Cheapest Prop board?
Is the Quickstart the cheapest Prop board being sold?
I think it's $25 from Parallax, more through other vendors.
The new FTDI FT231 chip has me thinking about how cheap a Prop board could be...
I also noticed yesterday that Digikey has Props for $5 in qty. 100.
Haven't gone through the numbers extensively, but it seems that very basic Prop board could be made for ~$10 in parts...
$5 Prop
$2 FT231X
$1 USB connector
$1 EEPROM
$1 Crystal + passives
Add in a dollar or two for the PCB and maybe you have something that can be sold for $15?
$5 Prop
$2 FT231X
$1 USB connector
$1 EEPROM
Assembly and testing costs could be eliminated if the board was sold as a bag of parts kit, and the user gets the fun of building the board.
If one bought the parts in quantity, and was able to sell the kit for around the price of one-off parts and shipping, I would propbably go with the kit. $15 would be a great price.
I would even ask for a unit that did not have the USB. I already have a prop plug and I only use it to program one board at a time. If that could be used, and the cost reduced further, I would still think it might be worth $15.
I'd probably go up to $8 for a bare board that I could add a dip prop, EEPROM, crystal, passives ans and option for USB ( w/ USB ) or a prop plug... But once you figure in design, manufacture and distribution costs, that might be a money loser.
The pricing rule of thumb seems to be 2.5 times the material costs, so you should charge $30 for the $12 kit.
--Rich
OBC
Maybe I'll think about a $16 to $19 board.
(I think about a lot more stuff than I actually do
Andrew, I like your board BTW. So, I guess $20 is the lowest priced Prop board around?
For you, the Prop adds $6 to the BOM and maybe $10 to the final sales price. For Parallax, the Prop adds (maybe) $2 to the BOM and $4 to the final sales price.
The Propeller Platform kit isn't the cheapest design possible - If you made a basic board (no USB, 3.3v only, one set of headers, no reset or power switch) as a kit, you could probably sell it for $25. But folks can already get a QuickStart, which is pre-assembled, includes USB, etc, for the same price. So how many basic kits would you expect to sell?
Not that I promote it that much, but I have sold 1. I did this and a few others just for fun.
The CpuBlade does not have an FT232 chip, but it does have the transistor reset circuit so that a cheap eBay USB-TTL (CP2102) board ~$4 can be used instead of a PropPlug. It has a 3V3 regulator but does require 5V input (readily available these days). Headers are supplied. The xtal is socketed and can be supplied as 5MHz, 6MHz or 6.5MHz (104MHz) and the board is designed for overclocking. http://www.clusos.com/home/1952.html
So, maybe I'll think about $19.99 and leave Cluso the lowest price winner...
I think $19.99 with say $2 USPS shipping should be possible.
The cost of the stencil and PCB fab setup fees are also killers, but if I can piggyback onto other projects, maybe it's possible.
I think Quickstart was originally to be $20 and then went $25.
As Nick points out, they do make the chip and save $6 there.
Aren't protoboards $20 in qtys of 5?
Cheapest 3rd party board I've seen is the LPC-H11A14 at Mouser, $15 1+ and $12 5+
So yes, Boards are being sold for $15.
Perhaps NXP give them the LPC parts, in a contra-deal, or a volume price ?
I like the LPC-H11A14 '4 sides' form factor, which keeps the PCB size down, AND gives user more IO pins...
The Quickstart is good, but one beef is it has no 'shrink' option.
Just a little more effort on the layout, and two saw cuts could make a much smaller one.
I've seen Nuvoton manage the 'subset' question, with some well placed slots - sturdy, but makes the user-cut-choice very clear.
Is a really tiny board really the best? I'll have to double check the cost per square inch PCB, but I don't think it's too much.
Wouldn't it be better to have place for people to solder in resistors and connectors to form audio, TV, and VGA outputs?
There are really two steps in this :
One is a first working device step, which is 'a device with a pulse' - this is minimal, but does need to not limit IO too much ( A weakness of USB stick type parts) .
Get this right, and you will sell 5 packs
Next up is a more functional board, Audio/TV/VGA are good, but given your work in the other thread with the SSD device, what about a stack system - in maybe the LPC-H11A14 form-factor.
Can you fit the video chip + driver within that square, ( ~ 33mmx33mm) 38mm PCB and have the connector just outside ?
The base board could fit a vertical Phono connector footprint, inside that ring ?
I can see one error in the LPC-H11A14 form-factor, which is they seem to have made it completely symmetric, so there is no user-oops protection there.
With 4 sets of pins, you can easily make it one-alignment only.
So, there was a $295 setup fee and then about 30 cents per square inch.
The LCP thing is 6.2 square inches for $2.40.
So, I guess that is about the right size board...
Wait a minute... I don't get it, the LCP page says the size is:
Dimensions:80x50mm (3.15 x 1.97")
And yet, the PCB is square...
http://www.olimex.com/dev/lpc-h11xx.html
I really looks 1.5"x1.5"= 2.25 square inches. So, I think I can budget in a bigger board...
http://www.olimex.com/dev/ARM/NXP/LPC-H11XX/LPC-H1114.pdf
That dimensions a 38mmx38mm square PCB
All the pins are broken out to the ring of holes around the board. I usually used a second small board with a voltage regulator stacked on top of this one as a power supply. I thought they made nice little Prop boards.
Here's one I made to use with a breadboard (this one has a DIP EEPROM).
I don't think I've made any this way since the QuickStart came out. Rolling my own with the above board with just too much work for the few dollars I'd save.
Just checked and it's now $14.99. So that, plus the Prop chip and other things is certainly going to be over $19.99...
