain. The curtain covers 6' vertically. There are easy options online for the strip of emitters and detectors, and built in processor with relay. They are all pretty crude looking, typical elevator stuff that is not designed to sit out visible in an exposed way. So I am thinking about options to do something cosmetically much nicer. A quick example: just simulate the strips with a nice piece of hardwood, drop the LEDs on one side, drill through and have only about a 1/16" every 4" or so. Same for the detectors, so the result is not some metal gadget with an ugly plastic lens(full length on most products, top to bottom, 7' long). The hole pattern still is a bit obnoxious, this is a high end home, an entrance to bedroom.
I wanted to see if anyone had any other suggestions. An obvious 'invisible' choice might be the Xband. I have those, and they can be mounted behind wood or drywall easily, so no cosmetic detail. But, since there is a door that is closing in the path, the Xband would likely trigger off of it. The IR beam is logical, as it is a very narrow line of sight that must be broken, it ignores the door.
Any thoughts or suggestions would be really appreciated.
Otherwise, I guess clear emitters and detectors would be less intrusive looking on a white background.
Does it really need to be every 6"? That seems a bit extreme, even for commercial use.
Personally, I'd just hang a set of 60s hippie beads connected to some piezo sensors to detect movement. Add a black light or two, some incense, and sitar music, and you'd be all set!
-- Gordon
What is the ultimate goal?
As gordon questioned, security, occupancy,...
Any plastic lense(strip) will be offensive to the cosmetic detail of hardwood and drywall. But as a last resort...
Don't know what state this is for, but by law there might need to be a secondary fail safe in the motor door closure as well. You can see how the Star Trek fans have tackled this. Some of the designs are pretty ingenious (though some look institutional). I'm sure you thought of it, but fire laws prohibit automatic doors in residences that cannot be also manually operated. Occupants must be able to freely and easily open the door by feel.
-- Gordon
-- Gordon
This was a lot of fun to figure out, amazing how tiny the beam is. This is a very shaky iphone vid and the narration sucks.
http://www.youtube.com/watch?v=2l7-UM3D39I
To minimize wiring, you could chain these with 1G79 / 2G79, and if you resistor-couple the IR Rx, you can wait in one state with all on, then if you sense a change, send a scan wave via the FF, and the CLK(s) where no Load decrease is seen, is the one that is off.
