A propeller USB stick
Tubular
The new compact FT230X lets me do something I've wanted to do for a while - a plug in "memory stick" prop circuit, for development. Just the basics - FT232R (equiv), xtal, micro sd, regulator, eeprom.
This board is 1.44" (37mm) long, and 1/2" wide
There are 8 GPIO (P16~23) are connected by a 10 pin IDC ribbon to the back of the board, and superglued or heathrink for strain relief.
I'm not using the 'extra components' associated with the FT230XS. If it doesn't work there are links for standard TTL (ie prop plug)
Edit: Assembled photo added
I've been thinking about that smaller chip too
I have 9 or 10 clear USB enclosures if you want them.
I bought a couple of similar enclosures from Element14. They may even be the same - one half has an oval recess and the other half a rectangular recess. Does that sound right?
Here's the link to what I bought... http://au.element14.com/multicomp/mcg1901/box-usb-plug-in-clear/dp/1603603
If it is the same, the board fits in easily as you can see from the photo below.
There's another company New Age Enclosures who have small usb enclosures, available through Mouser. It would be great to make an even shorter board, my mounting most of the components on the underside below the prop.
The microSD header looks neat, I didn't realize they were available.
Can I get an assembled pcb off you when you're done? Just for the fun of it.
The LDO - I like the way it lets the P0-P3 pass under en route to the SD card, and the symmetry with the msop eeprom. Its stable with 1uF, and its easy enough to get 4.7~10uF ceramic in 0603 for extra margin. But yes there are more compact alternatives. Rearranging it may be possible to squeeze 5mm of length by changing to a small reg, and putting the xtal where the tc1107 is now...
The Xtal certainly is the elephant of the design now. Previously it was the FT232RL.
Thanks for the link, I'll check those xtals out. The xtal is about the same size as the uSD socket ("header").
That's the one.
That leaves plenty of room for options like byte-wide QuadSPI chips for big XMMC programs.
I was planning to distribute PropellerGCC packages on the SD Card later.
For +5V to +3.3V regulation I've been using TI 73633 in 5SOT-23, 0.4A Iout, 75mv Vdo, 0.3ma Iq, 1% Accuracy, Caps optional.
Whilst the HC49/u may be large, it is widely available.
Note too, that the relatively low default clock of the Prop, excludes some packages.
I'd be more relaxed about leaving off the Caps, than the series R's. They will help the ESD tolerance, and on something that will be on a bench, with cables connected, that detail matters.
I'm sure there is room to fit 2 SMD resistors, even on the back of the board ?
That's a great idea (the packages dist on SD card...)
And nice regulator too. I like the "caps optional" - haven't seen that before.
I did think about it, but they are only 27 ohms. I'm actually quite curious about their exact purpose - is it something in the USB spec? Or are they trying to match cable impedance that varies from one manufacturer to another, or a slight EMC filter on output (27 ohms + 47pF)?
But you're right I could add some pads on the back. There are a few "optional component" pads on the back already - a TAJ-B tantalum in case its needed for SD card reliability, and some leds and corresponding resistors for power and P16~P23.
BTW, Resistor arrays save a lot of room and are the same price as a single resistor. Use this for the 27R in the USB line. You could also use 56R resnets and parallel etc.
I didn't really enjoy soldering Cluso's Ramblade resnets, but I guess I could revisit 4-packs...
I might have a crack at revising the layout based on two sides heavily populated, and your component suggestions (thanks). This is the target case it would be great to squeeze into...
This looks great!
Here is the SOT23 regulator 6Vin 3V3 out 250mA (use big pads) MCP1700T3302ETTCT-ND
Here are two 0805 10uF 6V3 Ceramic caps from DigiKey...
A t/hole xtal will actually take less pcb space but of course both sides. If you use 0.040" holes you can fit the xtal socket pins.
ED5037-ND
Not sure if you have the transistor reset cct. I am now using a SOT-23 transistor with series base and base-emitter resistors (Thanks Peter). IIRC they are 470R series and 4K7 B-E. It saves the 10K B-E resistor. You could actually omit the series resistors (or use resnets) for P31 & P30 since the FT chip is 3V3 I/O. (I have not checked your circuit to see if they are present.
And as Peter said, put some components underneath - at least the resistors and caps.
I have some of all of the above, and 56R (IIRC) resnets if you need a few.
Nice part. You use the 150ppm stability spec? Any drawbacks such as video artifacts?
I look forward to hearing your results. It's a nice package.
At least a 30ppm precision/stability part is available at a price.
Is there a second source?
I guess my parts choice reflect the limit of my soldering confidence, and I traditionally have drawn the line at QFN/DFN. During our summer holidays I set up a toasting area at work, complete with tiny peltier fridge to keep the tub of solder paste (as well as other chemicals) at 4 degrees or so. Got some stencils from ohararp.com (great), and other bits and pieces (solder tub etc) from Mektronics. I've run 2 or 3 tests with satisfactory results, and only had one failure which happened to be a QFN prop.
Need a more "compliant" oven - looking at what Elektor come up with, as well as some other units from France etc.
@MacTuxLin, thanks!
As for pcbs and stencils I've been using Storm Circuit lately and I've been really happy not only with their work but also their professionalism I guess you would call it as they check on your work and zip off a question or two if needed unlike some places that blindly follow your mistranslated instructions without any "are you sure"s. They are based in Hong Kong but they communicate like locals and are very helpful.
Second source distributor for NDK crystals is also AVNET as far as I aware. If you mean manufacturer then I'm not sure but I do dual foot-prints to allow for cylindrical ones in case there is a supply problem or else maybe allow for more choice in frequencies.
This board was the last one added to the Smorgasboard, when there was a small 1.44"x0.51" space left over
One application might be as a automated propeller based slideshow presenter - based on the great work in the recent thread. Some monitors have a usb port which could power this. The VGA connector at the other end would plug into the VGA port of the monitor or projector.
Will get one up to you shortly, Peter.
