Propeller tool 1.3 wine error "Read failure on COM1"
Gents,
I'm trying to get the Propeller tool 1.3 working under wine but when i want to compile and load to RAM/EEPROM i get the message "Read failure on COM1"
Identifying The hardware via F7 is successful but when it starts verifying RAM it ends with an error.
Does anybody have some very smart ideas about this?
Or if you can work on the command line use the new opensource Spin compiler from Parallax. Not sure if there is an IDE for it yet.
There is always the HomeSpun Spin compiler that is written in C# and runs fine under Mono on Linux.
Problem solved topic closed.
