Puff the Magic Boe Bot
I hooked up a 10-12v 650mAh battery to the bread board... After the smoke cleared, there is a burn mark on the ping sensor center chip in the back. The bot also stutters when in looks left and right. Hooking it up right the bot works fine other than the fact it twitches left and right. What chip did I burn (on the ping) and what did I damage to make the servo stutter? I swapped servos with a wheel servo and it stutters so the servos are ok. I did it this time....
Big center chip... *grumble...stupi...volta..regul...12v in a 3v syst....idiot*
what's the status? is it workin?
-Matt
http://s952.photobucket.com/albums/ae9/mchlcrash/?action=view¤t=MAH00104.mp4
I have not had time to try new pins between work and kids....kids...whos idea was that... I will post as soon as possible.
-MattG
It comes up a *new post* to me
So, have you been able to determine whether the Ping is fully operational? Have you disabled all other parts of your program on the bot, and can you see a debug of just the Ping values? Let's see what's broke and then get you fixed up.
Try the Ping on a couple of different IO lines to see if the issue is one of those lines (on the Stamp).
-MattG
Go here to test just the Ping, removing everything else from the picture (no servos). You'll be able to see the actual values the Ping is reporting.
http://sites.google.com/site/parallaxinretailstores/home/ping-ultrasonic-distance-sensor
From there, you can physically disconnect the Ping, and run the BOE-Bot activity that demonstrates putting the servos through the paces. In other words, what you want to do is isolate the pieces, and try each one separately. Isolate not just in code, but by physically disconnecting parts as you systematically test. Do the same for the Ping servo, just sweeping it back and forth. Disconnect everything else when you make this test.
-- Gordon
The new servo also stutters as the code is run. It looks as I hit two birds with ten 10 volts and will also be in the market for a new bs2. Thanks for the replies.
No worries...We've all "let the magic smoke" out many times also :frown:
It's all part of the fun? of it!
Please PM me with your shipping address, ok? Let's get you fixed up...:thumb:
-MattG
