push button problem.
I'm using two push buttons, one for mode and one for reset. The problem i'm having is that every time I press the PB1 the data displayed is random, where as I want it to follow the sequence of IF statements below. The information displayed will eventually be the actual data and it will be sent to an LCD but for now I would love to get PB1 to be more consistant. If anybody has any ideas in regards to this problem, I'd really like to hear them. Thanks in advance guys.
[ I/O Definitions ]
PB1 PIN 13 'Receive Input from pushbutton1(mode)
PB2 PIN 12 'Receive Input from pushbutton2(reset)
[ Constants ]
Capture CON 500 ' Num of msec to listen for input
[ Variables ]
pulses VAR Word ' input pulses from flow sensor
[ Initialization ]
HIGH PB1
HIGH PB2
pulses = 0
[ main ]
main:
IF IN13 = 0 THEN mode
DEBUG CLS, "press top btn for mode OR bottom btn for reset ", DEC pulses, CR
PAUSE 500
IF IN12 = 0 THEN reset
GOTO main
[ subroutine for current flow rate ]
mode:
DO
COUNT PB1, Capture, pulses
IF pulses = 1 THEN
DEBUG CR, "current flow rate ", DEC pulses, CR
PAUSE 500
ENDIF
IF pulses = 2 THEN
DEBUG CR, "total consump ", DEC pulses, CR
PAUSE 500 'debounce
ENDIF
IF pulses = 3 THEN
DEBUG CR, "resettable consump ", DEC pulses, CR
PAUSE 500
ENDIF
IF pulses = 4 THEN
DEBUG CR, "freezing/normal ", DEC pulses, CR
PAUSE 500
ENDIF
IF pulses = 5 THEN
DEBUG CR, "leaking/ok ", DEC pulses, CR
PAUSE 500
ENDIF
PAUSE 1000
LOOP
GOTO main
reset:
DEBUG CR, "resettable code goes here ", DEC pulses, CR
GOTO main
[ I/O Definitions ]
[ Constants ]
[ Variables ]
[ Initialization ]
HIGH PB1
HIGH PB2
pulses = 0
[ main ]
main:
PAUSE 500
GOTO main
mode:
DO
IF pulses = 1 THEN
PAUSE 500
ENDIF
IF pulses = 2 THEN
PAUSE 500 'debounce
ENDIF
IF pulses = 3 THEN
PAUSE 500
ENDIF
IF pulses = 4 THEN
PAUSE 500
ENDIF
IF pulses = 5 THEN
PAUSE 500
ENDIF
PAUSE 1000
LOOP
GOTO main
reset:
GOTO main
The SELECT CASE syntax might be good for your Mode function:
I thought the pause 500 after each if statement would take care of the debounce, obviously not, thanks for the heads up on the select case syntax, I'll check it out.
Thanks for the advice, it works like a charm now.. here's the code, let me know if I can make any improvements on it... thanks again
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
tx PIN 8
result PIN 1
[ Constants ]
leaks CON 99
freezing CON 98
currentflow CON 97
totalconsump CON 96
consumpreset CON 95
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
T9600 CON 84
T19K2 CON 32
#CASE BS2SX, BS2P
T2400 CON 1021
T9600 CON 240
T19K2 CON 110
#ENDSELECT
LcdBaud CON T19K2
LcdBkSpc CON $08 ' move cursor left
LcdRt CON $09 ' move cursor right
LcdLF CON $0A ' move cursor down 1 line
LcdCls CON $0C ' clear LCD (use PAUSE 5 after)
LcdCR CON $0D ' move pos 0 of next line
LcdBLon CON $11 ' backlight on
LcdBLoff CON $12 ' backlight off
LcdOff CON $15 ' LCD off
LcdOn1 CON $16 ' LCD on; cursor off, blink off
LcdOn2 CON $17 ' LCD on; cursor off, blink on
LcdOn3 CON $18 ' LCD on; cursor on, blink off
LcdOn4 CON $19 ' LCD on; cursor on, blink on
LcdLine1 CON $80 ' move to line 1, column 0
LcdLine2 CON $94 ' move to line 2, column 0
LcdCC0 CON $F8 ' define custom char 0
LcdCC1 CON $F9 ' define custom char 1
LcdCC2 CON $FA ' define custom char 2
LcdCC3 CON $FB ' define custom char 3
LcdCC4 CON $FC ' define custom char 4
LcdCC5 CON $FD ' define custom char 5
LcdCC6 CON $FE ' define custom char 6
LcdCC7 CON $FF ' define custom char 7
[ Variables ]
State VAR Word
[ Initialization ]
HIGH PB1
HIGH PB2
HIGH result
HIGH 15
State = leaks
pulses = 0
[ main ]
main:
PAUSE 500
GOTO main
mode:
DO
SELECT State
CASE leaks 'pushbutton pressed
IF IN13 = 0 THEN
PAUSE 250 'DEBOUNCE
IF OUT15 = 1 THEN
SEROUT TX, LcdBaud, [LcdBLoff, LcdOn1, LcdCls]
PAUSE 250
SEROUT TX, LcdBaud, ["No Leaks"]
DEBUG CLS, "No Leaks ", DEC pulses, CR
ENDIF
IF OUT15 = 0 THEN
PAUSE 250
SEROUT TX, LcdBaud, ["ATTENTION!! Water is Leaking."]
DEBUG CLS, "ATTENTION!! Water is Leaking. ", DEC pulses, CR
ENDIF
State = freezing
ENDIF
CASE freezing 'pushbutton pressed
IF IN13 = 0 THEN
PAUSE 250 'DEBOUNCE
IF Result > 930 THEN
PAUSE 250
SEROUT TX, LcdBaud, ["Pipes are going to freeze!!!"]
DEBUG CLS, "Pipes are going to freeze!!! ", DEC pulses, CR
ENDIF
IF Result <= 930 THEN
PAUSE 250
SEROUT TX, LcdBaud, ["Temperature of pipes are OK"]
DEBUG CLS, "temperature of pipes are ok ", DEC pulses, CR
ENDIF
State = currentflow
ENDIF
CASE currentflow 'pushbutton pressed
IF IN13 = 0 THEN
PAUSE 250 'DEBOUNCE
PAUSE 250
SEROUT TX, LcdBaud, ["Current flow is ???????"]
DEBUG CLS, "current flow rate is ", DEC pulses, CR
State = totalconsump
ENDIF
CASE totalconsump 'pushbutton pressed
IF IN13 = 0 THEN
PAUSE 250 'DEBOUNCE
PAUSE 250
SEROUT TX, LcdBaud, ["Total Consumption is ???????"]
DEBUG CLS, "Total consumption ", DEC pulses, CR
State = consumpreset
ENDIF
CASE consumpreset 'pushbutton pressed
IF IN13 = 0 THEN
PAUSE 250 'DEBOUNCE
PAUSE 250
SEROUT TX, LcdBaud, ["Ttl Consump snce lst rst is ??"]
DEBUG CLS, "total consump since reset ", DEC pulses, CR
State = leaks
ENDIF
ENDSELECT
LOOP
GOTO main
reset:
IF IN12 = 0 THEN
PAUSE 250 'DEBOUNCE
PAUSE 250
SEROUT TX, LcdBaud, [" rstable code goes here??"]
PAUSE 2000
ENDIF
GOTO main
